Results 1 to 20 of 20
Thread: Haswell: what voltages are safe?
    Mar 2006
    Sydney , Australia
    Guys, I would have thought that the new architecture would have lowered the safe voltage levels but it seems most people are still pushing the same voltages as Ivy and Sandy, so what is regarded as safe? What do you think will cause degradation? I noticed that vcore at all stock, only with ram set to 2400c9 XMP, raises vcore to 1.243v so this makes me think that maybe 1.30v isnt a big deal.
    With adaptive voltages working so well, does that make higher voltages slightly more safe since the cpu will spend most of its life down clocked and down volted?
    Any input would be great.
    Bencher/Gamer(1) 4930K - Asus R4E - 2x R9 290x - G.skill Pi 2200c7 or Team 2400LV 4x4GB - EK Supreme HF - SR1-420 - Qnix 2560x1440
    Netbox AMD 5600K - Gigabyte mitx - Aten DVI/USB/120Hz KVM
    PB 1xTitan=16453(3D11), 1xGTX680=13343(3D11), 1x GTX580=8733(3D11)38000(3D06) 1x7970=12059(3D11)40000(vantage)395k(AM3) Folding for team 24
    AUSTRALIAN DRAG RACING http://www.youtube.com/watch?v=OFsbfEIy3Yw
    Dec 2004
    Long Island, NY
    I doubt you're going to get any help. Everyone here's keeping their settings a guarded secret at the moment for that top overclocking spot. lol I've had to go to other forums to find out what works and what doesn't.
    FWIW, I'm on 1.4 vcore so far running a stable 4.7 on water. Not delided. I haven't used adaptive volts though.
    New rig: INWIN D-Frame, i7 4770k @ 4.7 Ghz/1.38V, Swiftech H220, MSI Z87-GD65 Gaming, Team Vulcan DDR3 1600, 9-9-9-24, Samsung 840 pro 256GB, EVGA GTX 780, Corsair 850W
    Old rig:Antec 900/GIGABYTE GA-X38T-DQ6
    E6750 @ 3.5 GHz/Thermalright 120 extreme/MX2
    CORSAIR Vengance 8GB
    PNY 8800GT/Thermalright HR-03 GT
    Old, old rig: FX-53/GIGABYTE K8NSNXP-939 nForce3 Ultra/1GB CORSAIR 3200XLPRO
    X800XTPE/WD 74GB Raptor/250GB Caviar
    Jul 2006
    anything more than 1.7vcore is possible to kill the CPU, be it ln2 cooled or not.
    Nov 2008
    for 4.7GHz i have 1.27 Vcore, 1.3V Vring, 1.8V VRIN.
    INTEL i5 4670K @ 5.2GHz - GIGABYTE Z87X-UD3H - CORSAIR VENGEANCE PRO BLUE - Palit GTX 770 OC - XFX Pro XXX 850W - SanDisk Extreme SSD 120GB
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    up to 1.3 V on all lines (CPU, Cache, vccSA, AIO, DIO) should be fine. Don't push more than you need, is better to clock CPU up, then add volts, rather than set voltage and tune CPU to that voltage. ASUS guides say up to 1.3 or so, other guides I have (dunno if I can share) say similar things.
    Seems slightly higher cache than cpu-V pays off for some.
    I am Xtreme
    Dec 2004
    France
    over 1.5v n the CPU can kill it on air, Ln2 over 1.8v can kill it, over 2.8v VIN can also kill it. If you have an asus board all the voltages will be in volts, on all if not most other boards they will be in offsets for the system agent, IOA and IOD because that is how Intel defines them(and how it comes in the UEFi code) and you can go to +0.3v on air with them. In my OC guide i outline safe voltages. IDk how you can translate them to asus board if you are using one, but follow shamino's guide, or there are a bunch of guides, i think hardocp listed a asus guide on kylebennet's site too, maybe look there, or raja has one on the ROG forums and i think maybe here i didn't look. System agent can help, but id stay under 1.3v like dave said, it can help a lot with CPU staiblization and of course uncore clocks.
    There are tricks with volts to get higher BCLk too, and somti mes it isn't what you think, like now I can do 198mhz BCLK on air with the OC where as before I could only do 189. But you don't need BCLK unless you are going for memory frequency WRs with single sided hynix MFR on LN2 lol.
    Dec 2004
    Long Island, NY
    Quote Originally Posted by sin0822 View Post
    There are quite a few offsets on the MSI board and coming from a socket 775/x38 system this has been a huge learning curve. Looking for any tip I can get. Seems like I'm trying to force the stable frequency with more core voltage whereas if I learned the other settings I can come down on the core voltage.
    Anyone want to clue me in as to what 2T/2T is?
    5GHz@1.4V 2C/2T
    Aug 2008
    Atlanta
    Quote Originally Posted by Rob94hawk View Post
    Anyone want to clue me in as to what 2C/2T is?
