Card dead? I get error code 97 on my p67 extreme 6 board. Works fine with the 6850 back in place. Any ideas folk? I hate to RMA a brand new card, but if thats what has to happen, thats what has to happen.
Thanks,
Michael
Thanks,
Michael
ASrock p67 Extreme 6
4x4gb Samsung 30nm 1866 9-9-9-24-1t
PCS 7870 MYST
i7-2700k 4600Mhz 1.315v
corsair H50 cooling push/pull
Had to update motherboard bios!!! Weird, but it works now! Applied some Ceramique to the core, idles at about 30c, full load 60c so far @ 1050 core. Not sure how to OC these new cards, I pushed the power envelope to +20%, but the core clocks would change constantly in 3dMark 2011, lowering the score if I went higher. I've read that "Boost" causes these problems, is there a way to turn it off?
PCS 7870 MYST
Trixx works pretty well for OC. I'm currently Using the non boost bios because my card came w/2 of them(it has a switch on the mobo) Unfortunately I cant go beyond 1050/1450 on my card unless I force constant voltage In terms of switching out a bios you can try using atiwinflash and use a non boost bios 7970 see if you can get a higher clock. Good luck!
I'm also curious about 3dMark, it seems that my "overall" score keeps getting destroyed no matter how much I put into the card. I wonder if this is an error software side?
i7-3820
SB Z
16GB 2200
GTX690
1KW Lazer
