Hi again.
Most of you remember me for my baby cascade jajaja. In the end it worked (a Killer SS could be far more effective), but for now that project is discarded. I need some cooler gases like ethane or ethilene. Will do a deep search in March for sure (have some frinds at that have access to University labs).
Upgraded the Danfoss NF11FX for some Panasonic R410A compressors with one of the condensers.
On the same base I have mounted two single stages, one for 12,000 BTU and the other one with 9,000 BTU.
These are the specs of the system (1st and 2nd) thats already built and is realy for gas filling.
Compressors: 2 x Panasonic R410A rotary compressors (12,000 & 9,000 BTU)
EVAP: Piotres 118cm suction Line with 54mm evap. Ryba will provide me a 42mm x 140cm for the 9000 BTU SS next month.
HX: Danfoss 10 plates (B3-014)
CPEV: Captube (Piotres SL is 0.91mm x 270cm long).
Condensers: 1x CD-8.4 1,5 KW (18000 BTU max) + 34 watts fan & 1 x CD 3/4, alu-cu (9000 BTU max) + 18 watts fan .
Refrigerants: R507
9000 BTU system is thought for GPU, NB and Mems. Maybe can be used for CPU and cool two platforms at the same time . Im ordering from Ryba a lot of mounting kits .
For the moment we have only tested with R-507a and achieved -61?C idle. Right, that alone does not matters. Next week there would be some load tests with some resistances. Discarding the peltiers jajaja
Thanks for watching
