Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: IVY E uses solder tim as expected, see delidded (and killed) 4960X with solder tim
    Jun 2007
    Thread here, Toppc (same guy that typically posts engineering sample specs long before NDA are up, ie like he did with 4770K), delidded his Ivy E eng sample 4960x, killing cpu in process as he had to pry solder apart (he believed the nonsensical internet rumor of cant solder 22nm, ie thought it was paste). You can clearly see the solder, amongst his ranting that someone spreading rumors about paste tim owes him another cpu.
    http://translate.google.com/translat...25E5%258B%2592
    May 2008
    Hahahaha!!!
    Quote Originally Posted by alacheesu View Post
    If you were consistently able to put two pieces of lego together when you were a kid, you should have no trouble replacing the pump top.
    Xtreme Addict Evantaur's Avatar
    Jul 2011
    Finland
    shouldn't laugh
    but this is hilarious
    I like large posteriors and I cannot prevaricate
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by AzureSky View Post
    in before rollo "im sure even in that state is faster then anything amd makes"
    Nice job getting personal on an unrelated topic.
    Donate to XS forums
    Mar 2010
    History of science, trial and... total fail ha ha ha
    Jul 2008
    In the space between...
    ROFL! Even if it woulda had TIM, who'd risk it with such a nice chip?
    'Best Bang For The Buck' Build - CM Storm Sniper - CM V8 GTS HSF
    2500K @ 4.5GHz 24/7 - Asus P8Z68-V Pro Gen3 - GSkill 2x4GB DDR3-2400 C10
    Sapphire Vapor-X 7770 OC Edition - PC Power & Cooling Silencer MkIII 600W
    Boot: 2x 64GB SuperSSpeed S301 SLC Raid 0 Work: Intel 520 120GB
    Storage: Crucial M500 1TB - Ocz Vertex 4 128GB - 4x 50GB Ocz Vertex 2
    HDDs: 2 x 1TB WD RE4 Raid0 - Ext.Backup: 2 x 1.5TB WD Blacks Raid 1
    Moderator
    Oct 2007
    Oregon - USA
    rough go, but soldered spreader is very good for the community.
    Asus Rampage IV Extreme
    4930k @4.875
    G.Skill Trident X 2666 Cl10
    Gtx 780 SC
    1600w Lepa Gold
    Samsung 840 Pro 256GB
    Xtreme Cruncher
    Jun 2006
    That's such a shame . It's a beast of a chip, might have been useful for many good purposes. Only a key chain material now
    Apr 2010
    but how hot will it run........and will it blend?
    AMD FX-8350@4.6(280/2520/2520)| 32gb gskill ares ddr3 1866|
    2*sapphire dual-x 7870ghz|16896.8 GB hdd space|
    2*hp ZR24w+Gateway FPD1976W(video playback)|Asus Xonar DX|
    z5500 5.1 speakers|Windows 7 x64|CoolerMaster Cosmos Medusa
    PcPower and Cooling TurboCool 1200watt
    Mar 2008
    Minnesota
    Quote Originally Posted by Zaxx View Post
    He probably has a tray of them at this point.
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Dec 2007
    Ah this is good news I was hoping they wouldnt screw the high end....
    Jul 2007
    Alberta, Canada
    This is good news.
    Does anyone have any concrete reason why Intel skipped solder on Ivy and Haswell by the way? It can't possibly add that much cost and time to the process can it?
    Feedanator 7.0
    CASE:R5|PSU:850G2|CPU:i7 6850K|MB:x99 Ultra|RAM:8x4 2666|GPU:980TI|SSD:BPX256/Evo500|SOUND:2i4/HS8
    LCD:XB271HU|OS:Win10|INPUT:G900/K70 |HS/F:H115i
    Jun 2007
    Finland
    I think the reason Ivy LGA1155 and Haswell 1150 are not soldered is that smaller core is too fragile to solder.
    Ivy-E and Haswell-E have much bigger cores and due that are not too fragile as Ivy and Haswell to solder.
    ::: Desktop's - Intel *** Intel 2
    2 x Xeon E5-2687W *** Intel i7 3930k
    EVGA SR-X *** Asus Rampage IV Extreme
    96Gb (12x8Gb) G.Skill Trident X DDR3-2400MHz 10-12-12-2N *** 32Gb (8x4Gb) G.Skill Trident X DDR3-2666 10-12-12-2N
    3 x Zotac GTX 680 4Gb + EK-FC680 GTX Acetal *** 3 x EVGA GeForce GTX780 + EK Titan XXL Edition waterblocks.
