Results 1 to 6 of 6
Thread: Best Bang for $ Graphics card for 1080/1440 Video
    Oct 2006
    Shanhai China
    I have a Hero3 recording at 1080/60fps or 1440/30fps. When I try to play back on my PC running an ATI GS9300 onto a 1280-1024 LCD, Q6600 CPU, Intel G41 Mobo, 8gb 1333 RAM, WD Blue 1TB I get stutttttteeeeeeerrrrrrrrr.
    I have order a QHD LED 2560x1440 which arrives today, so what will be the best Sub $200 graphics card to match this setup and stop the stutter?
    24/7 PC CoolerMaster CM690 + 7 fans(its HOT as HELL in Shanghai) Intel Xeon E3 1230 3.3-3.7Ghz, 2x8GB DDR3 1600 G-Skill, HD GT630 2GB, Scandisk Pro 256SSD 2x2TB Green, 2x 3TB WD Green Data Drives. HTPC Q8400, EP45 UD3L 4x1GB Gskill6400, 1xWD Black 640GB,2x2TB WD Green, 2xWD 1TB Blue(RAID1), Sapphire 4530 512MB,
    Computers have enabled people to make more mistakes faster than almost any invention in history, with the possible exception of tequila and hand guns.
    Mitch Ratcliffe, U.S. technology journalist and blogger
    Jun 2006
    The O.C.
    The Nvidia gtx 660 is the best sub $200 card for gaming you can get for 2560x1440, but you might be able to find cheaper just for HD video playback.
    i7-2600k L041C108 4.8ghz 1.32v PLL off Venomous-X Push/Pull http://www.xtremesystems.org/forums/...postcount=1063
    Asus P8P67 Vanilla
    Samsung 30nm MV-3V4G3D/US 2x4GB @ 9-10-10-28 1T DDR3 2133 1.6v http://www.techpowerup.com/forums/sh...d.php?t=159320
    Diamond HD 7970
    WD 600GB Velociraptor
    Corsair TX750W
    CM 690 II Advanced
    Q822A549 E8500 @ 4.5ghz air TRUE @ http://www.xtremesystems.org/forums/...d.php?t=203762
    G.Skill F3-12800CL6D-4GBXH @ 7-10-8-27 1T DDR3 2133 1.6v http://www.xtremesystems.org/forums/...d.php?t=266839
    Oct 2006
    Shanhai China
    what about
    What about the cheapo GTX630
    http://www.newegg.com.cn/Product/A19...0-_-281424-_-2
    or should I save some pocket money for the GTX650
    http://www.newegg.com.cn/Product/A19...0-_-288571-_-3
    The GTX660 will not fit to well on my LianLi T1 spider.......
    Feb 2009
    Hawaii
    ATI 9300? Is this an old AGP card? If so pretty much anything should play back your video. The gtx 630 should be fine.
    Xeon E3-1245 @ Stock | Gigabyte H87N-Wifi | 16GB Crucial Ballistix LP @ 1600Mhz | R7 260x | Much and varied storage
    Oct 2012
    Quote Originally Posted by LagunaX View Post
    Until recently I hadn't seen any GTX660 cards under $200. After rebate and instant discount, ASUS GTX660 at Newegg is probably the cheapest right now. Zotac and MSI also have sub $200 cards at Amazon.
    Without rebate, the HD7850 is probably the best bang for your buck on the AMD side. Though I have seen the HD7870 occasionally under $200 after rebate.
    Desktop rigs:
    Oysterhead- Intel i5-2320 CPU@3.0Ghz, Zalman 9500AT2, 8Gb Patriot 1333Mhz DDR3 RAM, 120Gb Kingston V200+ SSD, 1Tb Seagate HD, Linux Mint 17 Cinnamon 64 bit, LG 330W PSU
    Flying Frog Brigade-Intel Xeon W3520@2.66Ghz, 6Gb Hynix 1066Mhz DDR3 RAM, 640Gb Hitachi HD, 512Mb GDDR5 AMD HD4870, Mac OSX 10.6.8/Linux Mint 14 Cinnamon dual boot
    Laptop:
    Colonel Claypool-Intel T6600 Core 2 Duo, 4Gb 1066Mhz DDR3 RAM, 1Gb GDDR3 Nvidia 230M,240Gb Edge SATA6 SSD, Windows 7 Home 64 bit
    Oct 2006
    Shanhai China
    Thank you all for the feedback, looks like I will go for a GT630 with 2GB of memory for around $90.
