You can't get more voltage out of reference cards unfortunately.
Have had good luck w/ my Classified so far. Heaven and Valley can run @ 1320MHz/3700. Can fold @ 1241MHz, which is 200MHz higher than my reference cards. The bad thing is the stock cooling is insufficient. Even @ 1241MHz it is pushing 82C. Will be put on water the second blocks are available.
Seems like my 780 lightning hates me.
Intel Core i7 2600K @ 4.60GHz 1.42v
ASUS Maximus IV Extreme w/ 3604 BIOS
MSI N780GTX Lightning @ 1254/6502 w/ 331.40 BETA
2x4GB G.Skill Ripjaws-X F3-12800CL7D-8GBXH @ 1600MHz 7-8-7-24-1T 1.6v
Corsair AX1200 1200W
Samsung 840 PRO 256GB SATA III (OS)
Corsair Force GT 120GB SATA III (GAMES)
Creative Sound Blaster Z w/ Corsair Vengeance 1300 Headphones
Max Keyboard Durandal G1NL Red Backlit Mechanical Keyboard
SteelSeries Sensei Fnatic Edition w/ Razer Goliathus Speed Edition (Large)
ASUS VG278H
Windows 8 Professional 64-bit
Corsair Obsidian 800D
EK Supreme HF Acetal/Nickel + XSPC RX240 w/ 2x GentleTyphoon AP-15 + XSPC X2O 750 Reservoir/Pump + PrimoChill PrimoFlex PRO LRT Tubing 1/2" ID, 3/4" OD + XSPC
1/2" ID, 3/4" OD Compression Fittings
What kind of voltage were you using for 1.4GHz?
Just got my GIGABYTE GTX 780 and I think im in love, this thing runs great and is hella fast ( only using a 1080p display ), would you say that crysis 3 is a good way to test my OC stability, if its good in crysis it should be good in everything else ?
At the moment it seems i cant go much higher on the stock bios, need to find a better bios to increase power target and add more voltage to it, the card is sitting @ 1.2v atm.
Here are a few tests i ran:
Firestrike 10133 on 4770K @ 4.5 + Gigabyte GTX 780 @ 1200/7400
3Dmark2011 14374 on 4770K @ 4.5 + Gigabyte GTX 780 @ 1200/7500
3DmarkVantage 45874 on 4770K @ 4.5 + Gigabyte GTX780 @ 1200/7500
I tried running a couple of benches with my 2 780 cards... but it seems fps will NOT go above 200 fps... not in games, not in Unigine Heaven 4.0 (even with 1280x720 low quality settings) and not even in 3dmark03... wtf is going on.
I tried Nvidia Inspector, frame rate limiter is off... did nvidia hardlock the fps limit to 200 fps or something?
It's not the cpu... that's a 3930K @ 5GHz @ 1.40v (yes it's stable, I got a really good one)
Running Windows 8 64 bit by the way...
lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
*phone rings*
Friend: Do you have a spare PSU lying around?
Me: No why?
Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
Me: what PSU was that again?
Friend: Antec 480w
Me:........
Look at the GPU usage during games or benchmarks. If it isn't at 99% you are likely CPU bottlenecking. The lower the resolution, the more more depending a game / benchmark is on the CPU. I ditched one of my GTX780s because I was almost always CPU bottlenecking on the games I played.
Any of you guys know where could i get a Bios for my Gigabyte GTX 780 that would allow for higher power target and more voltage ? Since even on the 100% fan setting I cannot bench with much more then 1200/7400 @ 1.2v.
One option is the techinferno bios but that only allows for 1.215v also during the benches the card shows 100.1% TDP max power usage.
You don't need a new bios. You can get up to 1.325V with afterburner.
http://www.overclock.net/t/1393791/o...s-club/7880_20
Details are in first post.
Thank You for the link, also what the hell are you cooling the card with ? 1372 on the core is crazy good o_o
Real nice set up splave and damn lowfat holy crap that is fantastic for a ref board don't get too greedy though
What I have been up to was playing with my 780 classy first one made funny noises on first boot then 1 week later it gave up the ghost...new one goes 1400+ with h70 cooling and 1.4v with just software.
This was the best I could do for FSX around 1430 1.41 or so.
http://www.3dmark.com/fs/944561
Now its giving me arti's with any overclock....I will check my vrm/ram heat sinks but temps are good and lots of airflow over those areas front and back.
_________________
I have no idea whats the deal, but when i run the tomb raider benchmark it flickers and craps out a lot quicker then in any other benchmark or game.
My Lightning can pass at 1360 with 1.245v (factory AB limit) so I think I have a bit left in it.
Bencher/Gamer(1) 4930K - Asus R4E - 2x R9 290x - G.skill Pi 2200c7 or Team 2400LV 4x4GB - EK Supreme HF - SR1-420 - Qnix 2560x1440
Netbox AMD 5600K - Gigabyte mitx - Aten DVI/USB/120Hz KVM
PB 1xTitan=16453(3D11), 1xGTX680=13343(3D11), 1x GTX580=8733(3D11)38000(3D06) 1x7970=12059(3D11)40000(vantage)395k(AM3) Folding for team 24
AUSTRALIAN DRAG RACING http://www.youtube.com/watch?v=OFsbfEIy3Yw
Cheating on your titan aussie
_________________
Ok, something i noticed on my GTX 780, i get better overclocks with lower voltage, also my voltage is stuck at 1.187 no matter which bios i try, even with my own version bios which is the .37 the voltage wont go past 1.187, i have my max oc at +550 memory and +106 gpu which gives me a final clock value of 1176 with 1.167 voltage. My asic quality is 77%. I think my voltage is locked hardware wise and not bios controlled. Anyone have any input?
Intel Core i7 4770K @ 4.6ghz| Corsair H100i | MSI Z87-GD65 Gaming Edition | 16GB Corsair Vengeance @ 2.4GHZ | eVGA GTX 780 | Creative Sound Blaster ZxR | Samsung 500GB SSD/4TB Storage | LG 14X BLu-Ray Burner | Corsair HX1050 | Corsair Air 540 | Asus VG248QE 144HZ Monitor
i'm assuming it's a temp issue. @helixpc
mobo: strix b350f
gpu: rx580 1366/2000
cpu: ryzen 1700 @ 3.8ghz
ram: 32 gb gskill 2400 @ 3000
psu: coarsair 1kw
hdd's: samsung 500gb ssd 1tb & 3tb hdd
