Results 1 to 11 of 11
Thread: Thermalright SilverArrow SB-E Extreme
    Xtreme Reviewer
    Apr 2011
    Mar 2008
    Minnesota
    For what it is worth, I use one on a micro-ATX (Maximus V Gene) board with TALL G.Skill Trident X RAM sticks with no clearance issues by moving the fan to the middle and the other as "pull" out the back of my mid-tower Arc Mini.
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    That cooler looks great! Nice pictures and review, thanks for posting!!
    you sigged that?
    why?
    ______
    c[_]
    Nov 2002
    Alberta, Canada
    If you get a chance you should test using Cougar CF-V12HP8 fans.
    Little noisier than the noctua fans at full speed but they move and direct air pretty good and you can slow them down easily, i'm hooked on them
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Dec 2012
    Buenos Aires
    Quote Originally Posted by tool_462 View Post
    I couldn't fit a gtx 670 ftw if I used that orientation on mine...how did you do it? What gpu are you using?
    Mar 2008
    Minnesota
    Quote Originally Posted by Ivanlabrie View Post
    7970 but you have to use the 2nd slot, so limited to 8x but I lost no performance doing so.
    May 2006
    Kawasaki, Japan
    Would there be any drop in performance if I place the fans in pull orientation instead of push orientation? I have Corsair Vengeance RAM, and I would rather not remove the heatsinks if I can get through without doing so.
    Also, I have someone confirm that it fits fine in Raven RV03 case. Is that actually true? Further, would the fan orientation have an impact on this particular case?
    Jun 2006
    The O.C.
    Very nice I bought a used one and will install on my socket 1155 3770k sooner or later.
    Any comments on the thermal paste?
    i7-2600k L041C108 4.8ghz 1.32v PLL off Venomous-X Push/Pull http://www.xtremesystems.org/forums/...postcount=1063
    Asus P8P67 Vanilla
    Samsung 30nm MV-3V4G3D/US 2x4GB @ 9-10-10-28 1T DDR3 2133 1.6v http://www.techpowerup.com/forums/sh...d.php?t=159320
    Diamond HD 7970
    WD 600GB Velociraptor
    Corsair TX750W
    CM 690 II Advanced
    Q822A549 E8500 @ 4.5ghz air TRUE @ http://www.xtremesystems.org/forums/...d.php?t=203762
    G.Skill F3-12800CL6D-4GBXH @ 7-10-8-27 1T DDR3 2133 1.6v http://www.xtremesystems.org/forums/...d.php?t=266839
    Xtreme Reviewer
    Apr 2011
    Quote Originally Posted by LagunaX View Post
    Thermalright CF3 or Noctua NT-H1.
    Apr 2011
    I own this cooler..is there a mb compatibility list? I am looking at getting a z77 board
    Xtreme Reviewer
    Apr 2011
