Results 1 to 7 of 7
Thread: Gigabyte f2a88x-up4 amd a10 7850k review
    Jun 2005
    NYC
    Mainboard
    GIGABYTE F2A88X-UP4
    BIOS F4
    Processor
    AMD A10 7850K
    Cooler
    coolermaster V8
    Graphics Cards
    5870
    7870
    7970
    R9290X
    Memory
    CORSAIR DOMINATORS PLAT 2133 2X4GB
    TEAM GROUP 2666MHZ 2X4GB
    Power Supply Unit
    THERMALTAKE toughpower XT GOLD 1375w
    Monitor
    ASUS VK246H
    OS related Software
    Windows 7 64-bit SP1
    DirectX 9/10/11 latest End User Runtime
    cat 13.30beta
    Software benchmark suite
    SiSoft Sandra
    Aida64 extreme
    WPRIME
    sisoft sandra
    PCmark 8
    x264 benchmark
    3DMark01
    3DMark03
    3DMark05
    3DMark06
    3DMark Vantage
    3DMark 11
    3DMark 2013
    CineBENCH 11.5
    CineBENCH R15
    Resident Evil
    Tomb Raider DX11
    Bioshock infinite DX11
    Sleeping dogs
    SiSoftware Sandra
    Benchmark Results
    Aggregate Native Performance : 63.14GOPS
    Dhrystone Integer Native SSE4.2 : 93GIPS
    Whetstone Float Native SSE4.1 : 48.86GFLOPS
    Whetstone Double Native SSE4.1 : 37.61GFLOPS
    Whetstone Float/Double Native : 42.87GFLOPS
    Results Interpretation : Higher Scores mean Better Performance.
    Decimal Numeral System (base 10) : 1GOPS = 1000MOPS, 1MOPS = 1000kOPS, 1kOPS = 1000OPS, etc.
    Performance per Thread
    Aggregate Native Performance : 15.78GOPS
    Dhrystone Integer Native SSE4.2 : 23.25GIPS
    Whetstone Float Native SSE4.1 : 12.21GFLOPS
    Whetstone Double Native SSE4.1 : 9.4GFLOPS
    Whetstone Float/Double Native : 10.72GFLOPS
    No. Threads : 4
    Performance vs. Speed
    Aggregate Native Performance : 13.80MOPS/MHz
    Dhrystone Integer Native SSE4.2 : 20.32MIPS/MHz
    Whetstone Float Native SSE4.1 : 10.68MFLOPS/MHz
    Whetstone Double Native SSE4.1 : 8.22MFLOPS/MHz
    Whetstone Float/Double Native : 9.37MFLOPS/MHz
    Benchmark Status
    Result ID : AMD A10-7850K APU with Radeon(TM) R7 Graphics (2M 4T 4.58GHz, 4.12GHz IMC, 2x 2MB L2)
    Computer : GigaByte F2A88X-UP4
    Platform Compliance : x64
    SMP (Multi-Processor) Enabled : Yes
    NUMA Support : No
    No. Threads : 4
    Processor Affinity : U0-M0T0 U2-M1T0 U1-M0T1 U3-M1T1
    System Timer : 4.47MHz
    No. Runs : 64000 / 640
    Processor
    Model : AMD A10-7850K APU with Radeon(TM) R7 Graphics
    Speed : 4.58GHz (99%)
    Minimum/Maximum/Turbo Speed : 2GHz - 4.58GHz - 4.58GHz
    Peak Processing Performance (PPP) : 36.64GFLOPS
    Adjusted Peak Performance (APP) : 11WG
    Cores per Processor : 2 Unit(s)
    Cores per Compute Unit : 2 Unit(s)
    Front Side Bus Speed : 229MHz
    Type : Laptop/Netbook
    Revision/Stepping : 30 / 1
    Microcode : MU6F300103
    Latest Version : MU6F300104
    L1D (1st Level) Data Cache : 4x 16kB, 4-Way, Exclusive, 64bytes Line Size
    L1I (1st Level) Code Cache : 2x 96kB, 3-Way, Exclusive, 64bytes Line Size, 2 Thread(s)
    L2 (2nd Level) Data/Unified Cache : 2x 2MB, ECC, 16-Way, Exclusive, 64bytes Line Size, 2 Thread(s)
    Memory Controller
    Integrated in Processor : Yes
    Speed : 4.12GHz
    Features
    SSE - Streaming SIMD Extensions : Yes
    SSE2 - Streaming SIMD Extensions v2 : Yes
    SSE3 - Streaming SIMD Extensions v3 : Yes
    SSSE3 - Supplemental SSE3 : Yes
    SSE4.1 - Streaming SIMD Extensions v4.1 : Yes
    SSE4.2 - Streaming SIMD Extensions v4.2 : Yes
    HTT - Hyper-Threading Technology : Yes
    Performance Enhancing Tips
    Warning 241 : Dynamic OverClocking/Turbo enabled. Performance may not be consistent and may not match expectations!
