Mine doesn't default to 640x480? That doesn't seem right... and that's like 90% cpu anyways.
My post had both P and E 3D11 presets as well. Don't get why more people don't use extreme. 720p is so 2001
Feedanator 7.0
CASE:R5|PSU:850G2|CPU:i7 6850K|MB:x99 Ultra|RAM:8x4 2666|GPU:980TI|SSD:BPX256/Evo500|SOUND:2i4/HS8
LCD:XB271HU|OS:Win10|INPUT:G900/K70 |HS/F:H115i
Sorry man its true i posted wrong cauz i did a bench and let a small window to load my CPU im using C states and EIST and he saves last setting
this where my settings
http://i.imgur.com/H8ffk4o.jpg
Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
ASRock X299 OC Formula
ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
1x Intel Optane SSD 905P 480GB
4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
SilverStone ST1500W-TI TITANIUM
Alphacool Custom Water Cooling
Here you go. Cpu is at 4500
http://img708.imageshack.us/img708/3...04500780s1.jpg
Feedanator 7.0
ooh 780 fun!
seems like the highest mem i saw in this thread is 1830mhz, shouldnt the 780 be a better mem clocker than titan? cause of 3gb vs 6gb. if it can go 100mhz more in memory than titan it might catch up to it
andressergio: Will you buy GTX780 ? I am thinking about buying.
Intel Core i5 3570k 4.4GHz | Noctua NH-D14 | MSI Z77A-GD55 | Gigabyte GV-N1070G1 GAMING-8GD | Crucial Ballistix Tactical LP 4x4GB DDR3 1600MHz CL8-8-8-24 1,35V | X-Fi Titanium Fatal1ty Pro | EVGA SuperNOVA 750 G2 | 26" LCD SAMSUNG T260 | ColerMaster HAF X | Windows 10 Home Premium 64-bit CZ | > My new PC http://www.youtube.com/watch?v=V3iSpTVMhLA
I7 4770k @ 4.4ghz ( 24/7 clocks )
Zotac GTX 780 @ 1215/1749
ICE STORM : 178605
http://www.3dmark.com/is/597921
CLOUD GATE : 28572
http://www.3dmark.com/cg/534111
FIRE STRIKE : 10037
http://www.3dmark.com/fs/568253
3Dmark 11 : P14330
I7 4770k @ 4.6ghz
Zotac GTX 780 @ 1215/1755
http://www.3dmark.com/3dm11/6751430
No bios mod on the GPU, this is about the max i can do, it sometimes crash at just 5-10mhz higher.
BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
Those results are really tempting, i was thinking of buying two 780s, but i think i will keep my 670s since i can max all the games at 1600.
Gaming rig;
ASUS RAMPAGE IV BLACK EDITION
I7-4390K
G.SKILL Trident X 16GB 2400
Intel 530 240GB
2x Asus GTX780
Corsair AX1200
HP ZR30w 30
Win 8.1 pro
Sound rig;
Auzen X-Fi H.T. HD --> Yulong D100 MKII --> D-7100
I run a surround 5760x1080 on this single 780 and i really dont feel the need of a second one. I had a 670 before and the 2gb VRAM was to most limiting factor for BF3, with ULTRA settings and 2xMSAA you end up using more than 2gb, 2.2gb to put it right.
Accordingly i stay GTX680, difference 680 vs. 780 is small. Worth it to change cards
I've been having a Crysis marathon here and found something interesting stability wise. I've been at +125 offset since I've had these 780s and so far haven't' had any driver crashes or BSODs. I got through both Crysis, Warhead and Crysis 2 without issue. Crysis 3 on the other hand... 5 or 10 minutes, boom, BSOD. Take the cards back to stock and I am able to play sans issue. Oddly I can loop maxed out Heaven and 3DM11 for hours. With my fan profile they've never broke 70C either and at that Crysis 1 seems to generate higher heat load than 3. And to add fuel to the "Can it Run Crysis" meme, even SLI 780s crap then bed in the later levels, I saw single digit frame rates (2560x1440 ; Extreme; 4xAA/16xAF) during the final boss battle when there were multiple Ceph firing their ice beams at you haha... That carrier is quite the light show!
That said, Crysis 3 would be my recommended stability test so far after playing dozens of games released in the last 2 years. ( unless you run distributed computing, in when case that probably takes the cake )
Feedanator 7.0
Looks like asus gets my money agian for first custom 780 pbc to market
http://www.newegg.com/Product/Produc...82E16814121779
If i get any mod info or if anyone else does please post it up.
_________________
EVGA GTX 780 CLASSIFIED and voltage tuning - http://kingpincooling.com/forum/show...5716#post25716
first stroll on the dcII
stock 3d voltage 1.187 with the +37 1.23v
did not even start with anything yet
http://imageshack.us/photo/my-images/35/9l15.jpg/
not sure if i will mount the h70 on it today but thats first
then i have to bust off a resister and bridge a pad
power sence has to be done also then i will hang a vr for gpuv
bios might be issue hopefully the pl mods will take care of it
i might install gputweak to see if it will allow more voltage then ab.
Yuppers its same as 680 dcii mod wise
h70's on too
nasy throttle atm since i forgot to do power sence mod but i'll be back
_________________
Running into ovp/ocp 1.40v+
Runs ok for core temps vrm are good too
BF3 is ok to about 1267 1.31v
Driver crashing is sucky and is pmo but all ok sofar
it should go decent baby clocks of 1340ish just dice at low volts of ovp but i test alittle bit more with it later.
Using a bios i found for power limit, its ok for that
_________________
I got my ASUS GTX 780 DCII OC a couple of days ago, and so far it seems to be a decent chip. Currently running it at boost 1267 @ 1.150V (+220MHz) stable. The memory however doesn't like overclocking at all, even with the core at stock. I can push it to about 1625MHz (6500) stable. I know that plenty of people consider the ASIC value in GPU-Z to be bogus, but I included it anyway.
Still haven't decided whether I should try a modded BIOS or not, I am still running on air.
That looks great for a stock card,I would just try low volts and cool temps on that one
As for the bios its really not bad the stock one,if you are going no further then a o/c once in a while i would see no reason too.
IF you want more clocks you will need one for pt
_________________
I am happy with it, the clocks are good and temps are low.
However, there's always that little question in the back of the head "but how far can I push it under these conditions, just because I want to find out?", heh.
Forgive my ignorance, but what do you mean by pt?
Got any detailed suggestions regarding the BIOS? TI?
I just got my 780s and i am a little lost on the whole vbios and llc thing. I have 37 bios, zotac 780s. What i did was try out the llc tweak and the values returnd 00 meaning its now enabled. But i am still at 1.200v max. I am not sure what to do next to verify if its working and i am interested in getting a higher usable voltage. Can anyone guide me how??
