Results 1 to 5 of 5
Thread: For or against: 2.5" drives
    Feb 2007
    South Texas
    So I am about to start piecing together the rest of my General Purpose Server/NAS and I see a significant growth in 2.5" Drives. WD is even marketing some Red 2TB drives now. For a 8drive system would this offer significant heat/power/noise savings over going with 3.5" drives? Granted there looks to be a $75 premium on those 2.5" drives, but in Alaska, I might can make that up in a couple of years in power savings.
    Speed is really not a priority. My 4x750gb WD Sata II greens can run 100mb/s writes in Raid 5 which is more than sufficient. My file output at most would be needing a sustained 30-40mb/s read to support a couple of 1080P quality streams to XBMC powered HTPCs.
    System is:
    Supermicro H8SGL
    AMD Opteron 6128
    8gb Corsair XMS3-1333
    HighPoint RocketRaid 2720
    Raid 5:4x WD 750GB Green
    Windows Server 2012 R2 Standard
    Fractal Define R4
    ASRock X399 Fatal1ty
    1950x Threadripper
    32gb DDR4
    GTX 1070
    __________________________________________________ ____
    Sep 2010
    US, MI
    I'm pretty sure 2.5 inch drives only use the 5v rails.
    You would have to compare the amp ratings of the drives in question.
    In theory with a perfect set of brackets you could fit up to double the drives in the same encloser.
    MAYBE save a few watts, or maybe not .
    I would just go with the 3.5 inch reds myself.
    Just be warned, it seems the quality control is non existent these days except perhaps the retail ver's.
    I just got a 2tb retail red for my brother's future computer, cost quite a bit more, but it checked out 100% ok.
    I found out if you buy oem, and end up having to rma it, you'll get a used refurbished drive :\.
    That scared me into buying the retail, though I'm unsure of the rma practices of them :|.
    (I buy a new drive, I would expect a new drive...)
    Crunching For The Points! NKrader's Avatar
    Dec 2005
    Renton WA, USA
    3.5
    You wouldn't gain much if anything by having 2.5..
    Jul 2008
    In the space between...
    Quote Originally Posted by NEOAethyr View Post
    +1 amen...lol
    'Best Bang For The Buck' Build - CM Storm Sniper - CM V8 GTS HSF
    2500K @ 4.5GHz 24/7 - Asus P8Z68-V Pro Gen3 - GSkill 2x4GB DDR3-2400 C10
    Sapphire Vapor-X 7770 OC Edition - PC Power & Cooling Silencer MkIII 600W
    Boot: 2x 64GB SuperSSpeed S301 SLC Raid 0 Work: Intel 520 120GB
    Storage: Crucial M500 1TB - Ocz Vertex 4 128GB - 4x 50GB Ocz Vertex 2
    HDDs: 2 x 1TB WD RE4 Raid0 - Ext.Backup: 2 x 1.5TB WD Blacks Raid 1
    Nov 2006
    You could use 2.5" drives no problem. I'm using some right now in my server just as random disks. If you really want to be fancy you can get something like this:
    http://www.newegg.com/Product/Produc...82E16817998144
