Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: I bin PSC per IC at Home !!
    Champion
    May 2013
    Hong Kong
    I am using DDR3-2400 CL8-11-7-27 1T tcwl 6 for binning rules .... of course I use 1.5v vDIMM only!!
    I only do it when my wife slept !! Dual Channel is much faster !!
    Red is not pass , green is pass !! so I will know which chip is good enough for my battlefield !!
    It will be 8 layers 2oz PCB !! Codename : "Splave Series" !!
    Mar 2007
    Buenos Aires,Argentina
    lucky boy!
    hersounds powered by 121 % overclocking Machine http://valid.x86-secret.com/show_oc.php?id=220390 - http://valid.canardpc.com/show_oc.php?id=1917405
    facebook.com/hersounds
    Intel Core i5 4670K @ 4,5 Ghz 24/7 - Galaxy HOF GTX 780 - 8 GB Team Group Xtreem 2666 Cas 11 - 8Gb Avexir Core series 2800 Blue Led - Maximus VI Formula Armor TUF - Corsair Force GT 120 GB SATA 3 - Galaxy Hall of fame 1200 hersounds Limited edition Modular - Antec 620 dual fan mod
    Nov 2005
    The Netherlands
    will be interesting to see what your best combination can do
    Champion
    May 2013
    Hong Kong
    Ask Splave !! He is going crazy on it !!
    PI in the face
    Nov 2008
    my angus is ready
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
    Oct 2009
    Louisville, KY
    Would you mind explaining exactly how all of this works? It's quite interesting!
    i7 920 / X58A-OC / Dominator GT 2000 7-8-7 / 5870 Lightning
    Pie assassin
    Nov 2007
    Where lights collide
    Quote Originally Posted by bassplayer View Post
    the combination of software + hardware lets one bin per IC. Each IC is removed and re-balled, then re-inserted into the test setup and binned.
    Current Status - Testing & Research
    Champion
    May 2013
    Hong Kong
    Quote Originally Posted by ZenEffect View Post
    Not really... It is Hardware base IC Sorter. No OS required !! My English is not good . may be splave can explaining much clearly
    3D Team Captain
    May 2007
    Munich, Germany
    Great effort, I'm looking forward to seeing the final results.
    Oh, and count me in for a Splave Series kit.
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    May 2007
    Romania
    +1....how many ic's do you have?
    PI in the face
    Nov 2008
    I think there are about 600 right?
    XIP
    Nov 2004
    NYC
    You guys should launch your own "highly binned" retail ram kit company
    I'm gonna be your first customer, that's fo sho
    Administrator
    Nov 2007
    Stockton, CA
    Quote Originally Posted by Don_Dan View Post
    That might be a costly kit !!
    Pie assassin
    Nov 2007
    Quote Originally Posted by John Lam View Post
    There is still a software component. I assumed that it wouldnt require an OS, mabye a boot disk/usb but probably boots from hardware (which contains the software.)
    Best of luck with this endevor, hope to see a killer kit emerge.
    600IC is roughly 37 double sided sticks isnt it? are you sure thats enough? (no sarcasim intended) if only 1 IC are passing with tight bin rules out of 8, with 16 required, that makes a total of 2 good sticks out of 600 IC with 2 IC or so left over. TBH, the cost on this compared to binning MFR per IC is MUCH cheaper. About $1000 in memory to remove and reball before you can sort the ICs.
    Champion
    May 2013
    Hong Kong
    There is still a software component. I assumed that it wouldnt require an OS, mabye a boot disk/usb at best. Best of luck with this endevor.
    600 IC is binned passed 1.65v twcl 7 and I am going for second bin for DDR3-2500 twcl 6
    Administrator
    Nov 2007
    Stockton, CA
    I think they are just looking for a few sets of sticks to rule them all, not go into full production mode.
    Nice stuff John, knock em dead man !
    Champion
    May 2013
    Hong Kong
    May be it call "Firmware".... but anyway... Hardware cannot alive without software.
  18. #18
    Champion
    May 2013
    Hong Kong
    Quote Originally Posted by Buckeye View Post
    We are not going for mass production. Just look for some stick can go 5-9-5 2.1v
  19. #19
    Administrator
    Nov 2007
    Stockton, CA
    Yes that's what I said
  20. #20
    Xtreme Memory Hoarder
    Mar 2010
    Better to test with twcl 5 cl 5 if possible.
    Regardless this is an awesome project and I can not wait to see your results
    Quote Originally Posted by Hondacity View Post
    gskillllin it!
  21. #21
    May 2012
    Sounds to me like no-one will ever catch Splave in Pi
  22. #22
    Mar 2012
    Brisbane,Australia
    looks great!
    this is a very interesting project for sure.
    Ill take a kit too..
    Work/Gaming: i7-950|GB X58A-UD7|12GB Trident BBSE/XMS3|460GTX|WD 1TB BLK|Pioneer DVDRW|CM HAF-X|Win 7 Pro 64 bit|U2711|HX850|G500|G510
    Quote Originally Posted by hiwa View Post
    I protect my gskills like how i protect my balls
    Heatware: jimba86
    Bench:Custom Giga-bench|Win 7/XP SP3|WD 36GB Raptor|Dell 22|AX1200|MS intellimouse
    Bench 1:i7 930|water 2.0 performer|Gigabyte X58A-OC | 4GB corsair 1866 CL7|GTX 295 Quad SLI
    Bench 2:E8500|NHD14|P45-UD3P(2nd PCIEx16 slot broken.. )|2GB Corsair 8888 Cl4|GTX 260 SOC
    (Bench 3: In Progress) 4770K|F1EE|Gigabyte Z97X-SOC Force| 4GB GTX1 /8GB Gskill TridentX 2666CL11 ney pro|5870 x3 on KPC tek9 slim 5.0/7.0
    Bench 4 E8600|NHD14|REX|2GB Corsair 1800 Cl7|Asus GTX 280
    Bench 5 (TBC): FX?|990FX-UD7|Gskill Flare 2000 Cl7|6970
    Server/renderbox: G3258|TT Water 2.0|Gigabyte Z87 Sniper M5|8GB Gskill Sniper 2133|gigabyte 5750|FD NODE 804
  23. #23
    Champion
    Mar 2005
    Warsaw, Poland
    This is a new level of benching... ! You are PRO
    MSI MOA 2009 POLAND #3
    Gigabyte GOOC 2010 POLAND #2
    MSI MOA 2010 POLAND - NOT ORGANISED
    ASUS Polish Overclocking Championship 2010 #1
    MSI MOA 2011 POLAND - NOT INVITED
    HWBOT Country Cup 2011 - POLAND! #1
    MSI MOA 2012 EMEA - #1
    MSI MOA 2012 WW FINALS - #7
    ASUS Open Overclocking Cup AOOC 2012 - #1
    HWBOT Country Cup 2012 - POLAND! #2
    MSI MOA 2013 EMEA Qualifier - #2
    ASUS Open Overclocking Cup AOOC 2013 - #?
    MSI MOA 2013 WW FINALS - #?
  24. #24
    Champion
    May 2013
    Hong Kong
    Quote Originally Posted by l0ud_sil3nc3 View Post
    No boot on Air.
  25. #25
    Oct 2009
    Louisville, KY
    Are they actually balling the IC's? My guess would be that the jig allows them to mount the IC's securely without actually flowing any solder.
