Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: Haswell E and X99 to launch in 3rd Quarter...
    Jul 2008
    In the space between...
    Intel is set to release its first eight-core processors for desktops, the Haswell-E series in the third quarter of 2014 priced at around US$1,000. The new series will succeed the existing Ivy Bridge-E, according to sources from the upstream supply chain.
    Intel will also release its next-generation high-end chipsets, the X99 to pair with the processors, the sources noted.
    Source: DigiTimes
    Intel is planning to launch its 4th generation Core i7 HEDT (high-end desktop) platform, codenamed "Haswell-E," in the third quarter of 2014 (after June), which should space its launch roughly a year from Core i7 "Ivy Bridge-E." With Haswell-E, Intel is expected to increase core counts across the board, launching an "affordable" six-core part around the $400 mark, an eight-core part around the $600 mark, and an Extreme Edition eight-core part around the $1,000 mark.
    Source: TPU
    Nice...a $400 6 core for us broke bastards...lol
    'Best Bang For The Buck' Build - CM Storm Sniper - CM V8 GTS HSF
    2500K @ 4.5GHz 24/7 - Asus P8Z68-V Pro Gen3 - GSkill 2x4GB DDR3-2400 C10
    Sapphire Vapor-X 7770 OC Edition - PC Power & Cooling Silencer MkIII 600W
    Boot: 2x 64GB SuperSSpeed S301 SLC Raid 0 Work: Intel 520 120GB
    Storage: Crucial M500 1TB - Ocz Vertex 4 128GB - 4x 50GB Ocz Vertex 2
    HDDs: 2 x 1TB WD RE4 Raid0 - Ext.Backup: 2 x 1.5TB WD Blacks Raid 1
    Moderator
    Oct 2007
    Oregon - USA
    Umm...I think your title should be
    "Haswell E and X99 to launch in 3rd Quarter..."
    Asus Rampage IV Extreme
    4930k @4.875
    G.Skill Trident X 2666 Cl10
    Gtx 780 SC
    1600w Lepa Gold
    Samsung 840 Pro 256GB
    Mar 2006
    Saskatchewan, Canada
    You got the title kind of wrong. You should switch it to haswell E.
    If only the performance increase is decent, the 8 core variant might sort of be worth it this time. Earlier the price for 2 more cores for Intel, let alone 4 has been 300 dollars over their more mainstream counterparts.
    The 6 core is actually a decent price too. E.g Intel charging 70 dollars for 2 more cores rather than the near double the price for 2 more cores is kind of a good value for them.
    However, haswell itself isn't an impressive performer for desktop platforms. Its good for laptops because of the power savings but for desktops, it kind of seems unimpressive.
    Core i7 920@ 4.66ghz(H2O)
    6gb OCZ platinum
    4870x2 + 4890 in Trifire
    2*640 WD Blacks
    750GB Seagate.
    Mar 2010
    Minnesota
    The 8 core will be my next cruncher provided its above 3Ghz for the $600 one.
    Xtreme Addict Chrono Detector's Avatar
    May 2009
    Interested in the new chipset, the X99 and what it offers.
    AMD Threadripper 12 core 1920x CPU OC at 4Ghz | ASUS ROG Zenith Extreme X399 motherboard | 32GB G.Skill Trident RGB 3200Mhz DDR4 RAM | Gigabyte 11GB GTX 1080 Ti Aorus Xtreme GPU | SilverStone Strider Platinum 1000W Power Supply | Crucial 1050GB MX300 SSD | 4TB Western Digital HDD | 60" Samsung JU7000 4K UHD TV at 3840x2160
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by bearcatrp View Post
    You can (should!) always overclock it, all of these chips come unlocked.
    Donate to XS forums
    Jul 2008
    Doh...my bad...thanx for pointing that out fellas.
    "...with support for up to ten SATA 6 Gb/s ports, and a large number of USB 3.0 ports."
    That's what made me grin...as you can tell from my sig, I'm all out of sata 2 and 3 ports...already have the spinners on a pcie card. Hopefully the P97 will sport the same number of ports...thing that has me most interested is that m.2 pcie will be supported so there will be worthy accommodation for SandForce SF-3700 based m.2 drives (1.8GB/s r/w). Not all of us can afford/justify dropping 300-400 bucks on a good raid card.
    Apr 2006
    Damn it, I swore to myself I'd hold out until Skylake-E, as much as I like the idea of Haswell-E I don't want to be a DDR4 early adopter on top of the CPU and Mobo premium, but X99 sounds so much nicer than my old X79...
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    there is original thread...This info is not new :-/
    http://www.xtremesystems.org/forums/...esktop-monster!
    ROG Power PCs - Intel and AMD
    May 2006
    Quote Originally Posted by FlanK3r View Post
    There's new 'info' in it, speculations mostly.
    Quote Originally Posted by Zaxx View Post
    ...an eight-core part around the $600 mark
    If that's true, I'm in, finally! I have a c2d lol
    Jul 2008
    Quote Originally Posted by Iconyu View Post
    I don't want to be a DDR4 early adopter...