    Warning 227 : CPU FSB speed higher than rated FSB! Reduce FSB speed.
    Tip 229 : CPU microcode update available. Check for an updated System BIOS with updated microcode.
    Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
    SiSoftware Sandra
    Benchmark Results
    Aggregate Memory Performance : 16.72GB/s
    Integer Memory Bandwidth B/F SSE2/128 : 16.65GB/s
    Float Memory Bandwidth B/F SSE2/128 : 16.79GB/s
    Binary Numeral System (base 2) : 1GB(/s) = 1024MB(/s), 1MB(/s) = 1024kB(/s), 1kB(/s) = 1024 bytes(/s), etc.
    Benchmark Timings
    Time to Copy Capacity : 479?s
    Results Interpretation : Lower Scores mean Better Performance.
    Aggregate Memory Performance : 8.36GB/s
    No. Threads : 2
    Performance vs. Power
    Chipset(s)/Memory Power : 12.450W
    Aggregate Memory Performance : 1374.94MB/s/W
    Integer Memory Bandwidth B/F SSE2/128 : 1369.40MB/s/W
    Float Memory Bandwidth B/F SSE2/128 : 1380.56MB/s/W
    Capacity vs. Power
    Memory Capacity : 658MB/W
    Aggregate Memory Performance : 7.01MB/s/MHz
    Integer Memory Bandwidth B/F SSE2/128 : 6.98MB/s/MHz
    Float Memory Bandwidth B/F SSE2/128 : 7.04MB/s/MHz
    Assignment : 16.71GB/s
    Scaling : 16.17GB/s
    Addition : 16.81GB/s
    Triad : 16.9GB/s
    Data Item Size : 16bytes
    Buffering Used : Yes
    Offset Displacement : Yes
    Bandwidth Efficiency : 42.47%
    Assignment : 16.72GB/s
    Scaling : 16.52GB/s
    Addition : 17GB/s
    Triad : 17GB/s
    Bandwidth Efficiency : 42.69%
    Benchmark Status
    Result ID : AMD PCI standard host CPU bridge; 2x 4GB Corsair CMD8GX3M2A2133C9 DDR3 SO-DIMM (2.44GHz 14% OC 128-bit) PC3-17100 (12-16-16-42 8-58-18-10)
    Total Memory : 6GB
    Memory Used by Test : 2GB
    No. Threads : 2
    Page Size : 4kB
    Features
    Computer
    Name : GigaByte F2A88X-UP4
    Computer BIOS : F4
    Chipset
    Model : AMD PCI standard host CPU bridge
    Revision : A1
    Width : 16-bit / 16-bit
    Maximum Bus Bandwidth : 916MB/s
    Logical/Chipset Memory Banks
    Bank 1 : 4GB DDR3 SO-DIMM 12-16-16-42 8-58-18-10 4T
    Bank 13 : 4GB DDR3 SO-DIMM 12-16-16-42 8-58-18-10 4T
    Channels : 2
    Width : 128-bit
    Memory Bus Speed : 2x 1.22GHz (2.44GHz)
    Multiplier : 32/6x
    Cores per Memory Controller : 4 Unit(s)
    Maximum Memory Bus Bandwidth : 38.16GB/s
    Memory Module(s)
    Memory Module : Corsair CMD8GX3M2A2133C9 4GB DIMM DDR3 PC3-17100U DDR3-2134 (9-9-9-25 4-33-10-5)
    Warning 5400 : Low bandwidth efficiency (advanced). Check memory timings and settings.
