Results 1 to 21 of 21
Thread: The Power of Titan!!!
    Champion
    Feb 2007
    Hi, friends of KPC.
    The reason we are doing this thread is to tell you about our "Titan's" experience, and also to alert the extreme overclockers to take care with the fragile Titan's PWM.
    First of all, we tested the videocard in the air, and we were not happy to know the card coud not surpass 1175 Mhz / 1700 Mhz.
    The videocard is a gift from Zotac Miami (very thanks to Zotac)... and since the videocard cost is about USD 2000 (or more) in Brazil, we noticed will be impossible to play SLI... and sure... 3 or 4 way.
    Regardless all.... we decided to try to get the max of the card.
    Phase 1 - Hardmodding
    We did try the hardmodding (VGPU, VRAM and VPLL... also OCP and Thermal Shutdown)...
    I often liked to make a control panel, to have easier acess to the trimpot and also measure points.
    Looks like a functional and nice hardmod...
    Bad surprise
    After we run 1345 Mhz... and get more than 18K on 3Dmark11, we (me and Schenckel) decided to put a lit bit more voltage... since we were under LN2...
    So... suddenly, after 10 minutes benching and only about 10 seconds after start 3DMark11... videocard was death.
    We measure the resistence and noticed the card was shorted.
    OMG... to lose a VERY EXPENSIVE videocard in only a few minutes, was really a bad thing... but after to test the components, we could know that only one phase was death.
    Still had a hope
    Later that nigh in Brazil..... I see in the morning in Taiwan, ... TiN gave us a great help, and informed PWRGD point to cut... so, we could enable the Zoombie.
    We started to hardmod again the card about 1:00 AM... and finally finished and tested the card about 6:00 AM... really tired out...
    After to test and check it was working... its time to sleep 3 or 4 hours to finally try the Titan.
    That's the result:
    http://img845.imageshack.us/img845/9...83hdtv1080.jpg
    And that's the scores we got
    We know nothing compares with a magic hardmods done by TiN and Shammy... but we were happy that we made.
    Unfortunately, LN2 is too expensive and we could not afford lots of LN2...
    This is all we got with about 35 Lits...
    Titan is a ferocious consumer of nitrogen... but bring us a lot of fun...
    Best wishes from Brazil
    Dec 2012
    Buenos Aires
    Impressive scores!
    Handling that zombie looks like a PITA man...major props.
    Cheers from Argentina
    Mar 2007
    Buenos Aires,Argentina
    Amazing work my friend example that not surrender....nice nice work!
    hersounds powered by 121 % overclocking Machine http://valid.x86-secret.com/show_oc.php?id=220390 - http://valid.canardpc.com/show_oc.php?id=1917405
    facebook.com/hersounds
    Intel Core i5 4670K @ 4,5 Ghz 24/7 - Galaxy HOF GTX 780 - 8 GB Team Group Xtreem 2666 Cas 11 - 8Gb Avexir Core series 2800 Blue Led - Maximus VI Formula Armor TUF - Corsair Force GT 120 GB SATA 3 - Galaxy Hall of fame 1200 hersounds Limited edition Modular - Antec 620 dual fan mod
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    very nice, I have respect with all this vmods! Nice work!
    ROG Power PCs - Intel and AMD
    Sep 2008
    ROMANIA
    At what voltage did the card died?
    Anyway respect for your hard work but the modding with Evga VRM was a little complicated, may be first it would have been better to try stock VRM because it's not that bad.
    Master poparamiro, 1227/1400 1.328v on air, 3dmark'03, stock VRM, 8C.
    http://www.youtube.com/watch?v=JcHKe...layer_embedded
    It was good that you could revive the card and get some results.
    i5 2500K@ 4.5Ghz
    Asrock P67 PRO3
    P55 PRO & i5 750
    http://valid.canardpc.com/show_oc.php?id=966385
    239 BCKL validation on cold air
    http://valid.canardpc.com/show_oc.php?id=966536
    Almost 5hgz , air.
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    incredible work
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
    Champion
    Feb 2007
    Quote Originally Posted by xdan View Post
    We killed the card in LN2... 1.46V in 10 seconds..... PWM death...
    If I was you, do not go more than 1.38V...maybe 1.4V even with liquid nitrogen.
    To be cold... don't mean it will support more voltage... and also, we consider 1.32 or even 1.46V not enough to a 1000 USD card.
