Another simple single stage but still popular. My goal is set at -30C to -35C with 300W load. -35C target evaporator temp. The colder the better.
Compressor is the dependable and truly tested Danfoss 18CC Made in Germany
Basic parts - all new! Condenser is sized for 3/4hp compressor with 36 rows of tubing.
Chilly1 evap has been prepped for added surface area which should cause more turbulence.
Chilly1 brazed up and cleaned
Time to get started
Wiring done - ON/OFF switch installed
Copper is all run - working on evap and cap tube.
Leak testing @ 250psi. I'm gonna let this sit for a couple of days. Redo suck.
I'll add more pictures as I move along.
Thanks for looking.