    Warning 5010 : Cannot use Large Memory Pages due to lack of privileges.
    SiSoftware Sandra
    Benchmark Results
    Transactional Throughput : 5.11MTPS
    Modify/Read Factor : 0.60
    Lock : Hardware (HLE)
    Transactional Throughput : 2.56MTPS
    No. Threads : 2
    Transactional Throughput : 1.12kTPS/MHz
    Detailed Results
    Modify Probability (0.00) : 3MTPS
    Modify Probability (0.04) : 5MTPS
    Modify Probability (0.08) : 5.18MTPS
    Modify Probability (0.12) : 5.45MTPS
    Modify Probability (0.16) : 5.64MTPS
    Modify Probability (0.20) : 5.6MTPS
    Modify Probability (0.30) : 5.56MTPS
    Modify Probability (0.40) : 5.49MTPS
    Modify Probability (0.50) : 5.34MTPS
    Modify Probability (0.60) : 5.3MTPS
    Modify Probability (0.80) : 5.24MTPS
    Modify Probability (1.00) : 5.17MTPS
    Benchmark Status
    Result ID : AMD A10-7850K APU with Radeon(TM) R7 Graphics (2M 4T 4.58GHz, 4.12GHz IMC, 2x 2MB L2) (Hardware (HLE))
    No. Threads : 2
    Update : Database Transactional
    Processor
    Memory Controller
    Speed : 4.12GHz
    SiSoftware Sandra
    Benchmark Results
    Memory Latency : 71.6ns
    Decimal Numeral System (base 10) : 1s = 1000ms, 1ms = 1000?s, 1?s = 1000ns, etc.
    L1D (1st Level) Data Cache : 4.0clocks
    L2 (2nd Level) Data/Unified Cache : 19.0clocks
    Speed Factor : 81.80
    Chipset(s)/Memory Power : 6.230W
    Memory Latency : 11.49ns/W
    Capacity vs. Power
    Memory Capacity : 657.46MB/W
    Memory Latency : 0.03ns/MHz
    Detailed Results
    2kB Range : 0.9ns / 4.0clocks
    4kB Range : 0.9ns / 4.0clocks
    8kB Range : 0.9ns / 4.0clocks
    16kB Range : 0.9ns / 4.0clocks
    32kB Range : 4.2ns / 19.0clocks
    64kB Range : 4.2ns / 19.0clocks
    128kB Range : 4.2ns / 19.0clocks
    256kB Range : 4.2ns / 19.0clocks
    512kB Range : 4.2ns / 19.0clocks
    1MB Range : 4.2ns / 19.0clocks
    2MB Range : 8.3ns / 38.0clocks
    4MB Range : 71.4ns / 327.0clocks
    8MB Range : 71.5ns / 327.0clocks
    16MB Range : 71.5ns / 327.0clocks
    32MB Range : 71.5ns / 327.0clocks
    64MB Range : 71.5ns / 327.0clocks
    256MB Range : 71.5ns / 327.0clocks
    1GB Range : 71.6ns / 327.0clocks
    Benchmark Status
    Result ID : AMD PCI standard host CPU bridge; 4GB Corsair CMD8GX3M2A2133C9 DDR3 SO-DIMM (2.44GHz 14% OC 64-bit) PC3-17100 (12-16-16-42 8-58-18-10)
    No. Threads : 2
    Page Size : 4kB
    Access Pattern : In-Page Random Access Pattern
    Type : Global Data Memory
    Processor
    Memory Controller
    Speed : 4.12GHz
    Computer
    Computer BIOS : F4
    Chipset
    Revision : A1
    Bank 5 : 4GB DDR3 SO-DIMM 12-16-16-42 8-58-18-10 4T
    Channels : 1
    Width : 64-bit
    Multiplier : 32/6x
    Maximum Memory Bus Bandwidth : 19.08GB/s
    Memory Module(s)
    Warning 2531 : Single memory channel may not provide enough bandwidth.