    OCZ RevoDrive 3 x4 960Gb *** 4 x Samsung 840 Pro 512Gb
    Avermedia LiveGamer HD capture card
    Caselabs TX10-D
    14 x 4 TB WD RE4 in RAID10+2Spare
    4 x Corsair AX1200
    ::: Basement DataCenter :::
    [*] Fibreoptic connection from operators core network
    [*] Dell PowerConnect 2848 Ethernet Switch [*] Network Security Devices by Cisco
    [*] Dell EqualLogic PS6500E 96Tb iSCSI SAN (40 2Tb Drives + 8 Spare Drives, Raid10+Spare Configuration, 40Tb fail safe storage)
    [*] Additional SAN machines with FusionIO ioDrive Octal's (4 total Octals).
    [*] 10 x Dual Xeon X5680, 12Gb DDR3, 2x100Gb Vertex 2 Pro Raid1 [*] 4 x Quad Xeon E7-4870, 96Gb DDR3, 2x100Gb Vertex 2 Pro Raid1
    [*] Monster UPS unit incase power grid failure backed up by diesel powered generator.
    Jul 2007
    Alberta, Canada
    I've see various opinion's on the topic so far but many seem to suggest that the die's integrity shouldn't be the issue. It sounds plausible to me though. Would be nice if someone in the semi conductor industry or better yet Intel themselves had something to say on the matter.
    Things will only get smaller and denser from here on out and given Ivy and Haswell, I'd HATE to see 14nm running TIM...
    Feedanator 7.0
    Jun 2007
    If your really interested you cant send an inquiry to intel indium solder, they sell solder attaches for all die sizes, including dies smaller than Haswell or Ivy, as do many others. And both Haswell and Ivy are soldered, they are soldered to the PCB, they just dont have solder for tim as well. Cost/yield vs need. If you look at prices for indium solder vs paste per units on intels indium site, it isnt small, and multiple that x numbers sold, and factor in NO one needs solder on Ivy or Haswell if running at stock, like 99.9% will do.
    Would be nice for K's to be soldered, but just dont see that ever happening, unless stock specs warrant it.
    And solder isnt the only high thermal conductive attach, there are better and worse, tim is just cheapest.
    Dec 2009
    Brisbane
    I call bull, he killed that before he "delidded" it, he broke half of the little chips off! and THAT amount of solder on it? really? must be a pretty decent heat gun to melt the solder through the IHS...
    trying to think of something to put here...
    Xtreme Mentor
    Jul 2008
    Shimla , India
    Quote Originally Posted by tool_462 View Post
    Doesn't work like that at least i never got more than the one that also depending on availability of ES. They are limited in number and are shared no point in keeping all in a tray for a guy to destroy.
    Coming Soon
  18. #18
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    i would skip this gen waiting for H-E new 2011-3 socket + DDR4
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
  19. #19
    Oct 2012
    Quote Originally Posted by rintamarotta View Post
    bingo!
  20. #20
    Mar 2005
    Buenos Aires, Argentina
    Quote Originally Posted by PedantOne View Post
    bingo!
    I don't think than what rintamarotta said is the actual reason. I totally agree with rge.
    If Intel can get away by using cheaper grease on Desktops Ivy Bridge/Haswell, why would they solder it if its not needed on the first place? Reducing the bill of materials, they increase profit per unit, and they can do it, so why not? Makes sense to me. Even on other eras, solder was also reserved almost exclusively to high end products or that were at the top end of what their node allowed where solder was one of the things that made such a product possible, something that LGA 1150 Ivy Bridges and Haswell are NOT. Only with the original Conroe Intel overdid it with both solder and an overspecced cooling solution that allowed high overclocks even with stock cooling, and maybe with Sandy Bridge, too.
    Besides, there is a misconception regarding on the fact that the K series should be soldered because they're intended for enthusiasts. The only thing that Intel does manufacturing-side with the K series, is probabily changing a single write-once bit that to unlock the multiplier, and charging you 20 U$Ds more for that. If they're successfull in this market only doing that, again, why are they going to spend more resources just to please you? Intel runs a business, not charity, and their business track record always included sky-high profit margings for reasons like this.
