Results 1 to 23 of 23
Thread: I don't think I'll ever upgrade CPU/Motherboard for atleast another ____ years!
    Mar 2010
    Hey guys. I built this system back in '09 for home use.
    GA-X58a-ud7-rev 1
    I7-930 oc'ed to 3.7 on only 1.19735 volts!!
    Noctua DH-14 cooler
    Corsair 750W TX
    Sapphire 5850 Vid
    G-skill triple channel 1600mhz 6gb total
    WD black 640gb
    Seagate 500gb
    Antec 1100 case
    Windows 8 Pro
    Till this day I feel as though this setup is still very good and can't come up with any excuse to upgrade except maybe more RAM and an SSD drive? But hey what do I know
    Do you guys think I should do any upgrade? Look for a better CPU i.e 960, 980 or even 990x better video card?
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    i could see changing your storage and case, you dont need anything else. your graphics card is fine and i would not upgrade till the next gen, your cpu is fine and if you were to upgrade it the hex cores are not cheap even on 1366 so i would do a haswell quad instead as it should be about a SB-e quad clock for clock in overall performance and much faster for games. SSDs are really nice i would start with that.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Aug 2009
    Belgium
    Quote Originally Posted by zanzabar View Post
    Isn't the supposed 'much faster for games' performance of the Haswell CPU only when using the igpu? I didn't see anything about Haswell being a lot fast for games if you're using a graphics card (apart from the fact that haswell might overclock really well)?
    Asus Z87 Deluxe, 4770K,Noctua NH-D14, Crucial 16 GB DDR3-1600, Geforce Titan, ASUS DRW-24B3ST, Crucial M500 960GB, Crucial M4 256GB, 3 X Seagate 4TB, Lamptron FC5 V2 Fancontroller, Noctua Casefans, Antec P183 Black, Asus Essence STX, Corsair AX860i, Corsair SP2500 speakers, Logitech Illuminated Keyboard, Win7 Home Pro 64 bit + Win 8.1 Home 64 bit Dual boot, ASUS VG278H
    Oct 2006
    That setup wouldnt even come close to playable frames rated on 1440p monitors or higher. So as long as you are fine only running barely adequate FPS in old resolution then ya there is no reason to upgrade.
    Rig 1:
    ASUS P8Z77-V
    Intel i5 3570K @ 4.75GHz
    16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
    Nvidia GTX 670 4GB SLI
    Rig 2:
    Asus Sabertooth 990FX
    AMD FX-8350 @ 5.6GHz
    16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
    AMD 6950 with 6970 bios flash
    Yamakasi Catleap 2B overclocked to 120Hz refresh rate
    Audio-GD FUN DAC unit w/ AD797BRZ opamps
    Sennheiser PC350 headset w/ hero mod
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by nossy23 View Post
    for quads, socket 1156 was about 5% faster clock fom clock than 1366, then the SB is about 7% faster than the 1156, then the IB is about 5% faster than the SB, and the haswel (1150) is supposed be 5-10% faster than the IB. so over time it adds up that you not only should have higher clock speeds but better performance and lower latency. you would not really get anything now but you would get a nice upgrade if you want a new toy. it would also use about half the power.
    Dec 2012
    Buenos Aires
    Haswell will be faster for games, but ultimately you'll be limited by your old gpu. Try to get a gpu upgrade and an ssd, the other bases are covered.
    I'd reccomend a 7970 if you want something now, or maybe even a cheaper 7870 XT or 7950. Nvidia gpus are too expensive and don't clock as well, whilst performing on par at max oc, or slightly worse than AMD cards at most titles.
    EDIT: Again, this all depends on the resolution you're playing at of course. For 1080p you'd need an upgrade if you consider 60fps smooth.
    Sep 2007
    CA Bay Area
    I built my system towards the end of 2010. I specifically built it with the intention of not upgrading for quite some time - I went through about 7 CPUs until I found one that I was happy with. My 870's been running 4ghz @ 1.25v ever since. Originally I built the machine with 4GB of DRAM and a 5850. The only things I've changed is expanding the Memory to 16GB for my photo editing, as well as adding a 240GB boot SSD and a 512GB storage SSD to augment my Velociraptor. I've also swapped out my 5850, but not out of necessity, I was just able to get a newer card for a good price.
    Dec 2012
    Buenos Aires
    Yeah, those chips are strong enough for gaming...if anything gpu+ssd upgrade is in order.
    Aug 2009
    Belgium
    I don't think that's true for gaming. There is no real increase in gaming performance clock for clock, for several generations already. Check this out:
    http://alienbabeltech.com/main/?p=29402&all=1
    The only improvement we can see is in integrated igpu, power consumption, some extra new features, and some non gaming related software that gets a boost (like media encoding, encryption etc)
    Dec 2003
    At work
    I'd second the vote for an SSD...and for more memory. Video card upgrade depends completely on the resolution you plan to run, so unless you're into the multi-monitor gaming, it shouldn't be required. Just for fun, you might also consider a closed water cooling system for your CPU and see if it'll go a bit higher...with that low Vcore, I'd be surprised if it didn't have some more room left in it.
