Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
Thread: XS Test4Theory
  1. #26
    Xtreme Cruncher
    Mar 2009
    kingston.ma
    Quote Originally Posted by Snow Crash View Post
    ... to step around the core limitation of Test4Theory limitation ...
    http://www.xtremesystems.org/forums/...pp_info-method
    I use the linked process on my i7-980X to run 3 instances of T4T, let me know what pieces of it are tripping things up on you and I'll see if I can figure out what I did to make it work
  2. #27
    HWiNFO Author
    Apr 2006
    /dev/null
    Hmmm.. maybe I should switch my 32-thread dual-Xeon machine to run Test4Theory tasks on all cores ?
  3. #28
    Xtreme Cruncher
    Jun 2005
    Northern VA
    Quote Originally Posted by Mumak View Post
    yes, yes i think you should.....
    Its not overkill if it works.
  4. #29
    HWiNFO Author
    Apr 2006
    /dev/null
    but then you'd loose your #1 place
  5. #30
    Xtreme Cruncher
    Jun 2005
    Northern VA
    haha, nice try... but ive got like 50 more cores i could throw at it
    Stats are in.......11,081 for the day
    but it looks like we need to get a bit more poduction, we dropped down to 3rd in the dailies
  6. #31
    Xtreme Cruncher
    Mar 2009
    kingston.ma
    Quote Originally Posted by skycrane View Post
    but it looks like we need to get a bit more production, we dropped down to 3rd in the dailies
    yes boss, added 1 more
    good days back to back, we set anther team record 13,175
    AND ... we broke 1 MILLION total project point!!!
  7. #32
    HWiNFO Author
    Apr 2006
    /dev/null
    Based on RAC, XS is now #3 ! Not bad for a team of 4 active crunchers only Congrats !
    and happy Easter !
  8. #33
    Xtreme Cruncher
    Mar 2009
    kingston.ma
    Has anybody maybe experienced disk corruption?
    Since I stated with T4T, on two of my machines various projects begun to fail. I found that this was due to a disk corruption inside the BOINC data folders.
    I have a feeling that this might be related to VirtualBox...
    Just noticing this the last few days ... while only observational, it appears the more boinc instances I run the more virtual disk corruption takes place ... I was trying to add a new core every few days but I'm going to back down a little ... kills me but I lost about 48 hours between multiple instance over the last 2 days.
  9. #34
    Xtreme Cruncher
    Jun 2005
    Northern VA
    back up to #2 in the dailies, and a pb of 7122 for me today
    congrats to everyone that is putting up the points. im hoping to add a few more this week.
  10. #35
    Xtreme Cruncher
    Jun 2005
    Northern VA
    hehe, well ive added a few more the last 2 days we were over 20k, but dropped down to only 17k today
    i found a down and dirty easy way to add a new comps... it takes about 2 minutes per core, and thats with typing everything in...
    let me know if yall need it. im going to have it run on every core ive got. and see if i can get the #1 spot in the project dalies
  11. #36
    HWiNFO Author
    Apr 2006
    /dev/null
  12. #37
    Xtreme Cruncher
    Jun 2005
    Northern VA
    <cc_config>
    <log_flags>
    </log_flags>
    <options>
    <ncpus>1</ncpus>
    </options>
    <options>
    <data_dir>c:\programdata\boinc1</data_dir>
    </options>
    </cc_config>
    "C:\Program Files\BOINC\boinc.exe" --allow_multiple_clients --dir c:\programdata\boinc1\ --gui_rpc_port 31417
    no, just a concised way to run the switches. just increase the \boinc1 by one for each core, and the port 31417 as well
  13. #38
    Xtreme crazy bastid
    Apr 2007
    On mah murder-sickle!
    You guys looked lonely so I figured I throw you a core.
    [SIGPIC][/SIGPIC]
  14. #39
    Xtreme Cruncher
    Jun 2005
    Northern VA
    Thanks for joining in the fun of smashing atoms
    wooohooo, top 100 for me, and the team is doing nicely climbing up in the ranks.. were at 37 now, so everyone turn it up a bit, throw some more cores on it, bring your friends, and lets have some fun
  15. #40
    Xtreme Cruncher
    Jun 2005
    Northern VA
    <app_config>
    <app>
    <name>vboxwrapper</name>
    <max_concurrent>1</max_concurrent>
    </app>
    <app_version>
    <app_name>vboxwrapper</app_name>
    <plan_class>vbox64</plan_class>
    <avg_ncpus>1.5</avg_ncpus>
    </app_version>
    </app_config>
    ive also found this app_config that some ppl are making use of using 2 cores for the VM... not sure how it works. but im going to try it
  16. #41
    HWiNFO Author
    Apr 2006
    /dev/null
    I'll try that too. Wondering if the credit granted is then doubled too...
  17. #42
    Xtreme Cruncher
    Mar 2009
    kingston.ma
    I'm back for a while ... at least until I hit 250 K ... I've been bouncing around a bit lately but have got back on the CERN bandwagon ... Test4Theory, LHC classic sixtrack, and now the new ATLAS project
  18. #43
    HWiNFO Author
    Apr 2006
    /dev/null
    AFAIK, Atlas is in beta stage yet and Atlas tasks will be run at vLHC@Home (ex-Test4Theory) soon.
  19. #44
    Xtreme Cruncher
    Jun 2005
    Northern VA
    In case yall havent realized it yet, they FINALLY have vLHC running 2 cores max now. i still havent figured out why they wont let more than that run on a comp.... let us worry about how much hardware we need to run it. your job is to write the program to run on every core...
    end rant...
    also, vLHC, and atlas will NOT run on the same comp. they fight each other for access to VBox
  20. #45
    Xtreme Cruncher
    Mar 2009
    kingston.ma
    ... also, vLHC, and atlas will NOT run on the same comp. they fight each other for access to VBox
    I *think* some of the contention comes when multiple apps are trying to write snapshots at the same time, it simply takes too long for the HDD to write and you end up with the VM for one of the apps thinking the source system can not service it (which it can't) and then it magically shuts itself down for 24 hours (ugh).
    On a 4670K w / core 4.1, nb 3.9, RAM 2133, OS Win7 on SSD ... I had no issues with running 1x vLHC and 1x ATLAS.
    When WCG challenge is over I'll be back and see how far we can push the concurrency.
