I just purchased a used waterblock for my 290x to save some cash.
I need to purchase some (I do not know how much) thermal pads to install it.
Fujipoly Ultra Extreme seems to be the best, but it is very expensive. I'm looking at about $40 for 2 quarter sheets in .5mm and 1mm. For that price I would have to stack them in one place for the backplate (1.5mm) because it's too expensive to buy more. (non critical area).
Is it worth the cost difference over say some cheap ebay pad like this one?
http://www.ebay.com/itm/Thermal-Pad-...item2a2e18927d
Should I just get .5mm 60x60mm and layer it?
http://www.frozencpu.com/products/17...pj5s&mv_pc=736
At $40 I would basically be paying full price for the block, but of course it would likely have better TIM where the pads go. Or if I can get away with just stacking the .5mm Maybe I should go that route?
Thanks!
