[Project] Frupo's Fanless Test Lab @ Garage Mode 2012
About this thread & project: Language disclaimer
This project was firstly written and presented, in my native Italian language, on an Italian website and forum, particularly related to silent hardware, where I presented some of my works (PC moddings, PC buildings and so on).
Now I wanted to share this project and my work with you. Unfortunately I have not so much time and so much language ability to directly and quickly translate in English language, and did not want to use 'automatic' translation (but you could use this kind of 'automatic' translation, for example the one offered by Google which translates web pages... of course, if you want).
In agreement with Moderation Staff, I decided to simply copy and paste here my work, even if in original language, guessing that my work will be somehow useful for you, being sure that you will like pictures, that many times will be self-explanatory, and finally hoping you will appreciate the whole project.
Please feel free to comment this thread; if you have any questions related to the project, I ensure to you that I will do all my best to answer to your questions (obviously.... in my poor English!).
Enjoy.
INDEX
Presented for the first time in December, 2012. > Here <
Qualche breve parola introduttiva....
Obiettivi
Un banchetto da "laboratorio" veramente senza pretese, ma con l'obbligo e l'onore del fanless.
Un free style, posizionato rigorosamente in garage, su una minuscola scrivania.
Componenti quasi tutti presi usati sul mercatino, con il solito compromesso del prezzo e dell'occasione del momento. Il budget in realta' era molto basso, anzi per dire la verita' non c'era budget ma molti pezzi riutilizzati.
Sara' l'occasione per installare e testare sul campo Windows8? Maybe.
SECRET PICTURES
Mounting
Tutto e' pronto per il montaggio. Tutto a posto? Verifichiamo tutto con scrupolo, certo, per evitare sorprese dell'ultimo minuto.
I ragazzi sono a posto, fuori sulla porta, e si godono il sole del mattino...
... e noi ci possiamo godere il nostro mounting; essendo un banchetto, e composto tutto da hardware piuttosto semplice, non dovrebbero esserci problemi ne' sorprese.
E invece... Le sorprese cominciano sempre dai particolari inaspettati! Guardate un po' che bello (foto successiva): gli stand-off standard sono troppo piccoli rispetto ai fori presenti sulla base metallica del banchetto!
Ma pork! [!!K@zz@s?AERCCYYTK@@ kzz k kkkpork@@] Cominciamo bene!
Il Cooler Master Lab ha in dotazione degli stand off particolari, in plastica, che io non ho disponibili. Ma pensavo (senza aver controllato ahime'!!!) che fossero un particolare trascurabile e rimpiazzabile da stand off standard (quelli in ottone, raffigurati in foto), che ho in abbondanza.
Manco per niente! Niente stand off Cooler Master, niente montaggio motherboard. E se non cominciamo a fissare la scheda madre, beh, vedete un po' voi che assemblaggio facciamo... !??!!?
Ma senza perdermi d'animo, galoppo verso la ferramenta piu' vicina, con motherboard e banchetto sotto braccio (l'ho fatto veramente! mi sono presentato al banco della ferramenta con il banchetto e la mobo sotto braccio), e rimedio una soluzione, semplice ed efficace.
Va bene. Continuiamo con il resto.
Intrusi passeggiano sul nostro tavolo da lavoro...
... mentre continua l'assemblaggio dei componenti.
Chi e' questo losco figuro al lavoro? Indovinate...
Ultimi particolari...
Finito!
Finito? Era ora... dice lei! (Uma).
Finito, finito. Da tutte le angolazioni.
Test e rilevazione consumi
In idle, una volta stabilizzatosi il sistema dopo la partenza di Windows.
Consumo assestato intorno ai 40 - 45 watt (considerate la presenza di una VGA discreta).
Se avro' tempo, registrero' qualche altra prova di consumo in situazioni diverse, per ora... sono soddisfatto cosi'.
Alcune impressioni su...
Chassis Cooler Master Test Bench v1.0
Riferirvi ora la mia impressione sul mio primo contatto con un banchetto... Beh, che dirvi? Tanto positiva quanto puo' esserlo avere per le mani un oggetto che vi consente la massima libert? e praticit? di utilizzo!
Questo Test Bench prodotto da Cooler Master, disponibile in commercio ad un prezzo contenuto, vi permette di apprezzare e toccare con mano i vantaggi dell'open air. Pratico, elegante, imbattibile dal punto di vista della funzionalit? e, se vogliamo, anche da un punto di vista estetico per chi vuole il contatto visivo con l'hardware. Impagabile l'open air. Leggerissimo e pratico da spostare, anche una volta montato.
Se vogliamo trovare qualche difetto a questo banchetto... proviamoci... ? talmente spartano che non ha supporti di nessun genere per sostenere "in piedi" la VGA che, come tale, deve essere mantenuta in posizione per propria virt? di equilibrio (evitare quindi di "sbattere" il banchetto con l'hardware montato, a rischio di danneggiare lo slot PCI-ex per movimenti improvvisi della VGA), e non ha supporti per eventuali ventole (supporti che si potrebbero peraltro acquistare a parte da altre Aziende).
Ma per iniziare un viaggio nel mondo dell'open air, il budget d'inizio, ridotto quanto possibile, ? importante, e questo Cooler Master potrebbe essere una valida scelta a prezzo accessibile.
Se avete sulla vostra scrivania uno spazio sufficiente in larghezza per appoggiarvi una motherboard, allora potete pensare di installare tutto su questo banchetto. E far morire d'invidia i vostri amichetti niubbacci. Pensateci.
Seasonic X-400 Fanless
Impressioni... su questo alimentatore? E che devo dirvi? E' FANLESS. Vale la pena? Dovete deciderlo voi, in base al vostro budget ed aspettative.
E' un Seasonic X fanless. ... Mmmmh... Non c'e' molto altro che io possa dire, qui su PCSilenzioso!
Final Words
Volevo un PC fanless, dai primi tempi che ho iniziato ad apprezzare belle realizzazioni qui su PCS.
Volevo un banchetto open air, da quando ho realizzato la comodita' ed eleganza di questa soluzione.
Volevo un PC in garage, per fare... le mie cosucce... in tranquillita'.
Ora ho tutto questo.
Devo aggiungere altro?
Post-project pictures
May 2013, Magoo & friends: Fanless Test Lab @ Gaming mode.
- You may not post replies
- You may not edit your posts
Forum Rules