    It refers to disabling cores/threads in BIOS... 2-cores/2-threads... Or 4-cores/4-threads.
    Ryzen 9 on the test bench... Sometimes older generation/tech as well.
    Xtreme Memory Hoarder
    Mar 2010
    No guarded secret dude, you just need to test what voltages your cpu likes as they are all different. I spent a few hours, (yes hours) dialing in SA, IOA and IOD as these voltages are the most important.
    Input voltage should be no more than 2.1-2.3 on air to keep it safe.
    Quote Originally Posted by Hondacity View Post
    gskillllin it!
    Mar 2006
    Sydney , Australia
    Why does v-in need to be so high? What does it help?
    I am Xtreme
    Dec 2004
    France
    it helps stabilize the CPU, and might require less vcore if you find the sweet spot. ring voltage helps too with stabilizing the CPU.
    Dec 2004
    Long Island, NY
    Quote Originally Posted by l0ud_sil3nc3 View Post
    Appreciate the tip! By increasing the VCCIN a bit to 1.8 I was able to lower the voltage to 1.38 from 1.4 for 4.7 ghz. (ring 4.4ghz/1.15v) Unfortunately the BSOD showed up 7 hours later (only lasted 4 last time) just by watching a youtube vid. But rock solid stable through gaming. Go figure
    No need to touch SA, IOA and IOD since my memory's XMP is 1600 @ 9-9-9-24 2T.
    If I actually knew what I was doing I probably could've hit 5 ghz last month lol
    I am Xtreme
    Dec 2004
    France
    uit seems that this easy crashing by watching youtube videos is pretty common with Z87, it might be related to GPU incompatibilities or cache frequency or DPC.
    Dec 2006
    Malaysia
    Np with m6e. Running 24/7. I suspect it because of io a/d. Running them on offet auto with c-states require higher voltages as to fully manual without c-states.
    btw want to ask. is it ok to run cache/vring voltage higher than vcore?? to get 1:1.
    RAIDer
    Jul 2005
    Norway
    XS= xtreme safety? :p
    Moderator
    Jun 2002
    Quote Originally Posted by cstkl1 View Post
    why not? i dont find any relation between the 2 volts, they are individual domains.
  18. #18
    Feb 2007
    gotta love all the misinformation out there. So which is it? who's right? who's wrong? says who? half the people say do not exceed your vcore voltage with your cache (vring) voltage - yet here you guys are telling them its ok. Internet is a breadth of knowledge but a double edged sword in that regard.
    anvhow vccin helps stabilize the cpu because that IS is the voltage supplied to the voltage regulator. It needs to be higher than ALL other voltages, for obvious reasons.
    soa/ioa/iod aren't the most important voltages, however they do help with higher memory clocks due to stabilizing the IMC (memory controller) which can get pretty wonky at higher clocks.
    I will agree with 2.3 being adequate for anything apart from XOC perhaps. If you aren't getting the oc you want and your VCCIN is to this point, don't exceed it, your problem is elsewhere. As for voltages, up until a point - with these chips especially, temperature will be your enemy to a much greater degree than voltage. If your temps are in check 1.5 is perfectly safe. (course if your temps are In check at this point, you aren't on air =P)
    As for Vring, keeping them lower than your vcore at the high end is a good idea. Many have killed their chips w/ too high of a ring bus voltage. I wouldn't exceed 1.4 especially on air. Many say 1.3 but we have a lot of conservatives out there. Your uncore will crap out before your core OC will and it would end up taking you too much voltage to keep them 1/1. Best ive managed is a balance im happy with at 48/46 with intelburntest on maximum getting me up to about 73 degrees. If I go for 47 uncore the required voltage to be stable is too high for me (1.5) vring. On the core side, 4.9 is possible stable but that just widens the gap and the tradeoff for an extra 100 MHz is another full tenth of a volt and another 10c. (1.525 from 1.425) Initially I wanted 5.0 and felt I had the cooling to do it, this chip just isn't the one. 4.8 is the area where it starts to scale out of control.
    I do have another 4770k that im debating opening up and trying out, although the minute I open it - im tossing 250-300 bucks away for a potential 200mhz lol. Sounds fun but my brain is telling me sell it =P
  19. #19
    Nov 2008
    my cpu scaling
    4.6 GHz: 1.15V Vcore, 1.05 Vring, 1.8V VRIN
    4.7 GHz: 1.2V
    4.8GHz: 1.25V
    4.9GHz: 1.3V, 1.1V, 1.9V
    5.0GHz: 1.35V, 1.1V, 1.9V
    5.2GHz: 1.45V, 1.2V, 2.2V
  20. #20
    Feb 2007
    Quote Originally Posted by gravimag View Post
    my cpu scaling
    4.7 GHz: 1.2V
    4.8GHz: 1.25V
    gonna pull your card on that. ss or it didn't happen.
