Results 1 to 9 of 9
Thread: What do you recommend for extending your wi fi signal.
    Mar 2007
    I need to extend my signal on my router. It is not going as far as I need. The place where I need it has an Ethernet port in the room but I would need to be able to wire from the piece of equipment that I decide to use there. It would probably best be a router unless an access point can have ports to hook up to additional equipment in the room that I already use. I know it is best to stay with the same brand and my router is NETGEAR DGN3500. Can anyone tell me what they would use? Thanks.
    2-VIOTEK FI24D V2 24-Inch QHD Gaming Monitor with IPS Technology, ASUS ROG STRIX B550-A GAMING AM4 AMD B550, CORSAIR Vengeance RGB Pro 16GB (2 x 8GB) DRAM DDR4 3200, MSI GeForce GTX 1660 Ti 6GB GDDR6
    AMD RYZEN 5 3600 6-Core 3.6 GHz, Asus BW-12B1ST Internal Blu-ray Writer SAMSUNG 830 Series 2.5" 256GB SATA III , HITACHI Deskstar 2TB, 2 - Western Digital Black -2 TB HDD
    Super Flower Leadex III 650W 80+ Gold, AMD AM4 Wraith Prism LED RGB Cooler Fan, Windows 10 Professional Retail, Fractal Design R4 case
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    the best option would be to get a good new router with proper range most of the time. the next best option is to get a router and put it on an ethernet port and then disable DHCP on it when you get it set up so you can get them on the same network.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Mar 2007
    This is a new router. It cost $170. I really don't think that getting a new router would solve the problem because the location where I need the router is not necessarily a good one but a must. There are certain rooms that have different things in them that kill the signal too. I have so many wires running through my house and home automation etc. that it really messes things up. I have actually been thinking about a switch in the room and then an access point. A little more expensive setup, but a much easier configuration unless you know of a router that has a push of the button and it becomes an extender. I have heard they are out there but just have not had the time to look.
    Jan 2007
    Santa Barbara, CA
    Just a simple range-expander like an Airport Express should do the trick. Stupid simple to setup too.
    Computer: Intel i7-4770k | Asus Z87 Maximus VI Impact | 240GB Corsair Force GT | 240GB OCZ Vertex 3 | 16GB G.Skill Trident X 2400MHz | EVGA GTX690 Hydro Copper 4GB | Corsair AX850 | Steelseries 7G | Logitech G500 | 27" 2560x1440 Overlord Tempest X270OC 120Hz S-IPS
    Cooling: Koolance 380i CPU block | Swiftech Hydro Copper GPU block | EK X3 150 Reservoir | EK X-TOP D5 PWM drive | PrimoChill PrimoFlex PRO LRT Bloodshed red | Alphacool NexXxos 240mm XT45 | Alphacool NexXxos 280mm UT60 | Bitspower Fittings | 4x Bitfenix Spectre Pro 120mm | 2x Bitfenix Spectre Pro 140mm | Lamptron FC-5V2
    Case: Custom modded matte black Caselabs Mercury S3
    Mar 2007
    Will that work with a PC?
    Mar 2007
    Would something like this work? I would not even need a switch.
    http://www.newegg.com/Product/Produc...82E16833127256
    Jan 2007
    Santa Barbara, CA
    Quote Originally Posted by ingeborgdot View Post
    Yes, I have two of them. One has speakers plugged into it so I can stream music wirelessly using Airfoil.
    Xtreme Cruncher
    Sep 2008
    Kansas City, Missouri
    If it is extending 802.11 it will work with any modern PC.
    ~ Little Slice of Heaven ~
    Lian Li PC-A05NB w/ Gentle Typhoons
    Core i7 860 @ 3gHz w/ Thor's Hammer
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    OZC Vertex3 SSD 240GB
    Xtreme Cruncher
    Oct 2006
    1000 Elysian Park Ave
    Everything worked great in this house, until they decided to have an Ipad fixed by a non-apple authorized repair place, now it doesn't work downstairs and we might need to buy an extender. Like you it's a $100 N class router so i blame Apple You could try a different antenna, not sure if it makes any difference, but Newegg gave me one a while back when i bought something
    i3-8100 | GTX 970
    Ryzen 5 1600 | RX 580
    Assume nothing; Question everything
