My thoughts exactly STEvil
So it's true, Full AMD gen with xbox and ps4 will be AMD's CPU+GPU.
So i guess valve' box on AMD hardware and linux OS will be soon a real gaming rig. <= I may be interested by valve' box. i just hope that games will be able to play @ PC fashion way. i don't like playing with other way than keyboard + mouse untill now. maybe they're going to improve way to do that with new ideas introduced by nintendo with wii, microsoft and google's glaces.
... if i can't choice what i can use to control my games, i'm not going to buy it for sure.
G70/71 was over slow ... and low number of units :/ Even when it comes out, ... So i was surprised they used cell and a low GPU for P$3.
It was a big mistake to not get a powerfull GPU instead of doing a CPU powerfull for the day when it comes and useless for gaming, hard to code and we all know a slow CPU is not a big problem if you have a powerfull gpu. But i'm sad they don't use 7970/7950 instead of 7850/7870, now 7870 is not so slow but in 4 years, it's gonna be very slow, and 7970 would be a be higher priced at start but go fast cheap and better for having some AA in game.
So PC is still the best ...
go 7970 for a good performance / price ratio and forget ps$4
You're trolling right? because this console isn't using DDR3. AMD designed the memory controller that gave the 7850 153.6 GB/s, so why cant they implement this into this custom core?
Also people mentioning the geforce GTX 480 & 580....well the Ati 7870 is basically a match for these GPU's in graphics tasks (not so sure about GPGPU). So its no surprise. Seems quite good really.
Yes, but the point isnt that the desktop proc.s only have 1/7th of the discreet cards bandwidth, but that they compromise very little in sharing between the cpu&gpu in actual use. You claimed there was a large compromise.
maybe you mean this ? Geforce GTX 680 Whitepaper FINAL
According to Table in www.planet3dnow.de :
Cinebench 11.5 single : Tamash = 0.35 , Trinity = 0.35
Cinebench 11.5 multith : Tamash = 1,39 , Trinity = 1.14
since Tamash works at 5w TDP while Trinity at 100w , this is really impressive.so Jaguar uses some of tech from Tamash ?
CPU : Athlon X2 7850,Clock:3000 at 1.20 | Mobo : Biostar TA790GX A2+ Rev 5.1 | PSU : Green GP535A | VGA : Sapphire 5770 Clock:910,Memory:1300 | Memory : Patriot 2x2 GB DDR2 800 CL 5-5-5-15 | LCD : AOC 931Sw
Jaguar is the x86 core inside Kabini/Temash. Kabini and Temash are just codenames for SOCs(system on a chip containing CPU,GPU,IMC and rest of the logic).
You're speaking pure theoretical numbers. I'm talking about the look of actual games, you completely missed my point like many others.
Improvements in visual fidelity between generations is becoming less and less noticeable and in turn less of a marketable bullet point. Doesn't matter how many flops it pushes.
Iron Lung 3.0 | Intel Core i7 6800k @ 4ghz | 32gb G.SKILL RIPJAW V DDR4-3200 @16-16-16-36 | ASUS ROG STRIX X99 GAMING + ASUS ROG GeForce GTX 1070 STRIX GAMING | Samsung 960 Pro 512GB + Samsung 840 EVO + 4TB HDD | 55" Samsung KS8000 + 30" Dell u3011 via Displayport - @ 6400x2160
