Results 1 to 11 of 11
Thread: [REVIEW] ASUS Rampage IV Extreme ? Overclocking with Ivy Bridge-E (i7 4930K)
    Dec 2008
    MALAYSIA
    Arrow [REVIEW] ASUS Rampage IV Extreme ? Overclocking with Ivy Bridge-E (i7 4930K)
    Introduction:
    2013 is very important for PC market. There are more and more tech products coming this year. One of the most anticipated bits of silicon this year is the Intel?s Ivy Bridge Extreme processors. In this review I will be taking a look at the ASUS Rampage IV Extreme (RIVE), to pair with the IB-E based processor, i7 4930K. The RIVE has been added some nice touches and BIOS refinements to support the latest Intel?s processors. This board packs a lot of features that are aimed directly at the hardcore gamers and overclocking enthusiasts.
    Specifications:
    Full specifications of RIVE can be obtained HERE
    Overview of RIVE:
    The Motherboard:
    Now, meet the motherboard that is really EXTREME?
    The RIVE comes with a black and red theme. The LGA2011 CPU socket supports Intel Sandy Bridge Extreme (SB-E) and Ivy Bridge Extreme (IB-E) processors. The PCB form factor size is Extended-ATX (EATX) with a dimension of (30.5 x 27.2) cm.
    As you can see here, the RIVE is powered by intelligent Extreme Engine Digi+ II 8+3+2+2 Phase Power Design with premium components to handle extreme overclocking. There are eight memory slots that support up to 64GB of DDR3 memory. The quad-channel DDR3 architecture doubles the bandwidth of system memory to boost the overall system performance. Also spotted, onboard Power and Reset buttons, Slow Mode switch, LN2 mode jumper, ASUS ProbeIt measuring points, VGA Hotwire connectors, GO button, PCIe Lane switch and debug LED.
    There are whopping five PCIe 3.0 16x slots supporting up to 4-way SLI/CF @ x16/x8/x8/x8, as well as:
    3-way @ x16/x8/x16
    2-way @ x16/x16
    1-way @ x16
    The RIVE also has a single PCIe 2.0 x1 slot.
    SATA ports are consisted of:
    Intel X79 chipset controller: 2 x SATA3 + 4 x SATA2
    ASMedia PCIe SATA controller: 2 x SATA3
    The rear I/O panel includes:
    1 x PS/2 keyboard/mouse combo port
    1 x Bluetooth module
    2 x eSATA3
    1 x LAN (RJ45) port
    4 x USB 3.0
    8 x USB 2.0 (one port can be switched to ROG Connect)
    1 x Optical S/PDIF out
    5 x Audio jacks
    1 x Clear CMOS button
    1 x ROG Connect On/ Off switch
    Back side of the motherboard is very simple. Backplate is used to provide retention to the VRM coolers on the top of the board. The CPU socket area is supported by LOTES bracket and backplate.
    Test Setup:
    CPU: Intel Core i7 4930K
    MB: ASUS Rampage IV Extreme
    DRAM: G.Skill TridentX 2800 C11 2 X 4GB, Corsair Dominator Platinum 2800MHz C11 2 X 4GB, G.Skill TridentX 2666MHz C10 2 X 4GB, G.Skill TridentX 2600MHz C10 2 X 4GB, Corsair DominatorGT GTX4 2533MHz C9 2 X 2GB and G.Skill RipjawsX 2133MHz C8 4 X 2GB
    GPU: Gigabyte HD7970, MSI's special BIOS, Driver Catalyst 13.8 beta
    Storage: Crucial M4 128GB
    ODD: LiteON DVD-RW
    PSU: Corsair AX1200
    Cooling: Custom watercooling - EK Supreme HF plate #6 CPU waterblock, 2x XSPC RX360 radiator, Swiftech MCP655 pump, EK FC7970 GPU waterblock, EK Multioption X2 Advanced reservoir, XSPC 1/2" ID 3/4" OD white tubing, 12x Scythe GT AP-15 1850rpm 120mm fan + Aerocool Shark 120mm fan, Coolaboratory Liquid Pro thermalpaste etc.
    Casing: DimasTech Easy Dual V2.5 Test Bench
    OS: Windows 7 Ultimate 64-bit SP1
    SUCCESSFUL TRADE LIST RM600k+
    ^^ Malaysia's Overclocking Enthusiast Community Website ^^
    Find us at Facebook HERE
    XS Successful Trades:
    G.Skill RipjawsZ 2400C9 4X4GB - sold to easegantini | G.Skill RipjawsX 2133C8 2X2GB - bought from Dumo | 2600K 57X - bought from newhit | 3770K 6750 - bought from Viss | 3770K 6750 - sold to Sniper | 3770K IMC 2800+ - bought from Dumo | G.Skill Pi 2200C7 - bought from websmile | 3770K IMC 2933+ - bought from Viss | DomGT 2kC7 3X2GB - sold to _AntLionBR_ | G.Skill Pi 2133C8 - bought from websmile | DomP 2800C11 - bought from Alex-Ro | Pi 2000C7 - bought from websmile | GTX4 + KVR 1333C9 - bought from TaPaKaH
    Dec 2008
    MALAYSIA
    The UEFI BIOS:
    Main page with LN2 Mode jumper ON:
    RAM frequencies to choose:
    RAM timing settings: Mode 3 for Ivy Bridge-E
    Memory presets: Lots of memory IC supported
    DIGI + Power control:
    PCH Chipset Tweaker’s Paradise:
    VGA Tweaker’s Paradise:
    Memory Tweaker’s Paradise:
    EZ-Mode: A more simplified UEFI interface
    Software & Tools:
    1) AI Suite II - OC tweaking utility, is a tool for overclocking in the OS.