    Server: HP Proliant ML370 G6, 2x Xeon X5690, 144GB ECC Registered, 8x OCZ Vertex 3 MAX IOPS 240GB on LSi 9265-8i (RAID 0), 12x Seagate Constellation ES.2 3TB SAS on LSi 9280-24i4e (RAID 6) and dual 1200W redundant power supplies.
    Gamer: Intel Core i7 6950X@4.2GHz, Rampage Edition 10, 128GB (8x16GB) Corsair Dominator Platinum 2800MHz, 2x NVidia Titan X (Pascal), Corsair H110i, Vengeance C70 w/Corsair AX1500i, Intel P3700 2TB (boot), Samsung SM961 1TB (Games), 2x Samsung PM1725 6.4TB (11.64TB usable) Windows Software RAID 0 (local storage).
    Beater: Xeon E5-1680 V3, NCase M1, ASRock X99-iTX/ac, 2x32GB Crucial 2400MHz RDIMMs, eVGA Titan X (Maxwell), Samsung 950 Pro 512GB, Corsair SF600, Asetek 92mm AIO water cooler.
    Server/workstation: 2x Xeon E5-2687W V2, Asus Z9PE-D8, 256GB 1866MHz Samsung LRDIMMs (8x32GB), eVGA Titan X (Maxwell), 2x Intel S3610 1.6TB SSD, Corsair AX1500i, Chenbro SR10769, Intel P3700 2TB.
    Thanks for the help (or lack thereof) in resolving my P3700 issue, FUGGER...
    Dec 2007
    Earth
    SSD, and GPU will net you the highest performance boost. The rest of your HW is fine for awhile longer
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
    Mar 2010
    Thanks ya'all. Ordered 256gb 840 pro (samsung) and will use my WD black as a data drive! Might hold of on the GPU for now though, since I don't game much like I did in the past.
    I am Xtreme
    Jan 2006
    Australia! :)
    Quote Originally Posted by CrazyNutz View Post
    +1, & more RAM.. get a 3x4GB kit.
    OC your CPU a lil more & you'll be set!
    go read the CPU article on anand about the C2D set-up they recently tested - it shows you how much 'progression' there has been in CPU / CPU usage requirements
    DNA = Design Not Accident
    DNA = Darwin Not Accurate
    heatware / ebay
    HARDWARE I only own Xeons, Extreme Editions & Lian Li's
    https://prism-break.org/
    Oct 2006
    Shanhai China
    Old is still good!
    I keep an old Intel Q6600 running on an Asrock P41 mobo, 2x4GB DDR3 1333 and a 64GB Toshiba SSD SataII under the desk at school. I use it to keep it working as a spare for all my 775 based PCs at home. As I run Q8400,E6750,E6700 at home, so I need spares in case of breakdowns.
    I have it OC from 2.4 to 3Ghz and the old PC kicks a$$ still with every thing it does from video editing to music making. The SSD and 8GB makes a big difference in performance.
    If it ain't broke don't fix it!!! Its not the fastest PC NOW TODAY(its was once) but as I made it up from spare parts it does the job. Just looking for a cheap GTX430/460 card to give it some extra video power from a GT9300, its like an old F1 V8 pickup you keep just to take the rubbish down to the dump!
    24/7 PC CoolerMaster CM690 + 7 fans(its HOT as HELL in Shanghai) Intel Xeon E3 1230 3.3-3.7Ghz, 2x8GB DDR3 1600 G-Skill, HD GT630 2GB, Scandisk Pro 256SSD 2x2TB Green, 2x 3TB WD Green Data Drives. HTPC Q8400, EP45 UD3L 4x1GB Gskill6400, 1xWD Black 640GB,2x2TB WD Green, 2xWD 1TB Blue(RAID1), Sapphire 4530 512MB,
    Computers have enabled people to make more mistakes faster than almost any invention in history, with the possible exception of tequila and hand guns.
    Mitch Ratcliffe, U.S. technology journalist and blogger
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Actually if you have a decent case to start with I see it as one of the few things to get upgraded for a long time, unless you just like switching cases. I don't because it is almost impossible to sell a used case for more than peanuts. I've been using the same chassis since 2007 and still have no intention of switching it. No other case really either appeals to me or is far too expensive IMO. As it was I spent a little over $100 for this case.
    Other hardware lasts me quite a while anymore. I'll skip anywhere from 1-3 generations on hardware. I went from a Q6600, to an AMD 955BE, to a 2600k, and from an X1950XT, to a 4870, to a 7950. I used the same primary hard drive since 2008 until just recently when I got an SSD, and my main storage drive is about 3-4 years old now I think. PSU has been the same since 2007. Heck I still used an IDE NEC DVD-RW drive until my latest board no longer supported IDE anymore And I'm still rocking my old Audigy 2 ZS.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Oct 2006
    Shanhai China
    My Limit
    Every bit of Hardware I have must work with Windows 7. I couple of good P4 systems went into the B!N when the sound or video drivers did not work with W7 installed, made me cry
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    I don't think I'll ever upgrade CPU/Motherboard for at least another three days!
    Fixed!
