Anyone please ?
Anyone please ?
keep an eye on eBay.
ok i'll try , if anyone knows a specific model that will nice...
Search for HGA9468ZXA
It's 3/4 HP, but its close enough. Its a Horizontal, though... I'm also not sure how well it would translate to an SS Application.
http://www.tecumseh.com/en/united-st...ors/HGA9468ZXA
Some data after the link. I'd say the only issue might be cost, since it uses 507 and you're not gonna find it for a sub $100 deal, most likely. 507 isn't sold under 25lb cylinders either. However, at 5PSI, it does about -40F.
I had a compressor that I could sell to ya, but its not a Rotary, and I'm actually using it for a reclaim system now.
Regards, Stew.....
- This message brought to you by Frank Lee E. Snutz
too strong too heavy need it 12v dc 3-4 kilo max noise level 40db max
cooling capacity 500w max
10x
That doesn't exist.
If you have a cooling question or concern feel free to contact me.
On ebay you will have a better chance of finding a rotary if you look out for a mobile air con unit, over here in europe its winter and possible to pick up one for next to nothing. A unit rated around 9,000 btu should be ok for you. I got one last year from ebay for 99 pence and had to pick up only a mile away from home, its gone in my cascade and doing well.
The other option is to post in the wanted or message the normal builders on here, I know I have excess inventory and I've certainly helped people find things online before.
