Results 1 to 4 of 4
Thread: Collatz Conjecture help please
    Feb 2013
    Middle Earth
    I tried to do some GPU crunching at Collatz Conjecture, but their GPU WUs erred as soon as they were downloaded. I have AMD Radeon HD 7700 GPUs with the latest driver.
    I tried to post this question on their message board, but you need to crunch points before they will allow you to post which is a little dumb. How do I crunch, if I can't post, because I can't crunch?
    So, I have to fall back and hope someone here has my answer. What I'm doing wrong? Is there some additional GPU software I need to do Collatz Conjecture GPU crunching or are my GPUs just not expensive enough for Collatz Conjecture WUs?
    Gandalf
    "I refuse to answer that question on the grounds that I don't know the answer" [Douglas Adams (11 March 1952 - 11 May 2001)]
    Xtreme Cruncher
    Mar 2009
    kingston.ma
    What is the error messaging look like?
    You may not be able to run your GPU as high on Collatz as you were WCG.HCC
    Also sounds like there is an issue syncing CPU and GPU portions of the app results, and there is a suggestion that the latest version of BOINC is doing better syncing these pieces.
    Feb 2013
    Middle Earth
    Quote Originally Posted by Snow Crash View Post
    When the error occur, I adjusted the app_config file to 1.0C + 1.0ATI and it still erred right off the mark. I'll have to make another attempt at running the program, since I Removed it from the Manager because it wouldn't run. I'll have to get back to you about what the error looked like...
    Feb 2013
    Middle Earth
    Here is the error from the Event log. There was not app_config.xml file...
    5/4/2013 6:21:42 PM | Collatz Conjecture | Starting task solo_collatz_2379386804286473873768_824633720832_0 using solo_collatz version 405 (opencl_ati_100) in slot 7
    5/4/2013 6:21:44 PM | Collatz Conjecture | Computation for task solo_collatz_2379386804286473873768_824633720832_0 finished
    5/4/2013 6:21:44 PM | Collatz Conjecture | Output file solo_collatz_2379386804286473873768_824633720832_0 _0 for task solo_collatz_2379386804286473873768_824633720832_0 absent
    I've unchecked the solo_collatz project. That should stop the errors.
