I have Cooler Master XB Case - I'm going to mod the top panel for radiator to cool 2 x R9 290X VGA's crossfire. I was wondering If the Phobya Xtreme 200mm Radiator will be able to cool cards at stock clocks ? I was also looking at the Phobya Xtreme QUAD 480 Square radiator. I'm going to use a 240 or 280 + 1 x 120 to cool mother board. I have the EK mobo water block and CPU water block. Plumbing this case is going to be a nightmare - I think I can pull it off. I'm going to run single loop if possible. I also removed hot swap bays to give a little more room. Any help would be appreciated. Thanks wibujo