    2) TurboV Core - a simplified version of TurboV application.
    3) MemTweakIT - view and adjust the memory timings real-time in the OS.
    Dec 2008
    MALAYSIA
    Stability Tests:
    LinX 0.6.5:
    The 4930K is overclocked to 4.593GHz @ 1.408v and passed the stress test without an error in 5 hours 45 minutes. One of the cores hit 92C during loading but it's still lower than TJmax of 95C.
    Benchmark Tests:
    The 4930K is overclocked to 4.675GHz (6 cores/12 threads) for 3D benchmarks and 5.0GHz (2 cores/2 threads) for 2D tests. At the same time, the HD7970 is overclocked to 1300MHz core/7000MHz mem @ 1.3v/1.7v.
    3DMark13:
    3DMark11:
    3DMark Vantage:
    3DMark06:
    3DMark05:
    3DMark03:
    PCMark7:
    Super Pi 32M/ wPrime/ MaxxMEM/ AIDA64 Cache and Memory Benchmark:
    Super Pi 1M:
    Dec 2008
    MALAYSIA
    HyperPi 32M/ 1M:
    Cinebench 11.5:
    Unigine Heaven 4.0:
    Fritz Chess/ wPrime 1.55:
    X264 FHD Benchmark:
    Super Pi 32M Benchmark with Hynix-CFR IC RAM:
    G.Skill TridentX 2800C11 2 X 4GB + Corsair Dominator Platinum 2800C11 2 X 4GB @ 2965MHz 12-15-15-35-2T (Quad Channel)
    G.Skill TridentX 2800C11 2 X 4GB @ 3000MHz 12-14-14-35-2T (Dual Channel)
    Super Pi 32M Benchmark with Samsung IC RAM:
    G.Skill TridentX 2666C10 2 X 4GB + 2600C10 2 X 4GB @ 2700MHz 9-12-12-25-1T (Quad Channel)
    Super Pi 32M Benchmark with PSC IC RAM:
    Corsair DominatorGT GTX4 2533C9 2 X 2GB @ 2666MHz 8-12-8-28-1T (Dual Channel)
    Super Pi 32M Benchmark with BBSE IC RAM:
    G.Skill RipjawsX 2133C8 4 X 2GB @ 2133MHz 8-9-8-24-2T (Quad Channel)
    Dec 2008
    MALAYSIA
    Game Benchmarks:
    Metro Last Light:
    Bioshock Infinite:
    Thoughts & Verdicts:
    I've always been impressed with the ASUS "Republic of Gamers" (ROG) motherboards. With the RIVE, you get all the X79/Socket LGA2011 features, such as quad-channel memory, SATA3, and SLI and CrossFire (CF) support. ASUS gives the extreme overclockers the VGA Hotwire, GPU/DIMM POST, thermal sensors, LN2 mode, Mem TweakIt, Sub Zero Sense, OC Key, OSD TweakIt, 4-Way SLI/CF support, X-Socket, ROG Connect, ROG iDirect, and the Extreme Engine Digi+ II 8+3+2+2 phase power design using 10K black metallic caps.
    Overall, this is the board to beat for serious overclockers who are going for the enthusiast class. Overclocking on the Ivy Bridge-E (i7 4930K) was very great. The UEFI BIOS works intelligently to provide a pleasant overclocking session.
    Lastly, I would like to thank ASUS Malaysia especially Sanko for making this review possible.
    Performance: 5/5
    Materials: 5/5
    Specifications: 5/5
    Appearance: 5/5
    Performance/Price Value: 5/5
    Pros:
    + Excellent overclocking performance
    + Appealing red and black theme
    + Good motherboard layout with bunch of PCIe X16 slots
    + Intelligent UEFI BIOS and applications
    Cons:
    - Pricey (RM1499)
    - No Wifi module
    - No dual LAN ports
    I am Xtreme
    Sep 2006
    Nice work man !
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Jun 2009
    Ukraine, Dnepropetrovsk
    Nice review!
    Forgive for my English because I only learn it
    XIP
    Nov 2004
    NYC
    Nice work owik
    May 2008
    Decatur, GA
    Good stuff! How much VCCSA/VTT for those high mem clocks?
    i7 4930K
    32GB Corsair Vengeance Pro DDR3-2400C10
    Asus Rampage IV Black Edition
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
    Dec 2008
    MALAYSIA
    Quote Originally Posted by Leeghoofd View Post
    Nice work man !
    Quote Originally Posted by MaJ0r View Post
    Nice review!
    Quote Originally Posted by Dumo View Post
    Nice work owik
    Thank you so much for the compliments guys.
    I will try my best to improve my reviews in near future. TQ!
    Dec 2008
    MALAYSIA
    Quote Originally Posted by Shiranui Gen-An View Post
    Afaik for VCCSA/VTT I gave them 1.25-1.4v and that would be vary from RAM to RAM.