    That's probably the biggest drawback for sure.
    Mar 2009
    Toronto ON
    My upgrade goal for next month is:
    ASUS Rampage IV Black Edition
    Intel Core i7-4930K
    CORSAIR Dominator Platinum 32GB (4 x 8GB)
    Now it makes me think if I should not wait for the Haswell E and X99, since all in my upgrade will become obsolete including the mobo and ram, so soon.
    Core i7-4930K LGA 2011 Six-Core - Cooler Master Seidon 120XL ? Push-Pull Liquid Water
    ASUS Rampage IV Black Edition LGA2011 - G.SKILL Trident X Series 32GB (4 x 8GB) DDR3 1866
    Sapphire R9 290X 4GB TRI-X OC in CrossFire - ATI TV Wonder 650 PCIe
    Intel X25-M 160GB G2 SSD - WD Black 2TB 7200 RPM 64MB Cache SATA 6
    Corsair HX1000W PSU - Pioner Blu-ray Burner 6X BD-R
    Westinghouse LVM-37w3, 37inch 1080p - Windows 7 64-bit Pro
    Sennheiser RS 180 - Cooler Master Cosmos S Case
    Mar 2005
    I wish this was true. I don't see Intel releasing this until Q4 or later. Every E has had more that 18 between each..Why is Haswell any different?
    Also, the only 8-core is going to be $1,000 EE version..Unless there is news of a "mid-range" 8-core for $600 like they did for the 6-cores..
    Iron Lung 3.0 | Intel Core i7 6800k @ 4ghz | 32gb G.SKILL RIPJAW V DDR4-3200 @16-16-16-36 | ASUS ROG STRIX X99 GAMING + ASUS ROG GeForce GTX 1070 STRIX GAMING | Samsung 960 Pro 512GB + Samsung 840 EVO + 4TB HDD | 55" Samsung KS8000 + 30" Dell u3011 via Displayport - @ 6400x2160
    Mar 2011
    I was hoping the 5930K would be an 8 Core but it doesn't seem like that is on the cards. I can understand why though, Intel just doesn't feel the heat from AMD in these high end markets so why not make the eight core processor an X series for $999? People who really want it will pay that price myself included. It sucks but it is what it is.
    I really wish Intel hadn't of locked down the E5 XEON's or I would have picked up a 12 core E5-2697 v2 and not even care about Haswell-E i7's.
    Apr 2006
    Quote Originally Posted by Tenknics View Post
    Quote Originally Posted by Vicey View Post
    The first post says $400 for 6 core, $600 for 8 core and $1000 for extreme edition, that doesn't seem very far fetched right now, especially when you consider IvyBridge-E is being built as a 6 core. It seems realistic for Intel to go with this pricing model, and Intel seems very aware of how profitable putting the right chip right at the edge of acceptable cost can be.
    Mar 2006
    Intel arrogance has made it so, although AMD doesn't play a threat at all in this segment, their own processors do.
    With the small increases in performance lately for Intels enthusiast line, they have given people little incentive to upgrade over their previous platform.
    Intel is its own worst enemy at decreasing sales of newly release products. Ivy bridge E reviews, although they obliterated AMD in performance, the reviews came out negative in the end. The reason being, they present almost no performance increase over sandy-bridge E. Add in they clocked worse and they were not even that interesting to the enthusiast who will just take about any reason to upgrade.
    When Haswell E comes out and if it has the same number of cores as Ivybridge E and sandy E, people will be better off sticking with their old platform unless they are still on westmere or older. Haswell brought very little performance increase over ivy-bridge. Particularly with Haswell-e, because it may require a new set of expensive DDR4 memory, Intel has to do something new to entice potential owners. Because IPC is set at this point for the haswell architecture, this means adding more cores at the very least.
    It still pisses me off that Intel has staggered its release so their flagship platform comes out later than their mainstream platform when it comes to a new architecture.
    6gb OCZ platinum
    2*640 WD Blacks
    750GB Seagate.
    XIP
    Nov 2004
    NYC
    Quote Originally Posted by tajoh111 View Post
    On average, it needs 5.3Ghz SB-E to catch 5.1Ghz Ivy-E in most benchmarks full cores. Even bigger difference on IMC scaling
  18. #18
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    Oh may be I think to upgrade my 2500K
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
  19. #19
    Moderator
    Oct 2007
    Oregon - USA
    Try to remember they have staggered their release because haswell-e offers newer technologies than Haswell does. despite the fact they share the same namesake, they are much different processors.
    4930k @4.875
    Gtx 780 SC
    1600w Lepa Gold
  20. #20
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by Ace123 View Post
    The platform is different, the CPU is nearly the same except for the memory controller. Regular workstation platform differences...
    Donate to XS forums
  21. #21
    Dec 2003
    At work
    Unlocked 8 core? Only 3 years late and artificially late due to Intel's incredibly ignorant locking of the E5-2687W.
