Currently I have 2 Koolance flow rate sensors in my loop this is largely due to my 2 independent loops being combined temporary while I get a new pump for the other loop.
Previously I posted that I observed different output in flow rates from the 2 sensors. Now I have 1 spinning and the other one not moving!
The one spinning is before the gpu and after the cpu and the one not spinning is after the gpu before the res (at top of the loop).
Clearly the flow does work as one of them is spinning so obviously I will need to remove the bad one. Any suggestions on what to do with it? Should I try an RMA or something?
Also does anyone have any suggestions for a more reliable flow sensor?
Thanks!
