Trying to find out if the GTX770 will be offered with more than 2G of memory? Anyone have a clue?
Asus Z87 Deluxe
Intel I7 4770K/CM Eisberg 240L
16G (2X8) Corsair Vengance Pro DDR3 1600 CMY16GX3M2A1600C9
Corsair HX 850wt PSU
2X Corsair Neutron GTX 120GB SSD
1X Corsair Neutron GTX 240GB SSD
1 Seagate SATA3 2TB HDD
EVGA GTX780 sc
Creative SB ZXR
CM HAF XM case
Asus VG248 24" 3D LCD monitor
Audioengine A5+speakers/AS8 sub
Win8 Pro
it should never have 3GB as it is a 256bit buss, there is a 4GB card that was not stocked yet on newegg so i would assume that they will come.
http://www.newegg.com/Product/Produc...82E16814125462
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
Ah, thank you. Missed that while browsing newegg.
Asus Z87 Deluxe
EVGA GTX780 sc
Creative SB ZXR
CM HAF XM case
Win8 Pro
the 770 is essentially the same as a 680. Therefore you'll find 2gb, and 4gb versions
Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