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Great work Ronaldo , i'm glad the card still alive after you guys made Zombie card , awesome volt mods job , nice scores.
    Regards: Angelo
    Jun 2009
    Ukraine, Dnepropetrovsk
    Nice work! Which Vgpu did you use after zombified Titan?
    Forgive for my English because I only learn it
    Champion
    Feb 2007
    Thanks friends
    1.73V full load... almost set 2V to Epower... huge drop regardless all.... -140?C average ... CBB less than 50?C
    Uploaded with ImageShack.us
    Administrator
    Nov 2007
    Stockton, CA
    Nice work Ronaldo, crazy stuff there for sure !
    One-Eyed Killing Machine
    Sep 2006
    Inside a pot
    Like I told you on FB, great work man, great work
    Coding 24/7... Limited forums/PMs time.
    -Justice isn't blind, Justice is ashamed.
    Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
    May 2009
    great work man
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Pie assassin
    Nov 2007
    Where lights collide
    Kill a $1000 card? bring it back to life then torture it some more?
    Ronaldo = Hero
    great scores friend! Digging the soldering work too. does the zombie still live?
    Current Status - Testing & Research
    Jun 2009
    Central Massachusetts, US
    That's nuts, man. Great work.
    2600k @ 4815mhz
    Z68XP-UD4
    Sapphire 6950 (unlocked to 6970 bios, 950/1400)
    Corsair Vengeance 8gb DDR3 1600mhz
    Corsair 850TX
    Corsair Obsidian 800d
    MCR320 . MCP355/XSPC Top . ApogeeXT . Z-Multi rez . EK VGA Supreme HF . Primochill LRT UV blue tubing
    Jul 2008
    Poland
    Kitchen mix OC, amazing job - more like you.
    e6320@3,4GHz/GA-X48-DQ6/2x2GB OCZ Reaper@972/Gigabyte 8800GTS 512MB/F1 320GB Raid0/SB Audigy2/SHS-182D/Chieftec 400W
  18. #18
    xtreme energy
    Oct 2004
    Europe, Latvia
    Now this is rare, some serious hard modding I don't think I have ever seen anything like this on this forum as the stuff in your posted pictures
  19. #19
    I am Xtreme
    Dec 2008
    France
    Great job! Now that's the true spirit of xtreme overclocking!
    Donate to XS forums
  20. #20
    Champion
    Feb 2007
    The card worked great after zoombie;
    I think is the limit of the card... That's a gift from Zotac.
    @ ZenEffect --- you are a great bencher bro... unforgetable Los Angeles session in your home...
    I hope to see you soon... will go to USA, CA, before july.
    Best wishes for all
  21. #21
    Jun 2007
    Finland
    Omg that Titan and its mods..
    GJ
    ::: Desktop's - Intel *** Intel 2
    2 x Xeon E5-2687W *** Intel i7 3930k
    EVGA SR-X *** Asus Rampage IV Extreme
    96Gb (12x8Gb) G.Skill Trident X DDR3-2400MHz 10-12-12-2N *** 32Gb (8x4Gb) G.Skill Trident X DDR3-2666 10-12-12-2N
    3 x Zotac GTX 680 4Gb + EK-FC680 GTX Acetal *** 3 x EVGA GeForce GTX780 + EK Titan XXL Edition waterblocks.
    OCZ RevoDrive 3 x4 960Gb *** 4 x Samsung 840 Pro 512Gb
    Avermedia LiveGamer HD capture card
    Caselabs TX10-D
    14 x 4 TB WD RE4 in RAID10+2Spare
    4 x Corsair AX1200
    ::: Basement DataCenter :::
    [*] Fibreoptic connection from operators core network
    [*] Dell PowerConnect 2848 Ethernet Switch [*] Network Security Devices by Cisco
    [*] Dell EqualLogic PS6500E 96Tb iSCSI SAN (40 2Tb Drives + 8 Spare Drives, Raid10+Spare Configuration, 40Tb fail safe storage)
    [*] Additional SAN machines with FusionIO ioDrive Octal's (4 total Octals).
    [*] 10 x Dual Xeon X5680, 12Gb DDR3, 2x100Gb Vertex 2 Pro Raid1 [*] 4 x Quad Xeon E7-4870, 96Gb DDR3, 2x100Gb Vertex 2 Pro Raid1
    [*] Monster UPS unit incase power grid failure backed up by diesel powered generator.
