Anyone out there into modding their car/truck?
I recently was bitten by that bug (mostly out of necessity) & it's worse that OCing, at least on the wallet.
Any ongoing projects out there?
You must [not] advance.
Current Rig: i7 4790k @ stock (**** TIM!) , Zotac GTX 1080 WC'd 2214mhz core / 5528mhz Mem, Asus z-97 Deluxe
Heatware
Looking to turbo my 2004 GMC 1500.. maybe. Needs an upgraded sun shell at some point. Swapped in 2-3, and 4th servos.. HUGE DIFFERENCE!
So much to do with my bogger its rediculous (1990 Dodge w250)
Planning stage on a late 40's/early 50's dodge/fargo 2-ton build..
All along the watchtower the watchmen watch the eternal return.
i am about to get a catless up pipe, g16 td05 turbo, tune, and maybe a new intercooler for my 06 legacy gt (it is a legacy with the engine from an sti, but with a smaller turbo/intercooler and plastic intake manifold.) i am also looking at a set of new rims (the PO destroyed them) and maybe a thick rear sway bar.
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
I have my 99 Camaro that will always be a work in progress I'm sure. I bought it with some stuff done already (cam and supporting head work), so most that I'm doing for now is suspension stuff to make it drive and handle a lot better, also working on cosmetics both inside and outside. Not flashy stuff, but just some nice upgrades. I haven't decided yet but I may turbo a 3800 for it, or I might just jump to a 6.2L LS3 instead. Not sure, but that's a long ways away so I have plenty of time to decide.
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
Be careful! Invest/save some of it
i3-8100 | GTX 970
Ryzen 5 1600 | RX 580
Assume nothing; Question everything
2011 Evo
ETS intake, piping, and intercooler
TurboXS testpipe
T1R 76S exhaust
GTWorx springs
Whiteline roll correction kit
Beatrush diff spacers
makes 350whp, prolly gonna get some JRZ coilovers next year...
I'm very proud of it and I am still working on my car. It's a 2004 Volkswagen GTI w/ 2.8L 24v VR6
I have list of mods far too big to list here but I wanted to chime in and say that modding a car is a lot of fun and the money stays with you unlike a computer. You upgrade/ build a computer every few years, a car can stay with you for a very long time.
Computer: Intel i7-4770k | Asus Z87 Maximus VI Impact | 240GB Corsair Force GT | 240GB OCZ Vertex 3 | 16GB G.Skill Trident X 2400MHz | EVGA GTX690 Hydro Copper 4GB | Corsair AX850 | Steelseries 7G | Logitech G500 | 27" 2560x1440 Overlord Tempest X270OC 120Hz S-IPS
Cooling: Koolance 380i CPU block | Swiftech Hydro Copper GPU block | EK X3 150 Reservoir | EK X-TOP D5 PWM drive | PrimoChill PrimoFlex PRO LRT Bloodshed red | Alphacool NexXxos 240mm XT45 | Alphacool NexXxos 280mm UT60 | Bitspower Fittings | 4x Bitfenix Spectre Pro 120mm | 2x Bitfenix Spectre Pro 140mm | Lamptron FC-5V2
Case: Custom modded matte black Caselabs Mercury S3
i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
Car modding is an affliction just like modding PCs. It's better than spending all of your money on booze and drugs.
Damn, you have an amazing memory. It was on a 3yr lease, we turned it in for a 2011 A3. It's the wife's car.
Decided to turn this one into a track car.
http://vimeo.com/66271656
http://vimeo.com/67438506
I just replaced my dual mass flywheel which was ed up with an aluminium one from jim wolf technology. The new flywheel made a massive improvement but I had to learn how to drive again as the engine changes speed so fast now. I didn't line up the cps (one mark off) so I did the job twice hahaha live and learn. (05 NISMO Frontier)
the VW VR stuff revs out rather high and only makes 200HP for the 2.8 so you dont really need limited slip or an e-diff. unless you add a back turbo i dont see the point in it since the 2.0 turbo will make more power and does not lag, but then a turbo vr6 makes more power than an FF should have. the early '00s gti has room for nice wide tires, and has a short wheel base so FF should not be a handling problem with too much understeer
Sparky, I don't know anything about the LS3 but I have the L9H 6.2 in my Silverado. If the LS3 mileage is similar to the L9H be prepared for a shock at the gas pump! Makes plenty of power but is a gas HOG! Best mileage I've ever seen was 17.7 mpg with ethanol free gas. (I always try to find ethanol free because I get better mileage with it and I don't like ethanol in the first place!) Mileage going back and forth to work is usually in the 15 mpg range, highway mileage around 17 mpg, and interstate 16 mpg. Mileage when pulling a small enclosed trailer is in the 11 mpg to 11.5 mpg range. My truck does have the Max Trailering Pack which in addition to the 6.2 includes 3.73 gear ratio. A 3.42 ratio would help mileage a bit I would think.
If you're thinking about an engine swap and probably won't be getting much for mileage anyway, why not swap in a 7.0 liter? That should make for a FUN ride!
Even with slicks you can spin the inside tire on a GTI with a NA VR6 under hard cornering. On street tires you can smoke the inside tire in a hard turn. It the wet even on the street you might as well get out and push. It's called one-wheel drive for a reason. That's why VW went to braking the spinning wheel for a number of years. Now after years of that actually hurting performance for those who drive in snowy climes I hear VW has gone to an electronic diff on the 2013 GTI, though I have not confirmed this.
I have a Peloquin Limited Slip, Tubular control arms, Ground Control camber plates, and solid aluminum bushings. There is much more going on up front but those are the big ones. While it certainly took a lot of work to get here, there's no tire spinning with this setup.
The LSD makes a world of difference on the track, not so much on the street, I honestly don't push it hard on public roads.
Unfortunately the gear style LSDs require the wheels to be in contact to function properly and when the inside wheel lifts under hard cornering, the inside wheel still spins, but up to that point it helps. The reason most FWD cars don't have LSDs is because they cause understeer and more tire wear. The electronic diff is the ideal design as it only functions when needed sort of like ABS. Porsche has used these for years but they aren't cheap.
@AMDforME
This isn't rally racing, haha, this is amateur track racing.
The wheels are always in contact, I can feel the limits and don't go beyond them. Using sticky NT01's all around, with a camber of -2 up front and 10 way dampening on all 4 corners, 28mm solid swaybar in the rear, solid endlinks set to slightly more stiff in the rear, solid endlinks upfront.
Every part was meticulously picked with FWD handling in mind. Belive me when I say that the car handles quite well.
My mechanic builds mostly performance BMWs (Forced Induction) and he enjoys driving the GTI more because I didn't just throw money at it, I did the research and picked the correct parts needed to make it handle like a Porsche. It's a really challenge too, not many VW guys go to this length.
Some fancy headlights because my old ones were broken and pointing really weird.
Before:
(almost) After:
Finished:
You should do the quad beam mod, so the lows stay on when you hit the highs.
I had forgotten about this thread. I modded my Trailblazer recently and put a lift kit on it with 32" tires. Added a little over 4 inches of ground clearance. I was pleasantly surprised to find my mpg average barely took a hit. A couple tenths lower maybe.
was actually thinking of that just last night.
