Hello guyz,
Since 1 month I got a 7970 Dual-X card but it seems that software voltage changing doesn't work very well.
I use MSI AB but also TriXX and the result seems the same. When I change the voltage in AB (1.3v for example) and then I look in GPU-Z, I see 1.18v during high loads.
I have tried different BIOS but the problem is still there. (I use HIS 1180/1500 BIOS right now)
When I force constant voltage, that's a little better but GPU-Z reports low value too, something like 1.21-1.23v
Is my card voltage locked ? Somebody has an idea where the voltage reading points are on this card ?
And, yeah, the card coil-whine like a b*tch but it's another problem
