For gaming.
Cant stop wont stop :P
Case
- MAGNUM STH10
- Case Color: Black Matte
- Form Factor: XL-ATX
- ATX Layout: Reverse
- MB Door: XXL Window
- Window Color: Clear
- Top Cover: Ventilated
- Upper Chamber Covers: Ventilated
- Lower Chamber Covers: Ventilated
- PCI Backplate: Hex Mesh
- Flex-Bay covers: Ventilated
Case accessories
- 140.4 Radiator Side Mount (2)
- 120.4 Radiator Side Mount (2)
- Fan Mount (120mm x 25mm) - Flex-Bay (1)
- Caster Kit - HD(1)
- 120.4 Flex-Bay Radiator Mount (1)
- PSU Support Mount - Magnum (1)
- PSU Cover - Ventilated (2)
- USB 3.0 I/O 3.5'' bay - Silverstone Black(1)
- Thumb Screws(2)
- Shock Mount Kit(1)
Fan
- T.B.VEGAS DUO-12cm(22)
- T.B.VEGAS DUO-14cm (8)
WaterCooling parts
- Bitspower D5 / MCP655 Mod Kit - Matte Black Finish *(4)
- Bitspower Dual / Single D5 Top Upgrade Kit 250 (Clear Acrylic Cap) *(2)
- Bitspower G 1/4" Matte Black Rotary 90 Degree IG 1/4" Adapter *(6)
- Bitspower Dual IG1/4" Matte Black Rotary Mini Snake-Style Adapter *(7)
- Bitspower G 1/4" Matte Black Dual Rotary 90 Degree IG 1/4" Adapter *(6)
- Bitspower BP-MBWP-C47 G1/4" Matte Black Multi-Link Adapter- Set of 2 *(20)
- Bitspower BP-2D5TOPAC-UVRD*Dual D5 Mod*Top (Acrylic Version) - UV Red *(2)
- Bitspower BP-MBWP-C48 G1/4" Matte Black Multi-Link Adapter - Mini- Set of 2 *(13)
- Bitspower BP-MBWP-C60 G1/4" Matte Black IG1/4" Extender - 15mm *(11)
- Bitspower IG1/4" Extender - Black Matte Finish *(6)
- Bitspower BP-MBWP-C71 Matt Black Multi-Link Adapter *(19)
- Bitspower Case Top Water Fill/ Through Hole Fitting Set - Matte Black Finish *(12)
- Bitspower Crystal L-Block - 90 Degree Water Cooling Accessory *(11)
- Bitspower Crystal T-Block - 180 Degree Water Cooling Accessory *(4)
- Bitspower BP-CLTAC-S2 Crystal Link Tube Set For 2-Slots *(3)
- Bitspower BP-CLTAC-S3 Crystal Link Tube Set For 3-Slots *(1)
- Bitspower BP-CLTAC-S4 Crystal Link Tube Set For 4-Slots *(5)
- Bitspower BP-CLTAC-S5 Crystal Link Tube Set For 5-Slots *(7)
- Bitspower Dual IG1/4" Matte Black Triple Rotary Snake-Style Adapter *(2)
- Bitspower BP-MBWP-C46 G1/4" Matt Black Anti-Cyclone Adapter *(2)
- Bitspower BP-MBWP-C61 G1/4" Matt Black IG1/4" Extender-20MM *(4)
- Bitspower BP-MBWP-C62 G1/4" Matt Black IG1/4" Extender-25MM *(4)
- Bitspower BP-MBWP-C06 G1/4" Matt Black Stop Fitting *(20)
- Bitspower BP-MBWP-C18 G1/4" Matt Black Aqua-Pipe II *(2)
- Bitspower BP-MBWP-C17 G1/4" Matt Black Aqua-Pipe I *(2)
- Bitspower BP-MVV-MBKBK Matt Black Mini Valve With Black Handle *(4)
- Bitspower BP-MBRG G1/4" Matt Black Rotary G1/4" Extender *(4)
And alot! Bitspower Always :thumb2:
Motherboard
- RAMPAGE IV EXTREME(Reuse)
Cpu
- Intel I7 3930K (Reuse)
Memory
- Gskill RipjawsZ 2133 4*4Gb(2) (Reuse)
SSDReuse
- Adata SX900 256GB(2) (Reuse)
GPU
- GeForce? GTX 770 JETSTREAM (4096MB GDDR5) (3)
(Radiator, GPU Block & aquaero)
- Airplex modularity system 480 mm, copper fins, one circuit,stainlesssteel side panels x 4
- Set of side panels for airplex modularity system, 480 mm, black anodized aluminum X 4
- Set of interconnection plates (horizontally stacked) forairplexmodularity system x 1
- Side or horizontal connector for airplex modularity system x 4
- kryographics for GTX 680 acrylic glass edition x 3
- Backplate for aquagrafx GTX 680 x 3
- Temperature sensor internal/external thread G1/4 for aquaero, aquastream XT and aquaduct x 4
- Filter with stainless steel mesh, ball valves and mounting plate, G1/4 x 2
- aquaero 6 XT USB fan controller, graphic LCD, touch control, IR remote control x 2
- Frontplate for aquaero 5 und 6 XT (only art. 53125 and 53146!) aluminum black x 2
- Real Time Clock expansion module for aquaero 5 und 6 x 2
- Flow sensor "high flow" G1/4 for aquaero, aquastream XT ultra and poweradjust x 2
(CPU, MOBO & RAM) WaterBlock
- EK-FB KIT RE4 CSQ
- EK-RAM Monarch X4 CSQ
- EK-Supremacy
LOG
- Order 1 from PPC arrived*(Page 2)
- Order 2 from PPC arrived*(Page 3)
- unpacking both package* (Page 4)
- My Caselabs is here!!* (Page 8)
- My experiences during my setup of my case* (Page 8)
- Caselabs will be sending me the replacement! :thumb2:*(Page 9)
- Some modification done by MOPC :thumb2:*(Page 9)
- More bp loots during my weekend trip at taiwan! *(Page 10)
- Replacement part from Caselabs *(Page 10)
- STH 10 with 120.4 Flex-Bay Radiator Mount *(Page 10)
- 140.4 Radiator Side Mount at STH10 TOP!*(Page 11)
- Added new GPU*(Page 11)
- Added new waterblocks.*(Page 11)
- Aqua-computer Final order.*(Page 12)
- T.B.VEGAS DUO-14cm installed on top and btm chamber.*(Page 14)
- Some update on my aquacomputer list and replated my initial waterblock.*(Page 15)
- The arrival of the first parcel.*(Page 16)
- More Bitspower.*(Page 17)
- Received my 2nd parcel.*(Page 18)
:angel:
:sleep:
