X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 5 of 5
Thread: Timing belt question
    Apr 2007
    Long and short of it is, have a 2002 car with only 30,000 km's on it. Been garage stored for the last 5ish years un-driven. It still starts up just fine practically a brand new car. Does a timing belt deteriorate at all if just left on a car not driven? Going to be taking it out of storage this week and I know the guys at the dealership are going to tell me it needs to be changed. But my 2003 with 70,000 miles not km's still has its original timing belt
    i3 2100, MSI H61M-E33. 8GB G.Skill Ripjaws.
    MSI GTX 460 Twin Frozr II. 1TB Caviar Blue.
    Corsair HX 620, CM 690, Win 7 Ultimate 64bit.
    Apr 2008
    Chicagoland U.S.A.
    Its really a coin toss, i have seen timing belts fly off taking the valves with them rolling off the truck from the plant and have seen them go 200,000 without an issue , you just never know.
    If you have oil leaks over or around the front of the engine i would repair the leaks and replace the belt as oil will eat away at the belt.
    It would not be a bad idea to replace the belt if you plan to keep the vehicle assuming some dumbass does not do a hack job replacing the thing. ( I don't trust anybody working on my vehicles ).
    Dec 2007
    Texas
    I second the coin toss. Rubber parts can and will deteriorate overtime even if they are not being used. But if it were me I would prolly just take the chance and then replace it around 70k.
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
    Dec 2004
    Long Island, NY
    If it's a belt then I would change it. If it's a chain then no.
    New rig: INWIN D-Frame, i7 4770k @ 4.7 Ghz/1.38V, Swiftech H220, MSI Z87-GD65 Gaming, Team Vulcan DDR3 1600, 9-9-9-24, Samsung 840 pro 256GB, EVGA GTX 780, Corsair 850W
    Old rig:Antec 900/GIGABYTE GA-X38T-DQ6
    E6750 @ 3.5 GHz/Thermalright 120 extreme/MX2
    CORSAIR Vengance 8GB
    PNY 8800GT/Thermalright HR-03 GT
    Old, old rig: FX-53/GIGABYTE K8NSNXP-939 nForce3 Ultra/1GB CORSAIR 3200XLPRO
    X800XTPE/WD 74GB Raptor/250GB Caviar
    Dec 2007
    You should replace the belt, normally OEMs recomend replacing the T-Belt around 80,000 kms or 5 years.
    Better safe than sorry.
    Are we there yet?
