i7 4930K
32GB Corsair Vengeance Pro DDR3-2400C10
Asus Rampage IV Black Edition
2x GeForce GTX 780
Corsair AX1200
Cooler Master HAF-X
Dell U3011
yea the beauty of haswell. Hey is that new memtweakit on TT or somthing?
Memtweakit for you sin
http://www.overclock.net/t/1300766/s...#post_20119337
New rig: INWIN D-Frame, i7 4770k @ 4.7 Ghz/1.38V, Swiftech H220, MSI Z87-GD65 Gaming, Team Vulcan DDR3 1600, 9-9-9-24, Samsung 840 pro 256GB, EVGA GTX 780, Corsair 850W
Old rig:Antec 900/GIGABYTE GA-X38T-DQ6
E6750 @ 3.5 GHz/Thermalright 120 extreme/MX2
CORSAIR Vengance 8GB
PNY 8800GT/Thermalright HR-03 GT
Old, old rig: FX-53/GIGABYTE K8NSNXP-939 nForce3 Ultra/1GB CORSAIR 3200XLPRO
X800XTPE/WD 74GB Raptor/250GB Caviar
not too much, but for memory OC over 3ghz+ you will need to use 1.25x divider and for 4K+ it matters a lot as 1.67x doesn't seem to play nice with memory multiplier yet, so you need like 120x1.25*29.33. CPU OC seem to be little to no difference, maybe sometimes you can get higher with a divider maybe sometimes without. BCLK has a lot to do with the BIOS you use and its BCLK tuning.
uncore you also need to watch as on air the CPUs don't love over 4.7ghz, you can use Ring voltage to help it and CPU stabilization seems to help too.
Nice review steve, looks like a great board for the price.
MB Reviewer for HWC
Team OCX Bench Team
Is Gigabyte's solution a fix for the C1 problem? Does it work in reality? If so, I won't wait for the C2 boards.It is a very sexy board, not so many 3rd party controllers at all, except for the USB 3.0 hubs and a PCI-E to PCI bridge there are no more un-needed ICs. USB 3.0 hub actually is a pretty good thing in the case of Intel USB 3.0(as that sleep problem doesn't apply with a hub because the hub can still poll after waking!).
Hi Sin I was wondering if you will be doing a review on the Z87X-UD4H this one seems to hav 16phase VRM design 8 sata ports also pretty nice cash back deal going on. Also on z87 have GB sorted out the bios niggles. E.G boot loops... also I see now there is a dual bios switch which disables dual bios.. Has this made a difference on stability? On my UP5TH ive had it running 4.8GHz for good few months, today I tried upping the voltage and multi to 50X everything booted then upon checking cpuz my cpu still running 4.8GHz (seems its locked with backup bios settings) wanted your take on the VRMs on UD4H.
Corsair carbide 400R case
Corsair AX-750W PSU
Gigabyte Z77X-UP5 TH (F13a)
Gigabyte GTX 680 OC WF3X
Intel i7 2600K @ 4.8GHz Antec Kuhler 620
Gskill Ripjaw 16GB DDR3 2133 (10 11 10 28 1T) 1.62v
Samsung 840 Pro 256GB Win 8 X64
Samsung F4 2TB
Seagate ST3000DM001 3TB
Pioneer 216BK DVDRW
Liteon iHas 324 DVDRW
yea sure I can, I have all the boards just let me know which ones you want reviews done on.
yea sure I can, the disable switch is really great at taking down any type of OC recovery time. Yea I haven't see anyone complain about a boot loop or anything, maybe here you don't see anyone with GBT boards, but go over to other forums with people who actually own GBT boards and check out some of my help threads there.
I know exactly why you had a ton of trouble, your issue should be fixed in the next BIOS release, especially if you were setting all your timings manually. You should have just left more things on auto and changed like tRRSR for the 3rds just if you needed too. But never the less it wasn't an issue with the board or BIOS, but rather a bug that was really making it hard to manually set things correct.
And C2 is supposed to fix this? Ya sure Intel isn't just going to let Microsoft fix it? lol Check windows 8 downloads under the GBT download site, a bunch of USB 3.0 hotfixes that should solve the issues. Also as far as I can tell my USB 3.0 devices work, but the issue is isolated to only a few USB 3.0 devices, so i am not sure if I have one that would have the issue. A lot of the USb 3.0 issues i see are not related to sleep but rather in general to Intel's USb 3.0 support being a bit off.
Not bad even if they charged a lot more. Just needs a few bugs to be taken out that weren't early enough. For instance since launch they have fixed:
Freezing in the UEFI(while trying to take screenshots or set settings after a while) = Fixed
Uncore not changing over Turbo multi(39x for Uncore) = Fixed
Memory not working Cas6 under the cold= fixed
BCLK upto 200mhz on air = fixed (well you only need F5Q and to set voltages a special way depending on the CPU)
VOltage control to the max supported= Maybe will be added
F5q is the latest and the next release should be even better. THis board is designed to compete against the M6E(and I guess i need to mention OCF on this forum), nothing less.
Fact is that Gigabyte with socket 2011, and 1155 was a fail, it was on a descendent path, on Z87 it's a little better but still after Asus>Asrock
And i'm not comparig with Asus but with Asrock.
Asrock don't have the Gigabyte resources, with 1 overclocker( not 20)- a good team for bios, the OCF series mb's have better performance than Gigabyte.
Msi only save Gigabyte from 4th place.
I remember good old times on socket 1366 with X58-OC,1156 with P55-UD6 these are what Gigabyte is and should be.
Then was on top.
Now it's clear it's not.
i5 2500K@ 4.5Ghz
Asrock P67 PRO3
P55 PRO & i5 750
http://valid.canardpc.com/show_oc.php?id=966385
239 BCKL validation on cold air
http://valid.canardpc.com/show_oc.php?id=966536
Almost 5hgz , air.
Just a foot note. As rock sent out 15 samples. The 5 boards I got dont count (kidding!)
I got a oc sample from din bro who I totally give props to. He's working hard on fixing older ic's on the board. Seems for now we are stuck at lowering cache speeds to make things pass which is mad slow in 32m but I doubt it matters for other benchmarks. Why use the resources on one bench.
15 samples to this forum alone, right? Because I have been counting the number of samples sent out, and its way more than 15. Go asrock's front for samples: fittec corporation, i love how the samples ship from there, even with Z77 OC Formula.
maybe he just don't give you the latest BIOSes lol Also i think it has been a while since you tested the board, unless you just let john touch it. as far as memory goes for older kits, there is a reason there might be issues b/c you are setting all the timings manually on the 3rds, don't do that, not yet.
This is a GIGABYTE Z87X-OC Review with 4770K, lets keep this thread about the review and board.
Anymore of the bashing that was happening in this thread will result in a vacation with no further warnings.