  21. #21
    Xtremeish
    Nov 2005
    Norway
    Quote Originally Posted by B_Boy View Post
    Those little chips are ceramic capacitors(looks like 0402 size), and the reason they broke of is because like you mention the amount of solder that needs to be melted, so I bet some prying and quite a a substantial amount of heat was applied. It's very hard to control this process of removal if you don't have some kind of specialized equipment that aid you, so the temperature on the die during disassembly probably well exceeded the specifications. Not to mention that this really isn't designed to come apart anyways...
    Aber ja, naturlich Hans nass ist, er steht unter einem Wasserfall - James May
    Hardware: Gigabyte GA-Z87M-D3H, Intel i5 4670k @ 4GHz, Crucial DDR3 BallistiX, Asus GTX 770 DirectCU II, Corsair HX 650W, Samsung 830 256GB, Silverstone Precision -|- Cooling: Noctua NH-C12P SE14
  22. #22
    Jun 2007
    bingo!
    Wa are now on one year old 22nm production from Ivy, and situation is worst with Haswell. It seems not better for HSW-E
    PS. 22nm cant be soldered, sorry ...
    PS2. Westmere was not soldered too, and was a problem?
    you stated in other thread that 22nm cant be soldered, above is your post. Now you have been proven wrong via IVY E is soldered. So now your claiming saying small dies cant be soldered...really?
    Why dont you post some link or info from intel...though you cant since this was started by someone guessing maybe that is why intel didnt solder them, then someone, including you, took that internet supposition for fact.
    So lets see your source, or are you just agreeing it is just an internet rumor.
  23. #23
    Xtremeish
    Nov 2005
    Norway
    We have been over this several times, and it only takes one person that does not understand or have no knowledge of Surface-Mount-Technology to come up with bad information like this.
    The Haswell chips that have been soldered to the PCB's you find in mobile devices like laptops are BGA type packages, these go through what we call Reflow Soldering, which includes a multi zoned precise oven with a built in conveyor belt. The thermal profile of how these chips should be soldered can be found on Intel's website, they weren't published last time I saw, but you could always E-Mail them and ask for it.
    Let me also say this: With few exceptions today most electronics follow the RoHS standard of not using Lead in the solder paste, now if the product could not follow this specification (within the most used thermal profiles) we would have quite the uproar from several large manufacturers who would either need to reevaluate large parts of the production cycle or split it up to comply with the new guide lines. If anything, this would cause a headline.
    So for now, whenever anyone mentions this without a source: Ignore the troll and move along =)
    This is what they look like from the top and bottom:
    http://www.extremetech.com/wp-conten...ga-640x510.jpg
    http://en.wikipedia.org/wiki/Reflow_soldering
    http://en.wikipedia.org/wiki/RoHS
    http://en.wikipedia.org/wiki/Ball_grid_array
    http://en.wikipedia.org/wiki/Flip_chip
    http://en.wikipedia.org/wiki/Integrated_circuit
    http://www.youtube.com/watch?v=d9SWNLZvA8g
  24. #24
    Mar 2008
    Minnesota
    Quote Originally Posted by ajaidev View Post
    I used to get 6 of each stepping as they came out, no email, no message, just a package at the door. See my sig...
    I had a sort of "hook up" though of course.
  25. #25
    Xtreme Cruncher
    Jun 2009
    Bombay , India
    ^i hate you
    My nickname is tool !
    Intel Core i7 3960x | 3x Intel Core i7 980x | 3x Intel Core i7 920 | 2x Intel Core i7 2600k | 2x AMD opteron 6282 SE | 3x Asus Rampage II Extreme | 2x Asus Rampage III Extreme | Asus Rampage IV Extreme | 1x Gigabyte X58A-UD7 | 2x Asus Maximus IV Extreme-Z | Asus KGPE-D16 | 3x 6GB DDR3 Corsair Dominator 1600 Cl7 | 1x Patriot Viper II 6GB 2000 Cl8 | 3x Corsair Hx1000 | 4x Corsair Ax 1200 | 3x Antec 1200 | 4x Corsair Obsidian 800D | 2x Intel 80Gb G2 SSD | 4x Kingston HyperX 120GB | 2x Vertex 2 120GB | 2xWD 150GB Velociraptor + 1x WD 300GB Velociraptor +5TB | Msi Nvidia Gtx 295 | Msi Ati 4870x2 OC Edition | 2x Msi Ati 4890 OC Editions| 2x Sapphire Ati 5870's| Sapphire 5970 OC Edition | 2x Msi Gtx 460 | 3x Sapphire 6970 | 3x Asus Gtx 580 | 3x Asus 7970
