Results 1 to 16 of 16
Thread: Any issues with covering a water block in vinyl
    Sep 2010
    Calgary, Alberta
    Hey guys. I am in the middle of a mod and am thinking about covering my copper waterblocks with vinyl as it does not really match my color scheme. I am a little concerned about trapping heat inside when I cover with the vinyl though. Does anyone have any experience with that? I want to make sure that I am not trapping any unnecessary heat in there.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    The water is was takes the heat away, so no I wouldn't be concerned about trapping heat. Just don't put vinyl between the block and the GPU itself
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Banned
    Oct 2012
    Vinyl most definitely will trap heat that is normally taken away via air. How much is difficult to predict other than checking the CPU/GPU temps before and after. You might be able to use spray paint which would be better than vinyl as far as the heat retention issue.
    Mar 2006
    Ohio, USA
    Quote Originally Posted by AMDforME View Post
    It's a waterblock, not an air cooler, so the vinyl should make little difference.
    Dec 2007
    Earth
    ^^ This.
    The vinyl will not effect the performance of the block in any (noticeable) way.
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
    Banned
    Oct 2012
    Quote Originally Posted by Sparky View Post
    The waterblock absorbs some of the heat from the water which is then absorbed by the air. 100% of the heat pulled from the CPU does not go to the rad. That's why covering the waterblock is not advisable because the thermal efficiency of the waterblock drops and the CPU temp will increase unless the radiator and fan can deal with the added thermal load.
    It's very similar to an automotive engine block that gets hot from the coolant that is being pumped to the radiator. Painting an engine block actually increases the water temp slightly. If you were to wrap the engine block in vinyl or other insulating material the water temp would increase even further and add thermal load to the radiator and fan.
    Feb 2005
    Charlotte, NC
    It is a hypothesis that is worth testing.
    It is for the same reason that the high side of a refrigeration system is not insulated. The only time a condenser, discharge line, or compressor are insulated is if sound is a major issue; and we're talking industrial water chillers with screw compressors.... So as it applies to water cooling, the block indeed does absorb and in turn radiate some heat.
    Wrapping it in vinyl may have an effect. The see how it affects the water temp, I would like to see some temps. Otherwise, just saying that it won't be a problem is thin air. You may be correct that the effect is negligible...
    So in conclusion. Wrap 'er up and see what happens.
    Regards, Stew.....
    - This message brought to you by Frank Lee E. Snutz
    Mar 2006
    Ohio, USA
    Like I said, LITTLE difference. You're right, 100% of the heat load doesn't go to the radiator, but a good 99+% of it does. I'm looking at my waterblock and cannot see how just that thin bit of metal on the edges that is open to the air is going to make any sort of real difference at all.
    If that 0.1 degrees C makes or breaks your loop, your loop sucks
    Jul 2011
    Kaiserslautern, GE
    some paints actually radiate better than bare metal alone (that's why most home radiators - for warming via hot water - are painted). i don't think it matters one way or the other though. any temp differences will (as was said before) not be noticeable - even with a full metal block.
    i7 3930@4.5GHz (EK Supreme HF), GTX690@1.2GHz (Koolance NX-690), 128G 4M + 2x128G 4M raid 0, Silverstone TJ07, Custom Enclosure w/MoRa, 18x GT AP-31, 401X2 dual PMP-400
    Dec 2008
    Clearly you should add colored heatsinks to the top of your blocks so you get the color you want and then you can cool the block down better rofl.
    Post some pics up though b/c I have never heard of anyone else doing this and it will be very interesting to see how it looks when your done.
    Apr 2011
    North Queensland Australia
    I'm doing my 780s with wood grain vinyls, should be fun
    -PB
    -Project Sakura-
    Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
    2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
    Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
    Banned
    Oct 2012
    No actually 99% doesn't go to the water which is why I and Stewie007 both indicated that the only means to know how much the vinyl will affect the CPU/GPU temp is to actually test it.
    The issue isn't just the small bit of exposed metal on the edges. The entire water-block absorbs heat some of which is removed by water and some removed via convection and radiation. It also has nothing to do with making or breaking the loop. It has to do with the CPU/GPU operating at a higher temp - which is what the OP was rightly concerned about.
