Short version:
I've got a Corsair H100. It's dead. I need to get a replacement. From what I've seen on the internet, I'm not the first person to have a H100 fail, so I'd like to try something different. Suggestions?
Long version:
I've got a 3770k running at 4.8 GHz at 1.28v-ish, it makes quite a bit of heat. I bought an H100 and fitted some push / pull fans (4x 120mm Zalman ZM-F3 fans) with shrouds and lapped it, which kept it cool enough whilst still being relatively quiet
Unfortunately, the H100 has died - the lights on the unit don't work, the fan controller is only running one fan and the pump doesn't appear to be working. I'll be swapping back to the stock cooler later today but I somehow doubt I'll be able to keep at 4.8 GHz with the stock cooler!
I need to get a replacement. From Googling my problem it seems i'm not the only one with problems with an H100, so I'd like to avoid it again if possible. But I need something that cools at least as well as it does now (and of course ideally, better).
I've had a look around and so far I've found a refurbished H100 (it's only ?46, so cheap but I'm scared it'll break again), H100i (could try to pick one up on eBay, doesn't appear to cool much better but a different pump gives me more confidence) or the Swiftech H220 (which looks to be the best but is expensive).
Case is a Coolermaster ATCS 840 which is absolutely massive so (hopefully) space isn't such a problem - it can have up two 3 120mm fans in the top or a radiator mounted in place (terrible pictures but you get the idea).
Don't want to spend *too* much but it depends what's out there. Suspect with the cooling requirements it'll have to be watercooling, but I really want to stick with a sealed system for cost and lack of maintenance.
Full pc specs.
Suggestions?
