    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 1 of 1
Thread: HKEPC Pi Analyzer 0.9.6.222
    Champion
    May 2013
    Hong Kong
    Pi Analyzer is a Freeware Utility for overclockers to manage their Super Pi score(s) with Screen Capture function. Support Save and Load Result and provide the interval time between each Loop .
    Super PI is used by many overclockers to test the performance and stability of their PC. In the overclocking community, Super PI is a standard benchmark for enthusiasts to compare " world record " pi calculation times and demonstrate their overclocking abilities.
    Version History:
    0.9.6.222
    - Bug fix : Empty table after view comment
    - Add : PNG Format Screenshot Function (F7 Hotkey support)
    0.9.5.222
    - Minor window width fix
    - Check file header before loading it
    - Add comment function. " View->Show Comment " to
    enable it
    0.9.4.222
    - Load Function completed
    - Change main window height when changing superpi
    profile
    - Change row height to align with superpi loop results
    - Set default filename to Pi result
    0.9.3.222
    - Add " Enter " Behaviour in the first Combo Box. Jump to
    table when press ENTER.
    - Finished save function.
    - Load function not yet finished. Use notepad instead
    first.
    0.9.2.222
    - First HKEPC Pi Analyzer build
    Download Link :
    http://www.hkepc.com/forum/attachmen...BqdStVRUsycWdv