    Unlocked 10 or 12 core? Intel milked the hex cores for what will be 4.5 years (if Haswell-E actually does appear in Q3 2014). We won't see unlocked 10 or 12 core CPUs before the end of the decade, at the absolute earliest?and that's only if we're extremely lucky. The only way we'll see them sooner will be if AMD can release something competitive this decade.
    Server: HP Proliant ML370 G6, 2x Xeon X5690, 144GB ECC Registered, 8x OCZ Vertex 3 MAX IOPS 240GB on LSi 9265-8i (RAID 0), 12x Seagate Constellation ES.2 3TB SAS on LSi 9280-24i4e (RAID 6) and dual 1200W redundant power supplies.
    Gamer: Intel Core i7 6950X@4.2GHz, Rampage Edition 10, 128GB (8x16GB) Corsair Dominator Platinum 2800MHz, 2x NVidia Titan X (Pascal), Corsair H110i, Vengeance C70 w/Corsair AX1500i, Intel P3700 2TB (boot), Samsung SM961 1TB (Games), 2x Samsung PM1725 6.4TB (11.64TB usable) Windows Software RAID 0 (local storage).
    Beater: Xeon E5-1680 V3, NCase M1, ASRock X99-iTX/ac, 2x32GB Crucial 2400MHz RDIMMs, eVGA Titan X (Maxwell), Samsung 950 Pro 512GB, Corsair SF600, Asetek 92mm AIO water cooler.
    Server/workstation: 2x Xeon E5-2687W V2, Asus Z9PE-D8, 256GB 1866MHz Samsung LRDIMMs (8x32GB), eVGA Titan X (Maxwell), 2x Intel S3610 1.6TB SSD, Corsair AX1500i, Chenbro SR10769, Intel P3700 2TB.
    Thanks for the help (or lack thereof) in resolving my P3700 issue, FUGGER...
  22. #22
    Mar 2006
    Quote Originally Posted by lutjens View Post
    The sad thing is Intel is ridiculously ahead for IPC and single threaded performance compared to AMD.
    Intels QX series which is ancient by today standards, is competitive for single threaded performance and a tiny bit faster clock for clock than Phenom II which remains AMD's fastest IPC core(faster than piledriver).
    If Intel had kept the QX series around and let betters nodes and refinements bring frequency increase(these things could overclock to 4.5ghz on 45nm's), it would still be competitive with AMD's processors today.
    AMD choice to go lower IPC, higher frequency and lower single threaded performance, didn't pay off.
    Intel thus, has been just competing against itself for the enthusiast platform.
    In particularly benchmarkers. I only see Intel being used for benchmarking and its only this group of people that really get benefits from INtels newest platforum. That extra 5% or 10% more performance is significant here.
    Haswell E, hopefully Intel is a bit better with the thermal interface this time around, so people do not need to delid their processors.
    6gb OCZ platinum
    2*640 WD Blacks
    750GB Seagate.
  23. #23
    Aug 2007
    Arlington VA
    The chance to get off the current socket 2011 chipsets might be more than enough to get people to move.
    Their "enthusiast line" is actually their workstation and server line. It's fine to expect things to move slower there, it's the nature of the beast. But their chipsets, be it the 606 or x79, didn't deliver. ivy-E would have been more attractive if x79 had been properly refreshed, when you looked at the entire platform and z77 vs x79 it became a bit of a joke.
    AMD Phenom II BE, ASUS Crosshair II formula, 8gb ddr2 800, 470 SLI, PC P&C 750, arcera RAID, 4x OCZ Vertex2, 2x samsung 7200 1tb, HT Omega Clario +
  24. #24
    Jul 2008
    Quote Originally Posted by Heinz68 View Post
    Intel Core i7-4930K
    I'd wait if I were you...not just for the new cpu but for the chipset features as well...10 sata ports and m.2 pci-e makes me grin but then again I'm a storage/ssd hoar...lol Really REALLY hope that m.2 isn't exclusive to the X99. I sat out on 77 and 87 chipsets mostly for the lack of anything new in the storage department. Was eyeballing a mid-range LSI raid card up until I read about native m.2 support...with the looming SF-3700 launch (1.8GB/s r/w) I now wonder just how fast the 9 series will be. I got another 6 months min. before I'm ready to buy tho, and there will be lots more answers by then...besides, launch prices are always too high for my liking.
  25. #25
    Mar 2006
    Quote Originally Posted by crash5s View Post
    What I don't like about the line is when Ivy bride E comes out, haswell comes out at the same time. And considering haswell performs better than ivy bridge IPC wise, haswell beats it at many tasks.
    This I feel like x79 lineup and its cpu's have such a short life as the top dog.
    I liked it when Intel released something like x58 first, and then came out the mainstream platform after. You paid a higher price of admission, but you got the platform and new architecture earlier.
    If DDR4 comes out double the cost of DDR3, it might take more than a couple extra cores to entice me.
    6gb OCZ platinum
    2*640 WD Blacks
    750GB Seagate.
