Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
Thread: AMD FX-9590 nr1 and nr2 by FlanK3r
  1. #51
    Feb 2008
    Austria
    @ FlanK3r
    Nice FX-9590
    How much V-Core did you use for 4,5 GHz and 5,0 GHz @ Prime 95?
    And wich Steppin does they have?
    Here you can see different Prime95 runs from Germany
    http://www.hardwareluxx.de/community...l#post22604204
    FX-9370 @ 4.7 GHz @ 1,44 V | NB @ 2286 MHz @ 1,21V
    32 GB 1600 CL11 1,5V @ 846 MHz @ CL 9-9-9 @ 1,4V
    MORA 2 + Laing D5 + 9 x 120mm @ 5V
    Gigabyte GA-970A UD3 Rev. 1.2
    XFX HD7750 2GB Core Edition
    Samsung 850 Pro 512GB
  2. #52
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    I dont use PRIME 95. Im use AOD stress test. Look at first page (undervolting)
    http://www.xtremesystems.org/forums/...=1#post5225417
    btw, awesome temps from PRIME95 and wattercooling. Seems some highend watter setup. But only HT link is too low, default is 2600 for FX.
    ROG Power PCs - Intel and AMD
  3. #53
    Feb 2008
    Austria
    I prevere Prime95, because it heat & stress the CPU more
    Is a hight HT good? I thing it brings no Speedup and only problems with stability
  4. #54
    May 2008
    Czech republic
    yes, it can help in some GPU bandwith. So with highend GPU cards or Crossfire it could help in some scenarios. I wanna try with 8370E try few test up to 3200+ MHz at HT
  5. #55
    Feb 2008
    Austria
    I search today an find this old review http://www.xtremesystems.org/forums/...Results-coming
    There it scale good in Cinebench als also a little bit in Wprime and also Superpi1m.
    But if the HT clock is highter than the CPU-NB clock, the points in Wprime and also Superpi1m go down
    Furthermore, the results are from a low voltage competition wich you can see here
    http://www.hardwareluxx.de/community...m3-567063.html
    There youmust reach certain clock speeds at lower voltage, to compare the processors well with each other
    I think therefore he put down the CPU-NB to 2000, because then the CPU-NB uses less power and this remains cooler CPU when overclocking
    So he could overclock the CPU better
    Further i found out that the CPU-NB use less voltage lf tRC is high.
    The Highest tRC in my Bios is 42
    In Windows i can set te tRC up to 56 by using AOD, but i cant set an lower CPU-NB there i boot with the OS
    Also i fiund out if you push the Processor ODT from 60 to 120 Ohms and the Refresh Cyclus up to 300ns, the RAM works with much tighter timings and less voltage
    Now T1, tRAS of 18 and a Refrash Rate of 3.9us is absolutly no problem and also much other tight timings
    Here you can see everything. The RAM?s are Kingston ValueRAM 1600 CL11 (KVR16N11/8) with Elpida 4Gbit xBxx chips @ 1.35V
  6. #56
    Xtreme 3D Team
    Jan 2009
    Ohio
    Quote Originally Posted by FlanK3r View Post
    I don't really think higher HT Frequency will help GPU very much. It helped with integrated GPU on G/GX series chipsets, though...
    Smile
  7. #57
    May 2008
    Czech republic
    not much, but some step could be here.
    techtrancer: with tRFC I know (but in SUperpi guys need the lowest stbale tRFC ). The ODT info is interesting. I never played with this. Thnaks for good information. What I saw at hardwaredeluxx forum, there are few very nice results in stable OC.
  8. #58
    Feb 2008
    Austria
    Hope you will also post there stable OC results of your FX
    Have you other tips for me about FX RAM OC?
  9. #59
    May 2008
    Czech republic
    For higher CPU clocks, what I know, is better to have RAM at 1600 MHz, but of course for 24/7 performance I have personaly 2400+ MHz DDR3 (CPUNB the same clock and 1.25V at CPUNB). Its possible to get RAM around 2600-2666 for benchamrking, but its not easy. This tried The Stilt some times ago (I think).
  10. #60
    May 2008
    Czech republic
    Its nice Friday and my morning is about working at my PC. No crazy loads, only office, emails and sometimes take a look to the forums . Im going to lunch and I came back, my PC is frozed and in Coretemp I see temps 78 C! Wtf?
    So hard restart, everything is OK and around 5 minutes " boooom", I shocked a lot, my tube at Swiftech H220 explozed :-D. The hole is not big, but watter flows out, I must shutdownd PSU...
    There is hole, crack...I think one reason were temps at CPUNB and I think, there was some issues with pump in block...
    So, back to pure aircooling
  11. #61
    Apr 2003
    North America, USA, TX
    SO sad to see this! Did anything else get damaged? I have the same cooler and it was an RMA. It cools well but might be a ticking time bomb?
    Old Standby:
    DFI LANPARTY nF4 Ultra-D (R.AD0) 623-3 BIOS
    AMD Athlon 64 3800+ X2 (CCBWE 0529SPMW)
    THERMALRIGHT XP-90 w/Panaflo FBA09A12H-1AZ 90mm (56.8cfm) - AS Ceramique
    MSI NX6600GT-TD128E GF 6600 GT PCI-E
    WD Raptor 74G Boot, WD 1200JB IDE
    NEC ND-3520AW Black
    OCZ OCZ600ADJ ATX 600W
    ALPS Black 1.44MB 3.5" Internal Floppy Drive Model DF354H121F
    Lian Li PC-60USB B2 Silver Aluminum ATX Mid Tower Computer Case
    Win XP Pro (32-bit) SP2
  12. #62
    May 2008
    Czech republic
    I was lucky, all componments are live . Now Il send it to RMA too. The support team said me, it could be air bubbles inside...
  13. #63
    Apr 2003
    Good, I have had good service from them.
    Old Standby:
    NEC ND-3520AW Black
  14. #64
    Xtreme Mentor
    Feb 2007
    West hartford, CT
    yes i had the h220x leak on me at the swivel fitting....but not the tube bursting!
    swiftech replaced mine no questions asked.
    good luck
    FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
    Asus Crosshair Formula 5 Am3+ bios v1703
    G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
    MSI 7950 TwinFrozr *1100/1500* Cat.14.9
    OCZ ZX 850w psu
    Lian-Li Lancool K62
    Samsung 830 128g
    2 x 1TB Samsung SpinpointF3, 2T Samsung
    Win7 Home 64bit
    My Rig
