ARMAGGEDDON Alien IV G9X Gaming Mouse
Introduction
ARMAGGEDDON is a Singaporean brand, established on 11 November 2011. Although relatively new to the world of gaming peripherals, they specialize in gaming gear for professional gamers to help them realize their full potential in training and achieve peak performance in competitions. Today we have the chance to review the flagship gaming mouse called Alien IV G9X. The mouse has Count Per Inch up to 6400 CPI, PixArt 3305 advanced optical sensor, 7-level weight management and many other interesting features. Let?s see what the high-end gaming mouse has to offer.
Product Link: http://armaggeddon.net/gaming-mice/alien-g9x/
Suggested Retail Price: RM 139
Specifications
? 6 Macro-able? optical gaming mouse with 512 KB on-board memory
? CPI switching on-the-fly [default]: 400/ 800/ 1600/ 3200 CPI
? Software CPI setting: as low as 400 CPI up to 6400 CPI
? Adjustable polling rate (/second): 125 Hz/500 Hz/1000 Hz
? Frame rate: 6600 fps
? Acceleration: 20 G
? Advanced Optical sensor: PixArt 3305
? Adjustable mouse light effects and up to 4 colour options
? Total 6-Buttons with 2-Way Click scroll [save up to 7 macros in 5 available profile]
? High performance tracking speed: up to 160 inches per second
? Resolution range: 400 ~ 6400 CPI
? 6-button optical mouse
? On-board memory: 512 KB
? Cord length: 1.8 m
? 125 (L) X 82 (W) X 40 (H) mm
Unboxing
The front of the matte black box is illustrated with a picture showing the Alien IV G9X in yellow colour illuminated with Maldives blue lighting and some key features of the mouse. Near the bottom of the box shows the Alien IV G9X name and the tag line of "Great Grip Comfort, Balance and Weight Management?.
The back of the packaging describes the function of every button on the mouse, the 7-level weight management, dimension of the mouse, and system requirements. There is a big orange logo highlighting the mouse?s 2-year warranty accompanied by ?Very Durable? words nearby to emphasize that this gaming mouse is reliable and durable.
The accessories included in the packaging are pretty standard. You get a user manual, a set of replacement mouse feet, and a starter kit CD.
My first impression of the Alien IV G9X was impressive. It is a very attractive gaming mouse and the size fits just right on my palm. The mouse is very light measuring 125 mm X 82mm X 40 mm. However there is no information on the actual weight of the mouse. The mouse we received is the yellow colour version of Alien IV G9X. There are also blue and black versions available in the market. The black surface of the mouse has rubberized finish to provide an ultimate grip and comfort during heavy gaming. Coming from the front of the mouse you will find 1.8 meters of cable that has been covered in cloth braided sleeving along with a USB 2.0 connector.
The Alien IV G9X features six macroable buttons that you could customize using the included software. These include the left and right-click buttons, the scroll wheel click button, and a pair of thumb buttons as well as an additional button on the far right which serves as the double-click function.
The top of the Alien IV G9X offers a CPI on-the-fly button to adjust the sensors tracking speeds ranging from 400 to 3200 CPI, while you are gaming or working, without needing to go to the software for changes. Take note that you are able to set higher CPI up to 6400 CPI through the software. You also have the scroll wheel with motocross tyre print shaped grips on it to assure you don't slide on the wheel during heaving gaming. There is a curve located on the left side of the mouse to rest the thumb. Along the top edge you will find two thumb buttons that are defaulted for the forward and backward page functions and CPI level LED indicator on the front left.
Here you can see the right side of the mouse with the double-click button at the ring finger position. You could assign this button as another function such as forward page button if you like, through the included software.
At the rear edge you can remove the cover that houses the weights. You are given with seven 2.6 gram weight management system, you can add or remove them to suit your needs and desired feel.
Under the Alien IV G9X you have the advanced optical sensor PixArt 3305, which is centered well at the middle of the mouse. The mouse is equipped with four extra-large Teflon mousefeet for a faster and smoother glide. Teflon is known to have longer lifespan than conventional skates. You will also find warranty expiry information and serial number here. The Alien IV G9X features a Maldives blue lightning. The blue light effects including the intensity and pulsation speed can be adjusted via the software.
