I am currently run a high FPI rad (GTX 360) with three high rpm 120x120x38mm fan
please help me choose new rad & new fan
for a lower noise (not limit to single 360 Rad.)
and give me the same performance
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
You need more rad area to compensate.
A 360 gtx rad with 2200 rpm fans dissipate 300 watts
In the latest martin roundup, the Alphacool NexXxoS ST30 (thin rad) is the best for very low rpm fans
Alphacool NexXxoS ST30 with 600 rpm fans (absolutly silent) dissipate 75 watts.
With 1400 rpm fans others rads dissipate 200 watts
It depends the noise level you want
Personally, i have a 360 and 480 with very low rpm fans and it is absolutly silent. With my aquaero, i can automatically
stop the 480 rads fans when water temperature - ambient is low (almost all the time when i don't play games).
Bought the Phobya G-Changer NOVA 1080 60mm copper rad. Quiet as hell and the performance is awesome. Here is a pic..
I have 9X 120mm San Ace fans in there on 5v. Very quiet. The rad always keeps the water within 2 degrees of ambient. Did I mention that it is also ALL COPPER?! I love the GTX series performance rads. Got a few myself and heck have some in some YouTube vids with crazy San Ace performance fans making them hover. However this new rad really turned my crank for performance and quietness. It is easy to install on any side of the case if you have the appropriate bolts.