    The water-block can only pull a specific quantity of heat from the CPU/GPU. The hotter the water-block physically operates at, the hotter the CPU/GPU operates at. To change this thermal relationship you need to increase cooling of the water-block(s) when you effective insulate the water-block(s) with vinyl or any other material.
    bds71-
    As far as paint yes some paints do radiate better and some hold heat better. Either is better than a vinyl wrap as far as CPU/GPU temp is concerned. That's why I suggested paint as a possible alternative depending on what look the OP desires.
    Jul 2007
    Canada
    There have been tests done in the past between regular and premium versions of waterblocks where the regular had a delrin/acrylic top, and the premium had a copper top, and the difference was basically moot. If there was heat to be shed through this method, we'd likely be seeing options for waterblock tops actually cut like heatsinks.
    Secondly, heat enters the waterblock at the base, where the heat source is. In order to exit into the surrounding air, it must conduct all the way to the edge of the base, then up the sides, then into the top. This whole time, it will be rapidly conducting heat into the moving water. Under those circumstances (assuming decent flowrates), the odds of the top of the waterblock being even one degree warmer than the loop water are fairly slim. The simple fact that waterblock tops don't get warm in a proper loop is a pretty big hint here.
    Thirdly, you still won't get any cooling unless the air around the nearby air is cooler than the block. And in a watercooling system, you could very well be contending with the heat coming off power circuits, drives or pumps. Or you might be getting tons of warm exhaust air from your radiators (since you were feeding them cool outside air, right?), which renders the entire question moot.
    Go ahead and coat the top of the block.
    i7 2600K | ASUS Maximus IV GENE-Z | GTX Titan | Corsair DDR3-2133
    Feb 2005
    Charlotte, NC
    Quote Originally Posted by bds71 View Post
    Really..... So by introducing a barrier between air and the metal fins in a radiator heat transfer would be improved?
    I'm gonna go paint my air conditioner coil! That will surely improve performance.
    All kidding aside (don't be offended, I'm just teasing), the coatings on air coils are not for performance. If you see a condenser coil or radiator coil with black lacquer coating it, that is to prevent corrosion due to salinity. Paint is not going to help the transfer of heat between the metal and the air. It will impede it if anything... Generally, its such a thin coating that its largely irrelevant and heat is transferred without hindrance.
    I don't know if you're talking about those radiators that are in old houses.... But unless the paint is reducing and carrying away heat with it, there is no assistance in heat transfer. Bare metal will radiate heat better than painted metal (if you can even really measure it reliably).
    Regards, Stew.....
    Xtreme Mentor
    Oct 2007
    USA
    Quote Originally Posted by Stewie007 View Post
    Agreed 100%. It's for looks and in an industrial/car use, it's also for corrosion. I would like to see that posters proof that it helps. Maybe there is such things in space etc, but normal earthbound use? Naaa..
    The OP could be talking about steam radiators made from cast iron back in the 30's?
    Ohh, let me PM Howard Waskowitz, he would know.......... Crap, gotta wait till next season.......
    All stock for now, no need for more, but it's gonna be soon methinks.
    Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
    SLI GTX470 EVGA
    EK HF nickle blue top CPU block (free from Eddie)
    Koolance 470 waterblocks
    One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
    Banchetto Tech Station
    120 GB SSD, and a few other drives.
    1000W UltraX3 PSU, 900 watt (1500VA UPS
    23.999" Acer GD235hz and 24" Acer H243H
    Jul 2011
    Kaiserslautern, GE
    i was referring to emissivity (if that applies correctly in this instance) - from wikipedia: "The emissivity of a material (usually written ε or e) is the relative ability of its surface to emit energy by radiation." this is how heat is radiated to the surrounding area - and has less to do with heat conductivity of air (which is quite low) than you might think - and can, in some cases, be aided by paint. ever notice how most radiators are powder coated or painted? perhaps this is why? (might not be /shrug). anyway, that is the reason i made that statement
