Fan controller to control pump speed
So I have a theory on how to control pump speed on my next build, let me know if this will cause any issues.
Get this pump:
http://www.performance-pcs.com/catal...ducts_id=21689
use this molex to 3pin adaptor:
http://www.performance-pcs.com/catal...roducts_id=608
to plug it into this fan controller (30W per channel):
http://www.frozencpu.com/products/11...?tl=g47c17s239
and for bonus points, I can add the rpm monitoring pin to the adaptor...
will this work? will it cause any issues? is 30W enough? any issues from tiny 3 pin connector instead of full size molex?
I'm planning on filling the other 3 channels with 8 more fans (3 Noctua NF-A14 FLX, 3 NB eloop, 2 Noctua NF-F12 respectively) but all running really slow
I think this will work
You can get pump controllers specifically for this if you wanted, here is an example ----> http://www.pccasegear.com/index.php?...293&cPath=1285
other than that your idea should work just fine
EDIT: just noticed it was the 450 it needs 35w to start up
Be carefull, some pumps have a hard time starting up with standard fan controler.
I don't know how this one will react.
I had the same idea as you but it didn't work well with ddc.
You may have not the possibility to lower the volts much
PWM pump are better in this aspect.
Or use a pump integrating directly this feature.
Or use a fan controller wich can deliver more current for starting up the pump
In the description : Startup Voltage: 9 to 13.2 VDC
You won't be able to do 24V with your fan controller, only 12V
the http://www.lamptron.com/2013/02/05/i...amptron-cw611/ would likely be the better (but more expensive) choice as it is designed to do just that.
- You may not post replies
- You may not edit your posts
Forum Rules