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
  18. #18
    Oct 2006
    Shanhai China
    I wish I had the $$$$
    I have a 4 year old boy and that takes all my spare cash so I have to save the penies in a big jam jar to spend on my toys!
    Nearly got $300 in change, so come Christmas I should be able to upgrade.
    But seriously I don't need to upgrade till a PC dies on me. I have one that is based on a E6750 and is nearly 6 years old giving some signs of death, but until its dead I will keep it going.
    Then just use a new CPU/MoBo/RAM/SSD and recycle everything else into the build from the old PC. When does an old CM690 become unuseable, 2x2TB WD Green+2x1TB Blue still work, Antac 650W still in good order and the DVD still plays.
  19. #19
    Jun 2009
    You said your using your computer for home use, do you play games with your system or use it vmwares, etc?
  20. #20
    Mar 2010
    Just purchased a powercolor 7950 pcs+
    I guess I'll be playing pc games again... Oh Oh
  21. #21
    Xtreme Enthusiast Kai Robinson's Avatar
    Oct 2007
    East Sussex
    The computer in my sig is still what i'm using, 6 years on. Last major upgrade was 3-4 years back. Considering a new rig this year but eesh...hard to decide what to get Intel/AMD wise :/
    Main Rig
    Intel Core i7-2600K (SLB8W, E0 Stepping) @ 4.6Ghz (4.6x100), Corsair H80i AIO Cooler
    MSI Z77A GD-65 Gaming (MS-7551), v25 BIOS
    Kingston HyperX 16GB (2x8GB) PC3-19200 Kit (HX24C11BRK2/16-OC) @ 1.5v, 11-13-13-30 Timings (1:8 Ratio)
    8GB MSI Radeon R9 390X (1080 Mhz Core, 6000 Mhz Memory)
    NZXT H440 Case with NZXT Hue+ Installed
    24" Dell U2412HM (1920x1200, e-IPS panel)
    1 x 500GB Samsung 850 EVO (Boot & Install)
    1 x 2Tb Hitachi 7K2000 in External Enclosure (Scratch Disk)
    Entertainment Setup
    Samsung Series 6 37" 1080p TV
    Gigabyte GA-J1800N-D2H based media PC, Mini ITX Case, Blu-Ray Drive
    Netgear ReadyNAS104 w/4x2TB Toshiba DTACA200's for 5.8TB Volume size
    I refuse to participate in any debate with creationists because doing so would give them the "oxygen of respectability" that they want.
    Creationists don't mind being beaten in an argument. What matters to them is that I give them recognition by bothering to argue with them in public.
  22. #22
    Mar 2010
    Update: sold the 7950 for a huge profit (thanks miners) and picked up a 780 gtx. Also just bought a Xeon x5650 cpu. I love my I7 930 and I think it's a fabulous chip, but for the price and the fact that I'll be getting a 32nm and 6 core it just made it too tempting. Hopefully I can at the minimum overclock it to 4ghz and if it does in fact overclock then I'll need to figure out what to do with the 930...hmmm
    Quote Originally Posted by Kai Robinson View Post
    As long as you're happy. But now that you know you'll possibly be keeping you're next build for 5+ years, then you may as well go all out
  23. #23
    Jun 2007
    Good question, so let me try to flesh out an answer. I've been upgrading and downgrading constantly with new builds since 1998. Probably built at least 25 single socket setups and an equal number of dual socket ones pretty evenly divided between AMD and Intel. But mostly all Intel for the past 5 years. My current i7 4770K mini ITX rig was so cheap (Microcenter $199 deal with $40 off the motherboard) that I can't see upgrading from that one. I can't see any need for more than the GTX 760 video since that does the 2560 x 1440 nicely for my HP 27" monitor. I'll generally pick a main system and keep it for 5 years and then rotate in 3 to 5 more systems to play with and then resell the parts. The micro ATX dual socket 771 system was also so cheap ($250 for the motherboard, CPUs, and 24 GB RAM), I'll most likely keep that one for at least 3 years. The old PC-DL dual Prestonia Xeon rig is retired, but operational - I boot it up every other week or so. I recently built and AMD A10 6800K rig for a friend, so I don't see the need to do another AMD. But, then again, next week I could decide something is a good deal and be off again.
    Server - Corsair 400C Clear Case, Supermicro 665W PSU, Intel S2600CP eATX, 2 x Xeon E5-2640 (12C/24T), 32GB DDR3-1333 Reg/ECC, MSI GT 730 2GB GDDR5
    Daily Driver - Xigmatek GIGAS mATX Case, Corsair 750W Modular PSU, HP IPIWB-PB X79 mATX, Xeon E5-1620 @ 4.4 GHz (4C/8T), 16GB DDR3-1600 @ 1866, Sapphire HD 7950 3GB GDDR5
    ITX Gamer - SilverStone SST-SG05BB-LITE Mini ITX Case, Asus H81I mITX, i5-4590 @ 3.3 GHz (4C/4T), 8GB DDR3-1600, Zotac Mini GTX 1080 8GB GDDR5X
    Laptop - Acer AS5750-9422 Laptop, 15.6", Core i7-2670QM (4C/8T), 16GB DDR3-1600, HD 3000 Graphics
