Good day to all!
I've been studying hard these softwares and all the other softwares to achieve the maximum mhz's on my A10-5800k, but still I can't see how it can help
I've done this:
1st - Go to Bios and define BCLK:125.00, multiplier 52x and vcore: 2.0v, 4 cores enable;
2nd - Boot to windows;
3rd - Open CPU-z and PSCheck;
4th - Define a PState on P5 with 125mhz (multi 1x) and the less vid possible (althought it doesn't change voltages at the time I use fixed values on bios ), and define a PState with multi enought to do decent mhz;
5th - Save CPU's and exit;
6th - put the 2 Node's - 4 cores at the low PState of 125mhz and cool down the CPU to -196?C and put it with that temperature for 3~4minuts;
7th - Then when it is completly freezed, change to state of the more "clockable" Node to the high multiplier state and ... BSOD
Nothing diferente from not using directly this:
1st - Go to Bios and define BCLK:125.00, multiplier 52x and vcore: 2.0v, one core enable (the more "clockable");
3rd - Open AMD Overdrive and push for multi until you get the biggest frequency you can get.
I know that it must have some trick related with PSCheck, but I'm missing it, completly, and don't know Been studying it for days and days and already killed 4 A10-5800k
Can some AMD expert help me?
Cheers to everyone!!
Andr?
