hey guys, registered here years ago, but never really bothered to post. always just quietly observed the forum.
recently went through an overhaul and upgraded to the 3770K and was able to clock it up to 4.8ghz at 1.37v. recently retired the OLD D4 pump and finally got rid of that jet engine pitch noise, and got myself a D5, running at power level 5. also got rid of some sub par fans on my rad and replaced them with 7 NB eLoop b-12 P PWM fans. as you can see from my sig, the radiators are still the same (one GTS 360 rad + one GTS 120 rad). the block is koolance cpu380.
before upgrading the pump and the fans, i was getting low 70's (71~72 degrees C) in X264 encoding, which is about the most intensive app i use on my rig, but for stress testing Prime95 V27.9 small FFT 12K with AVX reaches 93~95 degrees C at ambiemt temp of about 18~22C.
after the pump and the new eloop fans, at around the same range of ambient temp 18~22C, i am seeing some improvement of high 60's low 70's in X264 (70~71 degrees C), and small FFT Prime V27.9 @ 12K peaks 90C at roughly 18C ambient and 92C at 22C Ambient.
again, i apologize for the wide range of estimate, but if i have to sum it up, comparing before vs after pump + fan upgrade, in best case scenario, i got a 5 degree performance improvement. but basically i believe i am getting anywhere between 2~5 degree of temp improvement average from upgrading the pump and the fans, factoring in the range of ambient temps. i should mention that i have all the eLoop fans setup through PWM in push + Pull so it throttles to full 2000rpm during load and quietly operating 1000rpm at idle. this is exactly what i wanted.
i understand that the inherent problem with HOT 3770K lies within the TIM used under the HIS. but since i am not ready to take the plunge just yet on delidding. is there anything else i can do to even bring the temp down by a few degrees. do you think adding another 120mm rad will lower the water temp more? i am also looking at getting the EK Supremacy, since the review here showed that in socket 1155, the Koolance CPU380 performed really poor in comparison to the Supremacy. then i am not sure if i will see that 5 extra degrees of improvement according to the review if i were to upgrade.
or i could buy more powerful fans, and buy another round of GT AP-29 PWM fans that run at 3000rpm. how much temp improvement do you think i'll see in that?
