Results 1 to 5 of 5
Thread: Maximus VI Impact overclock help
    Moderator
    Oct 2007
    Oregon - USA
    Ive been working with this little impact for a little while now, and I am completely stumped at the moment. When I was running my trident-X 2666 I was able to get the system to at least benchmark at 4.8ghz with an h110 closed loop on the bench. Now my 4770k is nude, with an EK supremacy with naked IVY kit, and avexir 2800, and I cannot seem to get the system to even bench at 4.6. Imagine my frustration.
    At this point im going to ask for help. I put the board away for a few months so perhaps I forgot a common setting that I was aware of before.
    What basic settings should I be using for overclocks 4.5+?
    Asus Rampage IV Extreme
    4930k @4.875
    G.Skill Trident X 2666 Cl10
    Gtx 780 SC
    1600w Lepa Gold
    Samsung 840 Pro 256GB
    Xtreme Memory Hoarder
    Mar 2010
    Quote Originally Posted by Ace123 View Post
    Have you tried the Trident X kit with the de-lided cpu to see if you can achieve the same clocks?
    Quote Originally Posted by Hondacity View Post
    gskillllin it!
    Moderator
    Oct 2007
    Oregon - USA
    I will, I loaned them out to a friend of mine to see if he could get his 3770k 5.2ghz Pi and Wprime scores up a little. I will get them back tomorrow. Maybe I will leave him with these 2800s and see if his Ivy has a good IMC.
    On a stable note, I got the system 100% stable with the 4770k @ 4.5ghz 1.3V DDR3 2800 1T command rate, with my little gtx 670 @ 1202/3598. Should be good for gaming. I would sure like to benchmark with this though :/
    4930k @4.875
    Gtx 780 SC
    1600w Lepa Gold
    Mar 2010
    Did everything get sorted Ace?
    gskillllin it!
    Moderator
    Oct 2007
    Oregon - USA
    Unfortunately I have not. I have given up on this CPU. I got it at launch so I assume 4.5ghz stable will be ok for a launch CPU on water considering I have seen MUCH worse. This will not be my benchmarking haswell. But then again I havnt had a chance to go grab my other memory either, but I did attempt to clock the avexir at 2666 and then 2400. I can force it into windows and make a few pi runs at 4.6 and 4.7 if I kill it with voltage. Not ideal haha. I messaged you about that other 4770k you have.
    4930k @4.875
    Gtx 780 SC
    1600w Lepa Gold
