Results 1 to 7 of 7
Thread: Need Hard Drive backup solution
    Aug 2013
    HI Everyone
    I need hard drive to to my office, I have 4 pc's in a work group and i was thinking to get network base hard drive to connect it to my router and on each pc setup the backup with the hard drive destination.
    Is that how its done? there is any better solution? any recommended Hard Drive?
    Thanks for your help
    Oct 2006
    England, UK
    Set up a small NAS and either use it as a backup or host the files directly on it.
    Aug 2013
    Network Base Hard Drive is not a NAS?
    That my idea to conect the hard drive to the network and all pcs will back up to there. But is it the best solution?
    Nov 2003
    NYC
    depends on what you are using for backup, some software is absolutely happy with backup to network locations, others can get fussy and would prefer something that can do iSCSI instead of SMB or something like that.
    chances are you'd be better off buying 4x internal drives and adding them to the desktops and backing up to them via built in windows backup, monitoring it would be the bigger problem at that point.
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    Crashplan.
    STARSCREAM
    3570k @ 4.6 GHz | Asus P8Z77-V LK | G.Skill F3-12800CL8D-8GBXM | ASUS GeForce GTX550 Ti
    Corsair Neutron GTX 240GB | Corsair Force GT 120GB | SK hynix 128GB | Samsung 830 64GB
    WD Black 640GB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i
    Corsair AX750 | CoolerMaster Hyper 212 | Antec P280 | Dell Ultrasharp U2410 | BenQ XL2420T
    ROCCAT Savu | Filco Majestouch-2 TKL w/Cherry MX Reds
    MEGATRON
    3770k @ 4.5GHz | Asus Sabertooth Z77 | G.Skill F3-12800CL8D-8GBXM
    SK hynix 128GB | Mushkin Enhanced Chronos 60GB | WD Red 3TB (4) | Seagate 7200rpm 3TB (2)
    WD Green 2TB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i (2)
    Corsair AX650 | Corsair H80i
    RAIDer
    Jul 2005
    Norway
    Small nas? This is Xtreme storage
    Feb 2008
    I second the recommendation for Crashplan. I have been using it for the past year. When you look at what you may spend for additional HDs or NAS this is a very worthwhile consideration. I have all of my data/photos/videos etc. backed up. It feels good to know that my data is reliably backed up.
