EDIT: I decided to make autocascade instead SS. See next posts for details.
New build, this time I'm building really strong SS for myself. I'm aiming in -60/70C area, so it should be nice alternative for DI.
Used parts:
Evaporator: 42mm stepper rev.2 http://www.xtremesystems.org/forums/...Stepper-rev.-2
Compressor: Daikin YZG-56RBY1 19300 btu
Condenser: Roen Est 1900W with 25W Ebm Papst Fan
Expansion valve: 0.9mm captube
Refrigerant: R507
Baseplate: 1.5mm stainless 500x400mm, on wheels
So far, all things are mounted to the plate, most piping is also ready, I've encountered small troubles, because flex hose turned out to be damaged and I have to order a new one and replace. I'm also planning to make GPU mount, together with my water chiller it should be nice combo to cool whole platform. I'll keep you updated
