Results 1 to 12 of 12
Thread: QX9770 vs I7 920
    Hamster Powered
    Apr 2006
    Virginia, USA [Krunching since 2001]
    QX9770 vs I7 920
    How much of an upgrade will the I7 920 be over the QX9770?
    Thanks,
    SiG
    XSWCG Disclaimer:
    We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
    Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
    Hamster Powered
    Apr 2006
    No one has any ideas?
    XSWCG Disclaimer:
    Xtreme Cruncher
    Jan 2009
    The Hague, Netherlands
    Upgrade for what? What are you going to do with it and what does it cost to "upgrade"?
    It has been a long time since I looked at the differences between these chips, but at stock there is not that huge of a difference I believe: http://www.anandtech.com/bench/Product/48?vs=47
    The i7 will probably overclock better though and is much better for programs that can use many threads.
    Overall the i7 is better, but I personally would not spend money to go from a qx9770 to i7 920 unless it is for number crunching or rendering etc and even then I would much rather spend the money on upgrading to ivy bridge or AMD FX8350 if Intel is too expensive for you. If the i7 is free though, go for it because overclocked it is significantly better than C2Q.
    3770K 4.7Ghz 1.32v / ASUS P8Z77-V PRO / 8GB DDR3 1866 9-9-9-27 /ASUS HD7970 1025MHz / Antec NeoHE 550 / Samsung 830 256GB Crunching
    Cooled by PA120.3, EK-HF, D-tek Fuzion GFX, DDC3.1 XSPC res/top
    i5 2400 Stock / ASUS P8P67 LE / 4GB DDR3 1600 / Seasonic S12II 430W / Intel G2 40GB Crunching
    2600K 4.6Ghz 1.34v / ASUS P8Z68-V PRO / 8GB DDR3 1600 8-8-8-24 / Antec 430W / Intel G2 80GB Crunching
    W3520 4.0Ghz 1.19v / Rampage II Gene / 6GB Kinston Value 1333 / 9800GT / Corsair TX650 / Antec mini P180 / Intel G2 160GB Crunching
    Intel G860 Stock / Gigabyte H67MA-UD2H-B3 / 4GB DDR3 1333 / Antec Earthwatts green 380W / Crucial M4 64GB Crunching
    E6600 3.2Ghz 1.36v - P5B Deluxe / i7 930 4.0Ghz 1.29v - ASUS P6X58D-E / Q9450 3.6Ghz 1.28v - Rampage Formula Retired
    Hamster Powered
    Apr 2006
    Thank you for your reply. I have both chips and the i7 is on a Gigabyte MB and the QX9770 is on an Asus Maximus Formula. Both are water cooled setups. I am upgrading my vid card and want to do a little gaming.
    XSWCG Disclaimer:
    Xtreme Cruncher
    Jan 2009
    For gaming, I think it is going to depend on how well your chips overclock which chip is better. If I remember correctly, the i7 was better in almost anything except for gaming. Like you see in the anandtech benches, they are performing very similar for gaming.
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    For gaming stick the card on the one that runs the fastest speed.
    All the other factors are so close as to not be worth while.
    Good luck pal!
    PS: If you don't have one buy a good SSD
    That will be the biggest change you've seen in years!
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Hamster Powered
    Apr 2006
    Quote Originally Posted by Movieman View Post
    Good luck pal!
    Thank you sir. Both chips will do 4ghz, but I run the QX9770 (which will do 4.18) @ 3.8 for daily use.
    XSWCG Disclaimer:
    Aug 2005
    Austin, Texas
    Run some simple superpi's and 3dMark's and see what is faster.
    7820X | Asrock X299 Taichi XE | Gigabyte 1080 Ti Xtreme | 32GB Memoriez | Corsair HXi1000 | 500GB 960 Evo
    Feb 2009
    IRAN
    Switch TO IvyBrigde Or Sandy Brigde .
    PERSIAN GULF
    Apr 2007
    Norway
    I say, if you dont need 2 pc's sell one and get a good graphic card for the one you use.. Both cpus have way more than enough power to take any game now.. But I think I whould use the i7 920.. they perform a little better, and has tri channel ram that allows 6/12gb instead of 4/8gb on the 775 setup.
    In any case, I whould not see the need to upgrade cpu to sandybridge or ivy, because the difference is not alot, and you dont need more cpu power for gaming and normal use in probably years =)
    Jan 2007
    Argentina
    The i7 920 is definitely better. Look at the link Conquistador posted. They both have nearly the same performance, while the QX9770 is clocked 23% higher. I don't remember how far the 920 clocks on average, but it should hit 4.0/4.2Ghz easily, and I doubt the QX9770 can match it at that speed.
    It's a newer platform also. Both are EOL, but if you don't change your entire computer too often you could even swap it for a 970.
    Main: Windows 10 Core i7 5820K @ 4500Mhz, Corsair H100i, 32GB DDR4-2800, eVGA GTX980 Ti, Kingston SSDNow 240GB, Crucial C300 64GB Cache + WD 1.5TB Green, Asus X99-A/USB3.1
    ESXi Server 6.5 Xeon E5 2670, 64GB DDR3-1600, 1TB, Intel DX79SR, 4xIntel 1Gbps
    ESXi Server 6.0 Xeon E5 2650L v3, 64GB DDR4-2400, 1TB, Asrock X99 Xtreme4, 4xIntel 1Gbps
    FreeNAS 9.10 x64 Xeon X3430 , 32GB DDR3-1600, 3x(3x1TB) WD Blue, Intel S3420GPRX, 4xIntel 1Gbps
    Dec 2007
    Texas
    umm use the i7 and sell the qx9770 on ebay, you can get at least $300 for the cpu alone.
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
