Results 1 to 5 of 5
Thread: Fx9590 $279.99 Newegg
    Moderator
    Oct 2007
    Oregon - USA
    Looks like you can find the Fx 9590 at a pretty hot little price right now at newegg
    http://www.newegg.com/Product/Produc...82E16819113347
    Asus Rampage IV Extreme
    4930k @4.875
    G.Skill Trident X 2666 Cl10
    Gtx 780 SC
    1600w Lepa Gold
    Samsung 840 Pro 256GB
    Sep 2010
    US, MI
    Your link got cut off somehow...
    Anyways... holy crap that's a nice price (err deal), perfect time to swap one up if anyone is looking .
    May 2012
    Houston, TX
    Down to 279.99$ at Microcenter too! Link
    I imagine AMD is realizing they can't compete at high price points- bumping the FX flagships back down into "value" territory can't hurt! If you don't mind the high TDP, this is a great deal.
    Anarcho-Hippie Hackasaurus Rex!
    Banned
    Oct 2012
    Be advised that there are only a few AM3+ mobos with a properly designed VRM circuit to power the FX-9000 series CPUs so make sure you are using one of these approved mobos or you will have problems and potential failure of the mobo/CPU.
    May 2012
    Houston, TX
    True that. 220W TDP is larger than many entire systems! Before I went with a laptop workstation, I was running an 8120 @ 4.6Ghz and 1.55v (which works out to something like 180-200W max I believe) and it was stable on a Gigabyte 970-UD3 (8+2 phase VRM), but would only hit around 4.2Ghz on an ASUS M5A97 (4+2 phase VRM). Both these boards were otherwise identical in features and priced the same, so watch those specs carefully
