Results 1 to 2 of 2
Thread: gigabyte windforce 290 backplate?
    Jul 2006
    Is there a backplate for gigabyte windforce 290?
    I want to put it a water block and backplate
    Aug 2006
    Go to EK's sight and use their water-block/card compatibility program and then see if there is a compatible water-block. Then the back-plate's screws will go through the holes on the video card and then screw into the water-block.
    In other words, you want to find a compatible water-block for your video card and then find the back-plate that is compatible with that water-block.
    Custom case laser cut from a 3/16" thick sheet of brushed Aluminum 8"x80" & cold formed into a box then anodized black with 1/2" Poly-carbonate side panels..[.fully modular, all aluminum mounting brackets, HD bays, and mobo tray are removable...down to the bare box
    --Asus Maximus V Gene--
    --Intel 3770k @4.2 GHz De-lided and I soldered an Arctic Twin Turbo to the Intel.
    --MSI R7970 3GB @1150, 1500 cooled with an Arctic Accelero Xtreme--
    --G.SKILL Ripjaws @2400 MHz --
    --SeaSonic X-1050 Gold--
    --128 GB Sandisk UltraPlus is was only $59 new! Seagate 1TB HD--
    --Samsung S23A750D 120Hz monitor--
    --Razer Tarantula-- keyboard, yes it is like 8 years old!
    --Corsair M60 mouse--
    --Klipsh Promedia 2.1-- I rock stereo speakers the way they were meant to be rocked
    -- 100% Fun ...
    Does it ever shock anyone else when your hear someone use Darwin's "survival of the fittest" to justify genocide?
