Amd Nvidia/Ati -3dmark06 scorebord revisted
asus L1N64-ws or /b depending on bios chip
4x1gig 8500 gkill bpk
2x opteron 8224 @ 3.8ghz
http://www.xtremesystems.org/forums/...&postcount=236
vga= 8800gt
winxp pro
custom chiller -31 water
2x dtek fuzions
bix3-with x3panaflo hi output
antec 850 quattro
heat under msimax abitmax and dfimax
hopefully new ram arrive tomorrow so i can push apu
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
Can it be you gained more than 100MHz with the new bios? Great clocks!
Either that or he moved to the North Pole for benching
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55'' Samsung LED 3D TV
i was surprised myself 4.7 was pushing it but the bios did fix a lot of issues waiting to see if they can address some more that i found
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
wow, very nice. Superpi is really quickly . Can your chip run 1M at 4900 MHz? Its max what I got, only once from maybe 10 try .
ROG Power PCs - Intel and AMD
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
the same at A88X PRO side, need new BIOS ...Finally I got new DRAMs for higher clocks. At Intel working OK, hope with AMD can rush 2600 MHz.
apu needs the higher mem speed..
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
I have no experience with Kaveri IMC, but Richland can run (6800K) memory at 2666+ MHz for some benchmarks.
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
Kaveri on dice? Was about time, thanks for sharing. Are you hitting an voltage wall at these settings?
im hitting a cold bug @-58 but doing some research its around the same as others
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
So what's Cinebench benchable dice frequency?
Also did you had time to test how high IGP can clock when frozen?
THX!
its bad, if coldbug is so soon
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
can try some tricks as with Ivy Bridge if could help it? So 107+ BCLK
Unfortunately higher BCLK doesn't change nothing on Kaveri CB.
msimax, did u have tested memory oc under cold? My sample doesn't improve nothing on memory oc @ -40C compared to air cooling (2640MHz max) and my rams are good for 2800+. I'm still not sure if i'm doing something wrong or it simply doesn't scale...
PS: -50C cb / -45C cbb here. ASUS A88X-PRO motherboard.
BIOS 0802? Ahhhh, Im still waiting for chip and for LN2
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
Also walling here, no mater the type of RAM/settings I use at around 2520MHz with the A88X Sniper board... FYI memtest 7 just hardlocks...
No matter what I tried, I just can't boot into windows over 2520MHz...
Noms mate you got a good IMC going there...
This CPU is running tighter clock per clock versus my 6800K. However it would have been even more fun if it could 2600ish memory speeds... guess not...
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
I'll be picking up a 7850K and Asus A88X Pro tomorrow so hopefully next week I'll have time to try out the RAM wall and see what I can come up with.
Heatware
filmbot
msimax, I was wondering if you had any experience with benchmarking this set-up against a multiplayer BF4 map (after a decent overclock... not stock speeds)... I ask because I am contemplating building with this CPU/mobo set-up for my HTPC which I intend to game at 1080p with (BF4). I'm addicted needless to say I'd like to see high settings at 30fps plus if possilbe... I would obviously overclock this set-up to it's limit.
EVGA 780i--E8400 @4.05Ghz--TRUE--EVGA GTX760 4GB--4X2GB PC6400 REAPER 4-4-4-15-2T @800mhz--150 RaptorX--PCPC 750 silencer--Antec 900
