Results 1 to 10 of 10
Thread: Recommendations for Water-Cooled Server Case
    Jun 2007
    Cool Recommendations for Water-Cooled Server Case
    Ok guys,
    I have a home server that is getting unbearably loud, and I'd like to move it into a new case, and water-cool it aswell.
    It has 10 HDDs, and I'd like to water-cool them all, along with the CPU, RAM and Northbridge (and possibly the VREG?). I know water-cooling hard drives is unpopular with some, but please, don't recommend that I don't do it.
    The motherboard and CPU are fairly old, but sufficient for my current needs. The are the ASUS M3N78 Pro (ATX), and AMD Phenom II X4 9950. 4GB RAM (two sticks).
    The overall goal here is to make the system quiet, but I suppose overclocking isn't out of the question, in the future.
    Looking for recommendations for chassis mainly, but also water blocks and radiators.
    Thanks in advance!
    Nov 2009
    No point in watercooling such old hardware, you are better off buying a new case and some decent fans. For example Fractal design define XL.
    Engineering The Xtreme
    Feb 2007
    MA, USA
    Lol, the reason watercooling hard drives is "unpopular with some" is that it's bad for the hard drives. They are meant to run at a certain temperature (not 30c! higher) for the lubricants and proper operation of the parts inside (thermal expansion) If you want to kill your hard drives go ahead and watercool them.
    As far as what this dude m_jones_ is saying, dont listen to him. Watercooling is your best option for a quiet system.
    I don't have a case recommendation, but I can say you should get a 3x120 radiator, some low speed fans, and go ahead and cool the CPU and NB. As far as the air portion of your cooling, just buy high quality fans like gentle typhoons and run them at low speed, you will see a huge decrease in noise.
    Nov 2009
    Air can be perfectly quiet too but dumping $300+ just to cool that old hardware seems like a bit of a waste of money overall when he could move to a much more efficient platform with a lower heat output and stick a rather large cooler with slow fans on it.
    Jun 2007
    It may seem odd watercooling such old hardware, but remember I'm going for quiet, not overclock.
    Also, I may upgrade the hardware in the future, and this watercooling setup can be re-used on the new system (I know I'll need new blocks for CPU and NB).
    Mainly I'm looking for a case recommendation. It should have 9 x 5.25 bays, and room to mount a 3x120 radiator. (ATX motherboard).
    Also, can you recommend a good 3x120 radiator?
    Thanks.
    Feb 2007
    MA, USA
    I like the EK radiators, perfect for quiet fans. The fans you should get are:
    http://www.performance-pcs.com/catal...ducts_id=24747
    or cheaper version: http://www.swiftech.com/Helix120mm-PWM.aspx
    I'm so out of the loop on cases I don;t have a recommendation there.
    Feb 2005
    OZtralia
    Quote Originally Posted by lloydsmart View Post
    Thanks.
    Good luck finding a case with 9 x 5.25" bays..............why would you want so many ???, HDD bays ???, take a look @ the Silverstone Temjin TJ11, but it aint cheeep
    Whilst WC is great keeping an OC'd rig cool, these days the top end air coolers are great if all you need cool is your CPU, re cooling HDD's your better off with active fan cooling using good quality quiet fans that I can guarantee will be inaudible 3 feet away
    lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
    Jun 2007
    Settled on the Antec Twelve Hundred V3 for a case.
    Now I need recommendations for a radiator. I want it to be internally mounted, 3x120mm. Any thoughts?
    Also, I've seen this 200mm radiator designed specifically to fit in the top of the Antec 1200 case, but unfortunately it's aluminium, and the rest of my water loop is going to be copper. Does anyone know of a similar product made of copper?
    Thanks.
    May 2007
    Hampshire, UK
    What about the thermochil pa120 rad its all brass.
    Home / Play Rig Asrock Z87 OC Formula/AC, i7 4770K L310B487, 8GB Corsair Dominator Platinum 2666 CL10, BeQuiet Dark Power Pro P8 1200W PSU, 120GB Corsair Force GT SSD, 2 x 1TB WD Sata Drives Mirrored, Palit 680GTX JetStream, Antec Kuhler 920, Windows 10 Pro, Logitech LX700 Deskset, AOC 27" Monitor.
    Work 24/7 Rig Gigabyte GA-Z97X-SOC Force, i7 4790K L418C133 ,8GB Team Xtreem LV 2600, PC Power & Cooling 850WPSU, 120GB OCZ Vertex 3 SSD, 2 x 500GB Hitachi Sata Drives Mirrored, Antec Kuhler 620, Windows 10 Pro 64 Bit, Logitech LX700 Deskset, Benq 27" Monitor.
    Home NAS DFI P35 T2RL Motherboard, Intel E6850 CPU, 8GB Nanya DDR2 6400, 2X 2TB Toshiba DT01ACA200 SATA Drives, ZFS RAID Mirror On Intel ICH9 AHCI, Artic Blue 850W PSU, Marvell Yukon 88E8053 Gigabit Ethernet, FreeNAS 9.2.1.5 RC, 64-Bit On 4GB USB2 SanDisk Cruizer Blade Thumb Drive.
    Jun 2007
    Well, my Antec 1200 has arrived!
    I'll get a 3x120 but it seems like a waste not to put a rad in the 200mm slot at the top of the case. Shame Antec's one is aluminium. Does anyone know whether the Phobya Xtreme 200mm radiator will fit this case?