    SiSoftware Sandra
    Benchmark Results
    Cache/Memory Bandwidth SSE2/128 : 78.62GB/s
    L1D (1st Level) Data Cache : 335.57GB/s
    L2 (2nd Level) Data/Unified Cache : 192.76GB/s
    Benchmark Results
    Speed Factor : 26.30
    Cache/Memory Bandwidth : 19.65GB/s
    L1D (1st Level) Data Cache : 83.89GB/s
    L2 (2nd Level) Data/Unified Cache : 48.19GB/s
    No. Threads : 4
    Processor(s)/Chipset(s)/Memory Power : 6.790W
    Cache/Memory Bandwidth SSE2/128 : 11856.55MB/s/W
    Capacity vs. Power
    Total Cache Size : 612.67kB/W
    Cache/Memory Bandwidth SSE2/128 : 17.59MB/s/MHz
    Cache/Memory Results Breakdown
    Buffering Used : No
    Detailed Results
    2kB Data Set : 338.72GB/s (281.68GB/s - 338.72GB/s)
    4kB Data Set : 342.3GB/s (269GB/s - 342.3GB/s)
    8kB Data Set : 340.89GB/s (250.56GB/s - 340.89GB/s)
    16kB Data Set : 335.89GB/s (239.1GB/s - 335.89GB/s)
    32kB Data Set : 320GB/s (231.64GB/s - 320GB/s)
    64kB Data Set : 291.19GB/s (162.09GB/s - 291.19GB/s)
    128kB Data Set : 203GB/s (148.5GB/s - 203GB/s)
    256kB Data Set : 196.82GB/s (124.92GB/s - 196.82GB/s)
    512kB Data Set : 195.36GB/s (143.8GB/s - 195.36GB/s)
    1MB Data Set : 192.65GB/s (142.8GB/s - 192.65GB/s)
    2MB Data Set : 176GB/s (125.48GB/s - 176GB/s)
    4MB Data Set : 109.83GB/s (75.24GB/s - 109.83GB/s)
    8MB Data Set : 17.37GB/s (16.19GB/s - 17.37GB/s)
    16MB Data Set : 17.12GB/s (16GB/s - 17.12GB/s)
    64MB Data Set : 16.71GB/s (15.66GB/s - 16.71GB/s)
    256MB Data Set : 15.89GB/s (14.71GB/s - 15.89GB/s)
    1GB Data Set : 13GB/s (11.92GB/s - 13GB/s)
    Benchmark Status
    Result ID : AMD A10-7850K APU with Radeon(TM) R7 Graphics (2M 4T 4.58GHz, 4.12GHz IMC, 2x 2MB L2); AMD PCI standard host CPU bridge; 8GB Corsair CMD8GX3M2A2133C9 DIMM DDR3 (1.33GHz) PC3-17100 (9-9-9-25 4-33-10-5)
    Total Memory : 6GB
    No. Threads : 4
    Page Size : 4kB
    Processor
    Memory Controller
    Speed : 4.12GHz
    Features
    Computer
    Computer BIOS : F4
    Chipset
    Revision : A1
    Bank 1 : 4GB DIMM DDR3
    Bank 3 : 4GB DIMM DDR3
    Memory Bus Speed : 2x 666MHz (1.33GHz)
    Memory Module(s)
    Amd Nvidia/Ati -3dmark06 scorebord revisted
    asus L1N64-ws or /b depending on bios chip
    4x1gig 8500 gkill bpk
    2x opteron 8224 @ 3.8ghz
    http://www.xtremesystems.org/forums/...&postcount=236
    vga= 8800gt
    winxp pro
    custom chiller -31 water
    2x dtek fuzions
    bix3-with x3panaflo hi output
    antec 850 quattro
    heat under msimax abitmax and dfimax
    Jun 2005
    NYC
    Test done with no changes in CCC
    valley and heaven benchmark
    resident evil only decent frames was with 1280x1024 settings low
    tombraider 1600x900
    sleeping dogs 1980x1080
    bioshock infinite
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    Jun 2005
    NYC
    still testing
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    May 2009
    Australia
    Nice review dude
    Jun 2005
    NYC
    testing with new bios
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    XIP
    Nov 2004
    NYC
    Awesome tests
    3D '11 waiting for your quad 290Xes
    Jun 2005
    NYC
    Quote Originally Posted by Dumo View Post
    Awesome tests
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
