http://www.extremetech.com/computing...-to-nvidia-amd
If WCG were to integrate AVX/AVX2 instructions in WCG projects... imagine the boost it would give... it would be quite epic.Haswell is a logical extension of the microarchtectural improvements Intel first introduced in Sandy Bridge. The new chip adds support for Intel?s second-generation Advanced Vector eXtensions (AVX2), which doubles the core?s peak FPU throughput. L1 and L2 bandwidth have been doubled to ensure the execution units stay fed, and the integer and FPU register files have all been enlarged. Branch prediction efficiency also gets a boost. Haswell?s real-world single-threaded performance in unoptimized code is expected to improve by 10-15%. In optimized, AVX2 code, the leap will be much larger; AVX2 includes support for integer vectorization that AVX lacks.
The increased FPU capability and additional AVX2 functionality make a huge difference in Haswell?s floating-point performance. The CPU is capable of up to 32 single-precision and 16 double-precision floating point operations per core. That?s twice what Sandy Bridge could achieve; a theoretical eight-core Haswell clocked at 3.8GHz will offer 972.8 gigaflops of SP and 486.4 gigaflops of DP performance.
A 3770k at 4.4 ghz is what... 120 glops max? It would be at least 3-8 times the performance...
BTW this isn't an anti-AMD post... I've only owned AMD GPUs and I'm running two AMD rigs right now... I'm sure AMD will include AVX2 in their next CPUs...
