So, currently @4.2 w/ 1.19v There's probably a little overhead in there, but since I crunch and game on this rig, I allow a little breathing room.
Now, when crunching w/ a load at around 95%, my temps were hitting 70-74C on an H80i. For me, this is a little too close for comfort for 24/7/365 crunching. I'm very hesitant to delid the processor, so I had one last trick up my sleeve. One thing that I've been doing is cutting out the fan grill at the top back of my Corsair 600T cases. For some reason, I love this case and tend to use it on every rig I build.
After cutting out the grill, I then use a dremel on some cheapo 120mm fans I've got lying around. Once the fan is removed, I use some 2-3in screws and install extensions to the fan in order to increase cool airflow going into the case. This helps to increase penetration into the rad.
By doing these two simple tricks, my temps on the hot-core are down anywhere from 5-9C. Which I think is pretty damn good. Current temps are hovering around 65-68, and I next I'm going to see if I can get it up to 4.3 w/1.2.
Cheers
